Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Shadow printing with Blue color. C350
My title page has a shadow of my print on my title pay. It shows a light image of some of the letters.
    Problem Solver:
  • 7 Answers
Sounds like you may be getting ghosting from the fuser unit upper heat roller may be worn
Posted on Dec 03, 2008
Blue Streaks & "Shadow Prints" on everything?
Mam, try replacing the cyan (blue) image unit may have a bad cyan image unit.
Jan 15, 2015 | Konica Minolta Magicolor 5450 Printer
Samsung clp 315 printing shadow images
Ghosting appears often because of bad toner. If cartridges have been refilled, they have wrong toner in them. If drum has worn out it will usually tell you. All parts for this machine cost too much. If toner is not the problem, probably best to get a new machine rather than pay to get it fixed. Brothers are cheaper to run.
Sep 01, 2014 | Samsung CLP 315 Laser Printer
How do I prevent my HP 1600 LaserJet from leaving a shadow of printing on the page?
Run 30-40 blank pages through it to take the image off the belt.
Go to Word or another WP program, call up a blank page and print it 30-40 times.
Mar 03, 2014 | HP LaserJet 1600 Printer
Image of last print shows up on presant print
This is usually caused by the left over toner not being properly cleaned from the transfer belt.
Open the printer front cover and close it. Wait for the printer to cycle. It usually make a little noise then stops. Then open the cover and close it again. Then print.
If the first page of the print out is clean. but the next page you print has a shadow of the first page, then you have a a problem with the cleaning mechanism.
Unfortunately the cleaner is part of the image transfer belt assembly which runs about $150 to $200. Unfortunately not terribly cost effective as compared to the original cost of many of these printers.
Good Luck.
Feb 11, 2014 | Samsung CLP-315W Laser Color Printer
Print appears on multiple pages
check the fuser unit in the back of the machine; typically the shadow effect is caused by the fuser assembly. Inspect your toner cartridges for any leaking toner. Genuine HP or ? ? ? ?
Dec 20, 2012 | HP Color Laserjet 3550 Printer
I have a HP Color Lasterjet 2600n when I print in blue, the printer prints a "shadow" of the letters in a pinky color to the side of the blue text.
calibrate the printer three times then close the prionter at least 30 min.restore on factory defaults (cold reset).
Sep 29, 2010 | Office Equipment & Supplies
Brother MFC-7420 just started printing a shadow image
Sounds like a bad drum cartridge. Pull the toner/drum cartridge out of the machine and set it down. Press down on a (blue?) tab to release the toner cartridge, and you can lift the toner cartridge out of the drum cartridge. There is a cleaning blade in there - a soft plastic blade that rides against the drum and scrapes off toner that didn't get transferred to the paper. If it gets stuck off the drum surface, images repeat a few inches (one drum circumference) down the page.
A new DR-350 drum unit should fix it. have the machine's power on when replacing it. While the door is open, touch the CLEAR key. The display will read "REPLACE DRUM?" or something like that. Press 1 for Yes.
Jan 05, 2010 | Brother MFC 7420 All-In-One Laser Printer
Sooty background won't go away
You most likely need to get a maintenece kit on it what that includes is the fuser. It could be tht the fuser itself is damaged or has burnt toner on it causing it to apear dirty
Feb 12, 2009 | HP LaserJet 2605DTN Color Printer
HP Printer problem
Sounds as though one of the drum cleaning blades is failing.
When you see the double image shadow, is it any particular color? If so, that's the drum unit that is failing.
Feb 06, 2008 | HP Color LaserJet 2600n Printer
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
383 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
