Question about Brother DCP 115C All-In-One InkJet Printer
Ink absorber pads FULL, will not 'clean' itself anymore
I can buy a new ink box (with pads included presumably) for about £3.50 but hey said it wouldn't work because once I had fitted the box back into the printer body, I then have to Input the install Code to reset the machine to tell it that there are new pads in place.
But, they won't tell me the codes, or, how to do it.... the swines!
Can anyone help?
Thanks, Les, Littlehampton, West Sussex, UK
  • 13 Answers
Brother DCP110c Reset Counter
1. press the Menu & Mono start keys. next press the up arrow key 4 times to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. press the mono start key several times untill the purge count appears on the LCD.
4. enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero
5. press the stop/exit key to return to the initial stage of the maintanance mode.
6. enter 9 twice by using the up arrow & set key’s to exit from maintenance mode
hope it works
Posted on Dec 08, 2008
My Canon MP210 printer [ USB001 ] said the Ink absorber is Full contact the service center. Guess what, the service center just gave information. I need to know if will be able to fix or will...
There are two possible ways to remove the error from your printer. First is to actually clean the absorber pads that are full of waste ink. The second is to reset the printer to clear the error and let the printer print again.
Clean the two absorber pads. There are actually two absorber pads located on the right side of the printer, under the
ink cartridges when the carrier is in the home position.
Accessing the pads and remove them for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezers and extra cloth for some ink spillage. Using the tweezers, lift up the pads sitting on the rubber retainer. The pads can be easily clean by placing them under running water. Use warm water to remove the ink from the pads. Dry the pads and reinstall them. Same procedure if you are installing new pads.
However, the problem will not be solve especially if you are currently facing the waste ink absorber full error or E-27.
Reset Waste Ink Counter Canon Pixma MP210 and Canon Pixma MP220
1. Start with printer off
2. Press and hold resume Button (triangle in the circle) and click "Power" button. green led should be on
3. hold the Power button, release Resume Button.
4. Without releasing the Power Button, double click "Resume" button and then release Both Buttons.
5. Click "Resume" for four times then click "Power" button, to confirm the selected action (reset counter absorber).
6. Turn off the printer and turn on again
7.
Please rate this solution. Let me know if you have any more questions. Thanks.
May 30, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Ink absorber full on a canon mp190
my canon Mp 190 ink absorber all most full. How to do?
May 09, 2011 | Canon PIXMA MP190 All-In-One InkJet...
The waste ink absorber is full.
Hey!Unfortunatly when the ink absorber is full the machine has reached its lifetime and the cheapest to do is to buy a new one as there are no why of cleaning or replacing the absorbers!!Sorry!!
Oct 20, 2010 | Canon PIXMA iP1600 Printer
I try to print on my canon ip1800 but it says the ink absorber is full how do i fix this
Hi It is a pad inside your printer witch absorbs the left over ink when it cleans itself this pad is full there only one way and that is to open it up with a screw driver it a messy job and put some other pad in place of it after any thing just to absorb the left over ink
Jan 22, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
My canon pixma ip 1600 has a full ink absorber---is there any way to fix this or do i need to buy a new printer-thanks
Try to remove the absorber (wear rubber gloves--very messy) and wash it in hot water and detergent. You can buy the replacement part if you don't want to try to wash it.
Sep 15, 2009 | Office Equipment & Supplies
My brother mfc 440cn read unable to clean error46
Its Ink Absorber Box is full. Inside the machine, in the back and hidden under the covers is a large plastic box with thick, felt pads packed in it. Every time the machine cleans its printheads, it squirts ink through all its nozzles, collects the mess, and pumps it into that box. After a few thousand cleaning operations, it decides the box is dangerously full of ink and throws up that Error 46.
Getting to the Ink Absorber Box (part number LP1270001) is fairly complex. I think it's time to ask a tech what he/she charges.
Jun 05, 2009 | Brother MFC 420CN All-In-One InkJet...
I'm getting a message that the ink absorber is full & the printer won't print
ok my best solution would be to get an engineer out to give the printer a thorough service but if this is costs more than the printer i would suggest just buying a new one. the problem is that when the printer cleans itself (i'm guessing its inkjet) it sometimes squirts a tiny amount of ink into an absorbant pad or container and over time it builds up and so the printer can't print as it would more than likely be spreading the old ink over the page. hope thats any help to you
Jun 16, 2008 | Office Equipment & Supplies
Printer problem
The ink absorber (a felt pad) is provided so the ink lost during cleaning has a restricted area to ensure the ink doesn't escape into mechanical areas of the printer.
I haven't seen the inside of your model but this is probably being monitored using reflected light and once the reflection is reduced (pad changes from white to dark) this warning is triggered.
The printer has been disabled to avoid cast-off ink from overflowing the recess in which the pad is installed.
Unless you are very good at finding the sometimes many snaps that hold your printer together, it should be turned over to a professional.
As a retired tech, I need to warn you that the cost of labor and the pad needed will probably exceed the cost of a new printer.
If you decide to replace it, be advised that most printers are supplied with only minimal amounts of ink in their included ink cartridges; please consider buying cartridges along with the printer to have available when the original cartridges run dry.
Apr 08, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA MP130 'waste ink absorber' message
If the error message is ""ink waste absorber almost full"
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by pressing OK
4)Enter ABS-M LEVEL by pressing <--- or ---> then OK
5)SET ABS-M LEVEL TO 0
6)OK
7)STOP/RESET"
If the error message is "" bottom ink waste absorber almost full"
Set "ABS-P" level to 0. Then "OK" and "STOP/RESET"
To clean the absorber, open the cover, and there are 2 small pads under where the cartridges normally sit. Put a pad of absorbent kitchen towel on top of the pad and press down a few times. The towel should absorb most of the ink. To give it a really good clean, turn the printer upside down while holding the kitchen towel over the pads and press a few times. You'll get more ink out.
It's a good idea to wear disposable gloves when you do this.
Apr 07, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Brother DCP 115C All-In-One InkJet Printer Logo
317 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
