Question about Swintec 7040 Typewriter
Electric typewriter does not print clearly.new ribbon,no help.
Printing problem.Typewriter doesn't print sharply.Replaced ribbon to no avail.Cleaned wheel,helped a little.Now what?
  • 478 Answers
Try typing on different paper also try typing on the heavy setting
Posted on Dec 07, 2008
Hi we have an old ibm typewriter. I changed the ribbon and the wheel. I cleaned everything but still prints half of the letters. The top part to be exact.
There should be an adjustment on the head that sets the angle of the strike for the wheel. Unfortunatley there are no diagrams available for this technology
Jan 06, 2015 | IBM Wheelwriter 1500 by Lexmark Electronic...
Typewriter won't type
check to see that when yu replace the ribbon it has not slipped in front of the print ribbon and that you have not got the button for corection pressed by mistake it is using this to print you letters not the ink ribbon
Jun 11, 2009 | Brother ML-300 Typewriter
Typewriter is working fine but won't type anything on the paper - new ribbon / new printwheel - no impression. Appears to be stuck on a "stencil" setting.
Put in a mulit part form, if it prints on the copies the ribbon isn't lifting, if it dosen't the plastic cap on the print solenoid needs replaced.
DickyO
Apr 23, 2009 | IBM Wheelwriter 30 Typewriter
Put new ribbon cartridge in ibm wheelwriter 3 not printing now
If the ribbon is lifting up you probably have a cracked print solenoid plunger cap. They are available but a little tricky to install.
DickyO
Feb 10, 2009 | IBM Wheelwriter 30 Typewriter
I have a brother electric typewriter and the print on the paper is no longer sharpin appearence.I changed ribbon to no effect.Now what?
MAKE SURE RIBBON IS INSTALLED CORRECTLY, SHOULD BE BETWEEN "FINGERS" NEXT TO CARDHOLDER AND CARDHOLDER.
COULD BE A BAD BATCH OF RIBBONS
SOMETIMES CORRECTABLE RIBBON DOESN'T PRINT WELL ON CERTAIN TYPES OF PAPER, SUCH AS "NCR" PAPER, TEXTURED, SLICK OR ANY PAPER THAT HAS BEEN THROUGH A PRINTING PROCESS (FORMS, LETTERHEADS, ETC.)
CHECK RIBBON ITSELF. THE CARBON SHOULD BE A FAIRLY EVEN LAYER. IF THERE ARE BLANK PLACES----
Dec 03, 2008 | Swintec 7040 Typewriter
Printing different letters
take to a repair shop or get a new one, no easy fix for this
Aug 21, 2008 | Brother GX-6750 Typewriter
Typewriter - Swintech 2640
Sounds like you need a new ribbon or you are using non-Swintec compatible ribbons that are not properly aligned to your ribbon feed. Try using Swintec brand ribbons and see if this still occurs. Worst case scenario, you need to have your ribbon feed adjusted at your local dealer.
Jay @ www.granadahillsbusinessmachines.com
Aug 08, 2008 | Swintec 7040 Typewriter
Ibm wheelwriter 5
Most likely the plastic cap on the print solenoid is broken they are available but are a bit tricky to install.
DickyO
Mar 27, 2008 | IBM Wheelwriter 30 Typewriter
Typewriter won't print
see on the lamps, is the printer lamp lights
Feb 04, 2008 | Brother ML-300 Typewriter
Typewriter not printing
There is a plastic cap on the end of the print solenoid plunger that nis probably broken the part is available about 10.00 but a little tricky to replace.
dickto
Nov 27, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
Swintec 7040 Typewriter Logo
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
