Question about Maxtor MaxAttach NAS 3000 40 GB Network Hard Drive
My maxtor external hard drive just keep on blinking(green light
It does not work, my PC can't access any data inside my maxtor hard drive. the green light just keeps on blinking
SOURCE: Maxtor One Touch III mini drive problem
Had the exact same problem with my 60GB Maxtor Mini III Edition, still cant find solution that works, when i rang up Maxtor they took me throught the above process- didnt work for me, but could work for you! Hope it does! Goodluck. Brentic
Posted on Jun 03, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Maxtor External Hard drive not compatible with Mac
I would check Maxtors website to see if there is compatibility issue using that particular drive on a Mac.
Posted on Jun 10, 2008
  • 22 Answers
SOURCE: Maxtor Basics 1500GB access issue
Go to the following website and download the FREE TestDisk program.
http://www.cgsecurity.org/wiki/Main_Page
Make sure you read through the documentation for using the software. This is a powerful Data Recovery tool so proceed with caution. It can fix lost partitions, deleted partitions and many other issues.
Posted on Apr 06, 2009
SOURCE: Maxtor Basics 1Tb external hard drive not working
Apri il prompt dei comandi e digita cd.. e premi enter tante volte quante servono per andare in C:> ; ora digita CHKDSK X: \F dove X: dovrai sostituirlo con la lettera assegnata all'HD in cui non riesci ad entrare, premi enter. In poco tempo corregge gli errori, non si sa (almeno io) come si sono formati, e tornerai a riveder le stelle! Te lko auguro ame ha funzionato
Posted on Apr 28, 2009
Chinthakaj
  • 416 Answers
option 01. try the unit on another windows pc. if its the same. i am afraid you might have an issue with the device.
option 2 . you could remover the **** from the enclosure & fix it directly to the pc so that you can retrive the data. however this will have an impact on your warranty
Posted on May 23, 2009
I've had my Maxtor external hard... Answer I've had my Maxtor external hard drive for a good 3-4 years, and for some reason, it just seems to stay idle and not let me access my data that is on it. The...
You did well to have it work so long!
It is out of warranty - open it up, remove the drive from the case. It may be a SATA drive, but probably an IDE from 4 years ago...
Just place it in your computer and it should work fine. The most common problem is the controller card for the external connection has failed. so putting it in your computer as a normal drive will either fix it - or tell you that the drive has died.
Oct 05, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Can't retreive any info from my maxator green
Good day sir/maam, I had the same problem with my generic external drive, keeps blinking but cant be recognized by the PC. chances are the Maxtor is done, you can salvage the Hard disk inside. Visit your dealer if its under warantee demand for a replacement they may also have service people to take a look at the drive. hope this helps
Aug 03, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
My Computer does not recognise the Maxtor 3200 personal storage
hdd problem,, 50% can fix you hdd.. if you have inportant data just make recover.. you can't use that for install program and operating system just only for external, save data but dangeros also maybe someday it wil not work totaly..
try to change the board if could
Jun 16, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
External Hard Drive problem - Why God!? Why!!?
sure..the power is not the key issue..what you might consider, is calling a local computer fix it shop, and ask how much to recover that data..then, you may be well advised to consider an online back utility, such as you can find here.
Oct 13, 2008 | Maxtor Personal Storage 3200 (M1227310)...
You need to open the enclosure and either put the drive in another enclosure or connect it directly to your computer.
Or you can pay to send it to data recovery people and they will get all the data off.
May 27, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
I have a maxtor 3200...
are you accessing the drive. When you accessing/using the drive, the light will blink.
Apr 06, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Blinking green light
Same problem. Blinking green light. Device not recognized. Have my whole life on this drive! HELP!
Apr 03, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor MaxAttach NAS 3000 40 GB Network Hard Drive Logo
1,109 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
