I have a JVC RX778V Audio/Video Reciever. It has recently been shutting down when watching tv and says on the reciever, "OVERLAOD". We turn back on but it continues to do this
I had incountered before VICTOR colored TV.ive found out that the problem was in the switch relay on the power supply area.. My suggestion is to check the relays wich is located at the supply board area resoldered the pin to make sure the pin is in solid contact. or put an AVR back up to your TV. If the problem still occur check the regulator IC or try to change a new IC this might help the problem.
hello if got a dvd recorder with a dammage hdd i need the firmware for the panasonic dmr-eh65 can...
(More)
hello if got a dvd recorder with a dammage hdd i need the firmware for the panasonic dmr-eh65 can jou help me
Good Morning, I just moved into a new home with an M&S System WH 35X for MC170, 300 or 370...
(More)
Good Morning, I just moved into a new home with an M&S System WH 35X for MC170, 300 or 370 Series M. The unit is not turning on unless the power source is dead. Is there a way to check this, would love to have this turned on around the house. Thank you. EPickell@its.jnj.com
My Olympus VN-4100PC is dead - there is no display and no lights. I have put fresh batteries in and...
(More)
My Olympus VN-4100PC is dead - there is no display and no lights. I have put fresh batteries in and that doesn't change anything. I had the device in my purse near my Blackberry Curve cellphone. Could it have gotten fried from the Blackberry? Is there anything that can be done?
