Question about Compaq Presario 5000 PC Desktop
Compaq presairo 5000
Someone threw away the computer away, I took it out of the trash,
the power supply is no good. I thinking about putting a new power supply in. What problems should I look for after i put another power
supply in?
  • Compaq Master
  • 4,806 Answers
The reason that the pc was thrown away is because something went wrong with it, and the owners know nothing about pc's or it would have been too expensive for them to fix. But, saying that you could get it working again!!! when a pc doesn't work its the major components you have to look at, the memory the CPU (processor) the PSU (power supply) or the motherboard, first i would look at the memory, if this goes faulty the pc will not start up and just beep, try a new PSU that may be the main problem and check the above
kind regards and please don't forget to rate us
Posted on Dec 03, 2008
  • 300 Answers
I would suggest checking the motherboard for any burned or blackened spots on the motherboard or any add-on cards that may be present. You should be able to get something on the display as long as you have good power and a good video card. You still run the risk of having a bad hard drive or cd rom.
Hope this helps. Please make sure that you rate this information.
Thanks
Hi i recently found an Akai PT5598HD tv in somebody's trash pile they said that someone had cut the power cord and threw it away. they did not want to deal with the hassle. I took the tv and spliced the...
On the power supply board is a tyrisitor and high voltage capacitors 2k most of the time Poor Solder Connection right where AC line connects,you will see it on that board.
Resolder everything and set should come on.
Oct 19, 2010 | Akai PT5598HD 55" Rear Projection...
Power light comes on but nothing appears on monitor
Mostly your heatsink damaged your motherboaard. check caps lock LED and Number Lock LED are working after switching on. If not ur motherboard or processor get damaged and u had mentioned what happened. Ur heatsink shorts some circuit in  your motherboard
Apr 06, 2009 | Compaq Presario 5000 PC Desktop
Computer will never turn on
Odds are good your computer is quite dirty on the inside. If you have never opened the computer I suggest you simply buy a new one, to save time and frustration.
But since you are here, this is what to look for:
Dirty inside - Open the computer and blow all the dust out. Use DRY air.
Power supply - if you have power but no lights on your motherboard anywhere, check your computer's power supply. This may mean removing it and testing in a different computer or using a multi-meter and something to turn it on.
Power switch - Perhaps your switch is simply worn out. Open the computer and follow the wires from the button to the motherboard. Remove the connection and short those two pins for a moment. If your switch is bad, your computer should now be booting up.
Hard drive failure - If you mean will not boot when you say "will never turn on" your hard drive may have failed. If this is the case you can simply replace the hard drive. BUT, you will have to re-install all of your programs AND your operating system. Better to simply buy a new computer if that is the case, unless you have all of your original disks and a fast internet connection.
Mar 06, 2009 | Compaq Presario 7470 (163881-004) PC...
Compaq presairo R3000 driver
You can go to this site and pick your computer out of the list. There are too many R3000 to chose from and you have the information to select the one you need
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom〈=en&h_client=S-A-R163-1&h_pagetype=s-001&h_query=R3000+&submit.x=0&submit.y=0
Hope this is what you were looking for and please don't forget to rate the solution
Jan 12, 2009 | Compaq Presario R3000 Notebook
Compaq nx5000 - will not power up. DIsk spins, green lights for a second , then powers down to only yellow light. SOmetimes - seems after long periods of no use - -powers up and runs. Have sourced new...
I just got my nx5000 up and running again. The memory needed to be reseated in the socket (got this tip of the HP site) All I did was open it up and reseat the ram - just took it out and put it back in again. Problem solved. I also took the opportunity to vacuum a little bit of dust out, but I don't think this was anything to do with the problem.
Get a copy of the service manual (Just google "hp service manual nx5000") it has easy instructions at how to get to the memory - it is just under the keyboard.
Hope this helps!
Dec 10, 2008 | HP Compaq nx5000 Notebook
Compaq 2500 power problem
The price you will pay isn't practical to just going out and replace the whole computer,you'll be alot better off financially.
Apr 07, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Latitude C640 is dead!!
The only solution that I can think of would be a power jack problem. I would not advise replacing the power jack yourself since you have to take out the laptop mother board, de-solder the power jack then solder the new one on and put it back together. My advice would be to take it to a professional computer repair shop and have them take a look at it and replace the power jack. It is worth getting repaired since power jacks usually range $40-$70.
Feb 20, 2008 | Compaq Presario 1200XL104 Notebook
Compaq tft 5000 out of work
Your backlight probably went out and needs replaced.
Jun 18, 2007 | Compaq TFT5000 15" LCD Monitor
Compaq Presario 5000 PC Desktop Logo
23 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
