Question about Maytag MAH8700A Front Load Washer
Maytag Neptune Mah8700aww doorlock
The doorlock will not release to let the doorlatch in. I would suspect that I'm very lucky that the door wasn't closed when this part went out. Am I right to assume I need to replace the part that actuates the lock?
  • sweet_mm70 Dec 14, 2008
    doorlocked at the end then wouldn't open .Then it opened after 7 hrs.and know won't stay shut or locked .go figured .severely frustrated. help
wagdom
  • 64 Answers
SOURCE: Maytag Neptune MAH8700AWW Front load
You must be on the right track, must be a blockage at the back of the soap drawer, check if junior has posted a toy car! If not turn down the water pressure at the machine stop tap
Posted on Oct 21, 2007
SOURCE: Maytag neptune error code d5
there is a small button on the inside edge where the door closes, it was broken off since there was nothing there I didnt see it.It was only a hole where the button was.So I had to get a new button and replace it.
Posted on Jun 17, 2008
reg501
  • 413 Answers
SOURCE: my maytag neptune washer model
Look carefully in the inside front of the dispenser. You should see what looks like a red plastic string. (the type of string used on a power string trimmer) Pull on this string and the door should release.
If you need further assistance please let me know..
Regards
reg501
The FixYa Team
Posted on Jun 22, 2008
SOURCE: Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
Posted on Oct 10, 2008
  • 99 Answers
SOURCE: Maytag Neptune MAH8700AWW Error Code Hr
this is joyce:
have you tried just unpluging the unit from the wall and waiting for 1 min and repluging it into the wall, this usually resets any codes. if not I will be happy to research this for you, infact I am doing it now while we speak, you try the simple method first. and let me know how that goes. my name is joyce
Posted on Feb 06, 2009
My maytag neptune MAH8700AWW shows an error code OE and the door is locked, how do I fix it?
Opening a locked door , click for a visual demo: Door locked#
It is possible that the actuator to the lock has failed and so is not releasing or there is a error on the control panel.
Jul 05, 2012 | Maytag Washing Machines
My Maytag MAH2400A Front Load Washer will not open. Locked inside of the chamber is a load of laundry. How do I open the door without damaging the mechanism that keeps it closed?
As I sit here with my Maytag Neptune MAH8700AWW torn apart, I can tell you it is impossible to unlock and the 800 number is no help. They tell you to unplug it for 5 minutes. Some web posts talk about a "magical release cord" under the top cover but it does not exist.
Nov 24, 2010 | Maytag MAH2400A Front Load Washer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
We just installed the MAH9700AWM Maytag Neptune and got an error code OE? We cancelled cycle, etc still getting issue.
The "OE" error code means the control detected the water level in the machine is above the overflow level. According to your description the first failure suspect is the water valve possibly stuck. Perform the troubleshooting as described in the tech sheets.
Here are the break down diagrams for the Maytag Neptune washer Model MAH8700AWW
Feb 25, 2010 | Maytag MAH9700AWM Neptune Front Load...
I have a maytag neptune modle mah8700aww the door won't unlock
Getting rid of the Maytag Neptune is the only solution!
Feb 14, 2010 | Maytag Washing Machines
The front door is locked and cannot be open.
Look for a thin clear looking line in the soap dispenser. Pull the soap dishes out and look towards the front closest to the door. It looks like fishing line but it is the door lock release. Pull it to get your door open and clothes out. Most common part needed in this situation is a new doorlock assembly (part #22003593). I hope this helped.
Jan 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
Our maytag neptune mah8700aww front loader will not drain and unlock the door. what do i do.
The drain pump os obviously either blocked or gone. Lie the drain hose on the ground to drain by gravity. Then have a look at the pump. This may need to be taken out as I'm not sure if there is a pump filter on this particular model. The door is designed to not open with water in the drum.
Dec 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
How do I replace the door switch button?
unscew & raise the top panel to gain access to the switch
easy fix!
Jul 21, 2009 | Washing Machines
My maytag neptune washer model #MAH8700AWW door is locked and wont release. Is there some manual release?
there is no "red string" on this specific model. Its really irritating that everyone is saying this when clearly no one can find a red string. Stop giving this advice. From what i can tell so far the release lever is inside the machine and to get to it you have to remove the front panel. My problem now is i cant get the top electronic panel off to get the front panel off... this machine is like a giant chinese handcuff!! I will never buy a maytag ever again!!
Jun 22, 2008 | Maytag Washing Machines
My maytag neptune washer #mah8700aww,display "lo" what is?
maytag neptune washer model # mah8700aww. there is no power on the display. checked power to outlet,
Apr 29, 2008 | Maytag Washing Machines
Maytag MAH8700A Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
