Question about Northgate Athlon XP 400FSB Barebones Upgrade Kit w/ Flash Card Reader (BARENGWFK7S741B) Motherboard
PC will not boot.
Red light is on on the motherboard but the system wont boot at all. Had a virus on it. Do I need new motherboard
  • ostarjasm Feb 07, 2009
    My problem is: I' wont XP program put on the Vista but I don't now how?
    Sergeant:
    Champion:
  • 233 Answers
Go to windows start menu and click on RUN. type in "msconfig'' without quotation marks and click enter. the computer will load the system configuration utility, on the general tab, select normal startup option, then click on the BOOT.INI tab the click on CHECK ALL BOOT PATHS,a dialog box will appear to tell you whether the windows boot directory is OK or not. if it displays that they are Okay, then there may be that a virus has affected those files. you ca also type in "sigverif" without quotation marks, on RUN to launch the windows file verification, click on start to check important windows files for their correct version. try restarting the computer. if your system still can boot, open the computer case to make sure that the hard drive, and RAM are connected correctly. if you still having problems, notify me.
Posted on Dec 03, 2008
Asus p5n-e sli will no longer stay on for more then a few seconds
You go to AVIRA dot com and download the boot tool, or go to BITDEFENDER and run an online scan, you don't put in a new HDD just because you had a virus, it sounds like you had a problem and thought it was a virus.
Read you manual, plug in the Sata drive into Sata 1.
Do you mean BIOS post, if you don't even see the BIOS post, check your monitor with another PC.
There is only one correct power switch pin, a , + and - pin, how can you switch, there is no such thing as switching.
Dec 15, 2012 | ASUS P5N-E SLI Motherboard
Hi, my dell optiplex gx 150 was infected by multiple viruses so i decided to re-install xp booting from cd. after copying all the files from the cd and the pc restarts, its failing to continue installation...
1.You have a corrupted boot sector on your hard drive.
2.you will need to format the drive and then re-install the Operating System.
3. If you are not able to do this then a new hard drive is needed.
4. install a anti virus program after installing the operating system
Feb 08, 2011 | Dell System Board for Optiplex GX 150,...
My laptop wont start up. When I press the on button yellow lights come on and then turn red and then it shuts down.Why?
That would be of the following. There is no Operating system anymore on the hard drive to do a malware virus. Or also the motherboard needs to be replaced. Usually if there is a Orange/yellow light on the board inside, the motherboard needs replaced. Hope that helps you out. First try to reinstall windows from the CD, if doesn't let you boot from the CD ROM (F12) (F2) then it is the motherboard. Hope this helps you
Sep 22, 2010 | Dell Inspiron 1521 Laptop
Cant boot my system
Check all your power cable if they are losened and the memory if is fully inserted
Aug 04, 2009 | ASUS P4SDX Motherboard
Gateway 510x wont fully boot/will auto shut down
it is't a virus, it could be your powersupply is going dead or theres a bad connection with the motherboard and powersupply or memory
Jun 17, 2009 | Gateway Media Center 510X PC Desktop
Motherboard won't boot up
Hey there,
This causes if you havnt connected the power cable coming from th power button to proper jack or pin.
Check out the pin in which ur power button cable is inserted.
Does your system boot when u press the restart or shut down icon from ur windows (OS). If it is not letting ur system to boot then you've been attacked with the Worm viruses. These viruses dont let ur system to boot because they keep their process running untill ur power is off.
Gimme ur acknowladge by rating me.
Thanx.
Romy
Dec 24, 2008 | DFI LANParty UT RDX200 CF-DR Motherboard
Hi please help me with my acer 3003 wont boot
try to power up with power cord only and see if it works. If no lights turn on than your motherboard is dead. If it turns on and nothing happens make sure there is memory installed(RAM). If it turns on and you see windows screen than it shuts off than your operating system needs to be installed again. Also, you can try booting in safe mode by hitting f8 when you initially start your computer and see if it stays on and if it does you have a virus most likely. Good luck.
Aug 18, 2008 | Acer Aspire 3000 Notebook
My system wont boot.. @ once..need many try to make it boot...
Hey there jolen 323. The issue may be related to your power supply failing, however that would be a pain to replace, so lets consider that video idea. If iyou have a video card, remove it and connect your monitor to the onboard video. If this is effective, replace your video card. Next check your motherboard capacitor to ensure you have not popped any. Normally they are flat on top. When they begin to peak or somtimes burst, there is your problem and may also be related to power supply issues, or poor memory configuration. Also ensure your ram is in good condition and the proper type for your board. If using more than 1 stick, try removing the one furthest from the CPU, and give a test start. the only thing left is to replace Power supply if you are confident in the board. Good Luck!
Jan 29, 2008 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Dell xps 400 won't boot
If you have you have changed motherboard with diferent CHIPSET you need to re-install OS!
Another Couses:
1)Virus Problem
2)Program Conflict on STARTUP-Go with safe mode -with admin privilges then go start run TYPE there MSCONFIG and desable all programs ( do not desable antivirus ) AND restart pc!
3)Another hardware error!
Dec 26, 2007 | Computers & Internet
My pc is going insane and so am I!
You need to go back into your manual and take a good look at the pin configuration connected from the Mb to your case. ASUS has a great site to help installing a new board. Check this out: http://support.asus.com/troubleshooting/troubleshooting.aspx?SLanguage=en-us
Click on Motherboards than click on (Trouble shooting PC).
Dec 05, 2007 | ASUS M2V Motherboard
Open Questions:
Losing data is a disaster. Never let that happen Use Cloud Backup'Call +1888784-9316 Cloud storage services are great for sharing files with friends and families, keeping documents in sync between all your devices, and so much more. Free cloud storage is even better! Several backup services offer free online backup plans. DataAlign is known for having the finest free cloud data backup software in the world! Not just being simple and automatic it can be customized to a large extent and not to forget the scheduling capabilities that allows it to run at any time of the day. With several years of experience in its kitty, DataAlign is the trusted innovators in free online backup solution. DataAlign is proud to be known as a market leader in providing Server Cloud Backup Solution based storage and individuals is our primary motto. Our innovative platform has been designed while keeping you in mind. To provide Cloud Backup For Small Business optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Unlike other companies, there are no catch with DataAlign free cloud backup solution. With the kind of experience, you get with DataAlign, we strongly believe that you will eventually upgrade your account to a bigger one. And that makes us give awa Online Backup Pricing accounts as a free version with no strings attached. So drop your worries and and setup your free cloud data backup account with DataAlign. Just to clarify we will not ask for your credit card details upfront when you sign up for a free account. Keep using your free account as long as you need it. DataAlign has been designed with you in mind. You wouldn't require any technical skiil or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
May 28, 2018 | The Computers & Internet
See all Northgate Athlon XP 400FSB Barebones Upgrade Kit Questions
Northgate Athlon XP 400FSB Barebones Upgrade Kit w/ Flash Card Reader (BARENGWFK7S741B) Motherboard Logo
105 people viewed this question
Top Northgate Computers & Internet Experts
Lee Eismann
Tom Chichester
Are you a Northgate Computer and Internet Expert? Answer questions, earn points and help others
