Question about Whirlpool RBD305PD Electric Double Oven
Oven has 4 conductor power cable, moved to house with 3 conductor
We have a whirlpool super capacity 465 self cleaning oven. can a 3 conductor cable be used and if so how should it be wired?
  • Whirlpool Master
  • 3,463 Answers
Unless your cooker is totally different to the norm, then yes you can use 3 core cable. assuming you are in the u/k, then the following applys.Brown is live-Blue is neutral, andGreen/Yellow is earth.
Depending on the total wattage of the cooker, you will need to use a min of 6mm twin and earth cable, If in any doubt, consult an electrician
Please leave feeedback
Posted on Dec 05, 2008
SELF CLEANING INSTRUCTIONS FOR WHIRLPOOL SUPER CAPACITY 465 ACCUBAKE
It's best to remove the racks. However you can go on line to download a free manual.
Dec 31, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool self cleaning oven super capacity 465
If there is a lot of grease it may be good to wipe the excess out. The excess grease could ignite if not it can sure smoke up the house.
Nov 12, 2013 | Ovens
Don't have a appliance booklet for my Whirlpool Model 465 Super Capacity oven - need to know how to clean please
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Jan 06, 2011 | Ovens
I ha ve Whirlpool self cleaning oven super capacity 465. The broiler portion works but the oven portion does not.
The most likely part to be the prob is gonna be the ignitor. Even if it is glowing it could be weak. If it is dim orange it is weak. Check out this Vid:
Dec 28, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I JUST MOVED INTO A HOUSE WITH A WHIRLPOOL SUPER CAPACITY 465. IT DIDN'T COME WITH A MANUEL AND WE DON'T KNOW HOW TO BAKE. WHEN WE PREHEAT IT DOES NOTHING. THE SELFCLEAN AND BROILER WORKS THOUGH
Remove the bottom tray in oven compartment...... usually 2 screws at the rear... Turn it on to bake and see if ignitor glows if not test ignitor for 120v if you have 120v replace the ignitor. If it glows and still does not light burner after a few seconds the ignitor is weak replace it. (The gas safety valve has to receive a certain amount of power that must flow through the ignitor for the burner to ignite a weak ignitor will not allow enough power to flow through it). If you are not getting 120v trace the circuit.
Nov 04, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Error codes E1 F2 whirlpool super capacity 465 oven
HI. This code is a good indication of a separated key pad ribbon or the actual key pad may be damaged. Use the procedure below to isolate the culprit.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jul 25, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool self cleaning oven problem
Hi
Thanks for using FixYa. This error means that you’ll need to check the door latch/switch and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 09, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
ER1 F2 error on Whirlpool Super Capacity 465 RF386PXE Oven
HOW DO YOU CLEAN SELF CLEANING OVEN SUPER CAPICITY 465
Sep 23, 2007 | Ovens
Whirlpool RBD305PD Electric Double Oven Logo
106 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De GO PATS
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
