Shadow images on monitor
Behind words and photos too there seems to be a gray shadow kind of a faint double image.
  • 1 more comment
  • mark165 Jan 12, 2009
    I hae t PC, both HP... Both have monitors HP w19b. Within 2 weeks of each other they started to have a ghost image to the right of the object. The ghost image is a faint shaded area. The ghost go directly to the right ...not right and down or up, just to the right of it
  • lv421 Mar 05, 2009
    Have a HP w2007 19 inch LCD monitor and after 10 months it started to have a ghost image to the right of the object.
  • Anonymous Mar 21, 2009
    same problem got a hannpree 28 inch tv, 1920x1200, hp computer, cant put it on native res cause card doesent go that high, ghost to the right as well. idk, annoying..............
  • 558 Answers
If it is vista it is normal otherwise I would need more info operating system video card monitor etc.
Posted on Dec 03, 2008
  • Scott Hill
    Scott Hill Feb 01, 2010
    thanks for the **** rating
Dell flat screen monitor is repeating images
"Shadowing" effect fixed by separating the wires in back. Touching wires cause crosstalk of signals . Immediate fix.
Aug 01, 2014 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor won't come on
If the light inside the monitor is no good, you'll still be able to very faintly see the "shadow" images of what is being displayed. If you just plug in the monitor by itself to power and turn it on, does anything happen?
Nov 06, 2013 | Westinghouse Computers & Internet
Alignment is not the issue with my printer... i keep getting a shadow behind my letters and images I print, but not on typed documents... only scanned ones or copied and pasted images into word... so...
The shadows are common from scanned images. You might want to hold the book you are trying to scan in a better angle so that the scanner can read it more clearly. Then your scans won't have that many shadows.
Mar 06, 2011 | Office Equipment & Supplies
'Shadows' behind all texts and images on the screen
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Oct 13, 2009 | Acer AL2016W 20" LCD Monitor
Im seeing shadow/double images of text,icons etc.even a system recovery has not helped.what is causing the problem?
Most probably you have a problem with the connection between your graphics adapter socket & your monitor. Check this connection & make sure it is not loose & that the cable connecting your computer to the monitor is not damaged or is not running very close to a source of electromagnetic interference.
Oct 02, 2009 | HP Pavilion m7750n PC Desktop
Double Images / Shadows on the monitor screen
Hi..there,
Have you guys...try to open your OSD on your monitor and blanced the colors or adjust the WB (white blanced) settings....
Jun 30, 2008 | Gateway FPD2275W LCD Monitor
I read through other solutions to this problem because I had the same problem. I checked to make sure electrical cords were properly attached, and vola! problem solved! I had no idea this problem could be fixed just by checking the cord connections. Thanks a million for posting this solution. I had been putting up with the shadowing, streaking for months! You really made my day.
Jun 10, 2008 | Gateway FPD2275W LCD Monitor
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Blue image shadow on one side of the screen..Help!
Perfect! That is typically called "Ghosting" where there is a faint image shadow behind the image on your screen. I'm glad you were able to get it fixed!
Jul 23, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Computers & Internet Logo
1,450 people viewed this question
David Payne
David Payne
