Question about Swintec 7040 Typewriter
I have a brother electric typewriter and the print on the paper is no longer sharpin appearence.I changed ribbon to no effect.Now what?
  • jemoyer12196 Dec 20, 2008
    I thank you for your suggestions.What I found to work after much trying.I took out the daisy wheel and took a fine toothbrush,with alcohol on it and gently brushed the letters off.Made sure they were dry and reinstalled. It worked.The letters are again sharp.
    Scholar:
  • 183 Answers
MAKE SURE RIBBON IS INSTALLED CORRECTLY, SHOULD BE BETWEEN "FINGERS" NEXT TO CARDHOLDER AND CARDHOLDER.
COULD BE A BAD BATCH OF RIBBONS
SOMETIMES CORRECTABLE RIBBON DOESN'T PRINT WELL ON CERTAIN TYPES OF PAPER, SUCH AS "NCR" PAPER, TEXTURED, SLICK OR ANY PAPER THAT HAS BEEN THROUGH A PRINTING PROCESS (FORMS, LETTERHEADS, ETC.)
CHECK RIBBON ITSELF. THE CARBON SHOULD BE A FAIRLY EVEN LAYER. IF THERE ARE BLANK PLACES----
Posted on Dec 20, 2008
My Brother ML 100 typewriter does not print because the film ribbon does not advance while typing. It keeps striking the same spot on the ribbon and therefore, no typing appears on the paper. If I remove...
I've had several of these ribbon cartridges do this. You might get lucky and get it freed up, but I rarely did. Look in the windows of the cartridge and see if the ribbon is not wound evenly...if it isn't you can try gently tapping the cartridge on a flat surface to attempt to even out the ribbon on the spool. If you are not successful, then replace the cartridge. I had mine for almost 10 years and the cartridge was always the problem. Otherwise the typewriter worked flawlessly. Good luck.
Sep 05, 2013 | Brother ML-100 Typewriter
I just replaced the typewriter ribbon my Brother ML-100 typewriter; however, it does not advance properly so typing does not appear on paper. What is the problem?
Take the ribbon off, see if it advances with the hand feed wheel if not you have a bad ribbon. Type without the ribbon and be sure the ribbon driver is turning. There may be a switch or setting for use of an overstrike ribbon,
DickyO
Aug 28, 2013 | Brother ML-100 Typewriter
Brother ce60
Try a milti part form if the carbon prints then you have a ribbon problem. Very old or not lifting/\.
DICKYO
Jul 03, 2013 | Office Equipment & Supplies
Electric typewriter just aquired. Brother CE-70
Go to brotherinternational.com, click on support. Poke around in there you will find a manual for your T/W.
Dickyo
Dec 14, 2010 | Brother EM-430 Typewriter
SX 4000 Brother Electric Typewriter
With power off, remove the ribbon and look down inside the carriage assembly on the right hand side. Look close and you will see a white gear, you rotate that gear, either way about 1/2 a revolution. Power on and try typing, if it works you can put in the ribbon and go, if not, rotate the gear somr more.
Aug 27, 2009 | Brother SX-4000 Typewriter
Typewriter will not print. did the self demo,it went through the motions, but no letters on the paper. the ribbon appears to be new. any ideas what the problem is?
check the ribbon is passing in front of the print head as sometimes the ribbon slips to high or behind also check the correction tape hasnt move in front to block the head hitting the print ribbon
Jul 30, 2009 | Brother SX-4000 Typewriter
Brother CE-70 typewriter. Was typing perfectly well. Over about 15 characters the impact on the print head reduced to nil. Although printhead appears to strike the daisy wheel the character does not strike...
Make sure that the ribbon is moving. If characters are piling up in the same spot on the ribbon you will get this problem. Easiest fix is to replace the ribbon. Many brand new ribbons can have a problem. If this dosent solve the problem it may be a mechanical problem with the mechanism that drives the ribbon, requiring a technician to repair.
Oct 22, 2008 | IBM Wheelwriter 30 Typewriter
No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Jul 09, 2008 | Brother EM-630 Typewriter
Why doesn't my typewriter type when I'm typing
I had this problem once with another brand. One mode actually waits for you to complete an entire line of type before printing it onto the page allowing you to make error corrections without wasting alot of "correction tape". Change the mode back to typing on the fly.
Mar 14, 2008 | Brother SX-4000 Typewriter
Swintec 7040 Typewriter Logo
51 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
