Question about Vehicle Parts & Accessories
Immobiliser problem wrangler jeep
How do i bypass immobiliser on my 1998 wrangler jeep
    Problem Solver:
  • 13 Answers
Ok well i assume you are trying to install a remote start/alram system. Her is all the info you should need to do so.
1. vehicles with gray keys have immobilizer system installed. If your vehicle is equiped with an immobilizer system a bypass module is required because you have sentry key immobilization. you can find this bypass module at Circuit City or Best Buy. The bypass module part number is 555cw but there is also a unversal module that can probly be used just ask the salesman selling you the module i belive the universal part# is 556uw. Now I will list your wire colors and locations for your vehicle
__________________________________________________________________________________
1. 12 volts - pink/blk - ignition harness
2. starter - yellow - ignition harness
3. ignition - blue - ignition harness
4. accessory - black/orange - ignition harness
5. second accessory - black/green - ignition harness
6. parking lights (+) - black/yellow - headlight switch
7. door trigger (-) - yellow - headlight switch
8. dome light supervision - use door trigger -
9. tachometer - gray - ignition coil
10 speed sense - white/orange - white plug, pin 27 PCM ( the PCM is on the passenger side firewall under the hood )
11. brake wire (+) - white/tan - brake pedal switch
Well thats about it. hope this helps
Luis
Posted on Dec 04, 2008
Need routing diagram for serpentine belt - '98 Jeep Wrangler, straight six with and without A/C
Click of the following direct, Free Link. It has several Serpentine Diagrams, including the one for your 1998 Jeep Wrangler 4.0L In-Line 6-Cylinders based upon your Engine Options (AC/No AC, Power Steering/No Power Steering, etc.).
The Link Page ALSO has the 2.5L In-Line 4-Cylinder Serpentine Belt Diagrams with their various engine options.
Included are the with AC / without AC Routing.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/1998/make/jeep/model/wrangler/1998_jeep_wrangler_drive_belt_routing_diagram.htm
Apr 13, 2010 | 1998 Jeep Wrangler
1987 jeep wrangler has a nutter bypass and runs rich
did you check the air filter? if the air filter is dirty, the mixture is automatic richer than normal. the ratio between air/fuel is changed.
try this ant let us know.
Apr 12, 2010 | 1987 Jeep Wrangler
1998 jeep wrangler starting issues
Hi Dava224 i had the same problem with my 1989 CJ. when it was cold out i would pump the gas pedal 3-4 times before turning the ignition. it puts a small amount of fuel in the motor without stalling it out. it wont start as hard. another good idea is to keep some fuel stabalizer in the tank everytime you fill up. hope this helps
Jun 28, 2009 | 1998 Jeep Wrangler
1998 Jeep Wrangler 2.5 liter motor timing specs?
you could have vacumm problems making it seem like the timing is off, but the other guys are right on the timing!!!! it could be throw-body problems, like crack manifold problems. This year has thhis type of problem sometime. Try spraying WD-40 around the vacuum hoses, & manifold to see if the motor changes rpm????
Feb 09, 2009 | 1998 Jeep Wrangler
Jeep 2006 wrangler x series
yes that fuse is intended to bypass the clutch safety switch indefinitely.If theres a good fuse in there it will bypass and not cause any problem whatsoever..........(you probably already know this ****........)just make sure the transmission is in neutral or you have the clutch pressed down so the jeep doesnt lurch when you turn the key
Nov 23, 2008 | 2006 Jeep Wrangler
1998 jeep wrangler sahara brake, tail and turn signal wont work
Did you go off road in the mud or woods?If so the connecting plug where all the connect probably has gotten disconnected.I think it is near or between the fuel tank and rear bumper.
Aug 30, 2008 | 1998 Jeep Wrangler
1998 Jeep Wrangler
The only time my fuel light comes on in my 95 wrangler is when it is about out of fuel.
Aug 24, 2008 | 1998 Jeep Wrangler
Immobiliser
hi check the fuses in the vechicle and if there ok you would have to see if there is a positive feed at the immobiliser as they are delicate circiuts you may have burned them out best of luck yates210456
Jul 19, 2008 | 1998 Jeep Cherokee
Vehicle Parts & Accessories Logo
1,842 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
