Question about Ahead Software Nero 6 Ultra Edition (2434nl20) for PC
I have Nero 7 ultra edition. when I open the nero program it goes into safe mode that wont allow me to make copies of anything.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Sounds like the demo version, am i correct?
Instolation free
Posted on Dec 11, 2008
Nero 7 essentials-serial number and organization
1C80-E086-015A-0000-4001-A109-92X7
1C80-0000-19E5-MA2X-4006-3632-3745
1C80-0000-19E5-MA2X-4001-3140-7597
heyy guys guess what ive got my serial number of nero 7 ultra edition.here it is for all of you free
note down
serial number:1234567890
Serial key for: Nero 7
nero ultra 1C82-0000-19E5-MAAX-4006-3722-9426 nero premium 1C80-0000-19E5-MA2X-4002-4146-4458 nero essentials 5C89-0000-1911-0000-4007-5457-1666
Serial key for: nero 7 essentials
4C87-202M-3005-E11K-0XXX-C660-0900-403E-953E-9M40
try some of these
hope it helps
Jan 04, 2012 | Computers & Internet
Tip
Nero 7 Ultra Advance-to-Time Index Problem Work-around
Posted under Nero 6 Ultra because there is no Nero 7 Ultra listing here on Fixya...
OK, I am going to tell you how I managed to work around this problem. I am posting this in the hopes it will save someone else the aggravation I had in stumbling around trying to find a procedure that would fix the problem. I found a work-around I can live with, so here's the problem and the solution follows. If it applies to you, I hope it makes your DVD-burning life livable again! Oh yeah, looks like Nero 8 is ready to come out soon. Just when you though it was safe.... anyway, here goes:
The Problem:
Burning DVDs using Nero 6.2 on Win ME was successful, and it allowed for advancing via time index. For example, I would burn a DVD and be able to go to any time point in the scene. However using Vista and Nero 7 Ultra, while DVDs burn successfully, the advance-by-time index is no longer available in DVDs burned under Vista with Nero 7. Details:
DVD burner: Buslink DBW1647-U2
O/S: Vista Home Basic
S/w: Nero, Ver. 7 Ultra, registered
DVD media: 16X Starlogic DVD-R
DVD player: Goldstar VM681M
The scenario is this:
1. Begin playing a chapter on the DVD
2. Click the chapter menu button on the remote.
3. Use up-down arrow keys on remote to try to get to timed index setting (ie, the one where if you select it and type "10:00" it will jump the scene to the 10:00 mark).
4. Can't select that option.
The Work-around:
1. Open Nero Vision and choose to create a DVD.
2. Access the Options by clicking More>> and make sure Nero SmartEncode is set to 'Disabled'. I think since Nero wants to convert everything to MPEG-4 that that might be a factor. Also, you may need to get some codecs, too. I am using the K-lite full pack available here: http://www.digital-digest.com/software/k-lite_codec_pack.html (Note that K-lite doesn't like other codec packs being on the same PC as it-- it nagged me to uninstall the DivX and Vista Codec Packs, and I did. I have discovered no problems so far since.)
3. Add your video files and step through the rest of the process. Settings to look out for: Automatically create chapters: NOT checked, Enable Forward/Backward Jumping: checked.
4. On the last screen, choose to Write to Disk instead of burning to the CD drive-- select a place to save the DVD-compatible files. Click "Burn" and off you go.
5. After your DVD files are written to disk (they will be in a folder called TS_VIDEO in the place you chose to save them to), fire up a copy of ImgBurn (http://www.imgburn.com/). [Maybe Nero's image burner will work too, I just haven't tried it. In any case this is known to work so I am using it here.]
6. Switch Mode to Build -- you need to build an .iso image file in order to burn it to DVD -- and select the TS_VIDEO folder holding your Nero-ed files. Indicate a name for the output file and run it. This should not take nearly as long as Nero took in creating the raw DVD files. The .iso file you created will be close to the same size as the raw DVD files are in the TS_VIDEO folder Nero created.
7. Now switch mode to Write and indicate the .iso file you built as the input and select the target DVD drive you are using, then run it. The burn process should not take long, either, compared with the other steps.
8. Test it in your DVD player-- you should be able to jump to time indexes now.
I have no idea why this works as opposed to the transcode-then-burn process that worked for me under Nero 6.2. There may well be other ways to deal with this problem, I just don't know what they are. Downside to this approach of course is that you need about 33% more disk space as compared with that required for transcode-and-burn (t-and-b: need space for the original files and Nero temp files; the .iso approach: need space for the original files, the DVD-compatible files Nero creates, and the .iso file created from that). However this is an alternate procedure, not a fix, and the only approach so far I have found.
Plenty of good DVD discs gave their lives to discover this process. I hope I can save you some misery and trips to the store for more blank DVDs by posting it here.
on Feb 22, 2008 | Ahead Software Nero 6 Ultra Edition...
What a serial number for nero 6-6-0-13?
Its the number you need to activate the program..
Thats what it is.......
If however you are asking for a FREE...UNPAID FOR...CRACKED copy of nero.........
AT YOUR OWN RISK..http://thepiratebay.org/search/nero/0/99/0
Jul 16, 2010 | Ahead Software Nero Ultra Edition 6
I need a serial number for Nero Express? How can I find it?
nero 7 ultra
nero 7 premium
nero 7 essentials
Nero 7 ultra trail
1C83-7221-10E5-477X-405C-3740-9040
Nero 9 5.5.9.0
1506-1772-1062-4779-2865-6371
Nero 9.4.13.2 installation code
8M01-209M-AH6P-5UW0-WHAW-C53X-473X-79MH
nero 8 ultra edition
1K22-0867-0795-66M4-5026-0145-C7A5
Jun 01, 2010 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Cant get nero 7 ultra edition to delete of my pc
Try this open the icon my pc then click on add or erase programs now select the nero and click in the icon eliminate.Good luck
Nov 05, 2008 | Computers & Internet
System restarts after installing Nero 8 ansd above version
hi!!!
may there is a bug in your OS
try to install
roxio or other burning software
Nov 05, 2008 | Microsoft Windows XP Professional
Nero 7 serial
I have here the serials hope this works!
Company: www.serials.ws Nero 7 Premium Serial: 5C80001080000000002666685258 OR Company: www.serials.ws Nero 7 Ultra Edition Serial: 4C82-0010-8011-0000-9933-9670-5722
only for nero 7
Have a nice day.
Sep 19, 2008 | Ahead Software Nero 6 Ultra Edition...
Nero 8 Ultra Edition
vista has many compatibility issues... did u install nero using run as administrator option coz if u haven't done so then many of the required dlls would nt have been installed....
Mar 01, 2008 | Computers & Internet
Installation
Well, U can click on a Button that allows u to still use the software, try this, right click on the nero ultra edition short cut, and RUN AS ADMINISTRATOR, and allow the program to run, and maybe next time u open nero it wont ask for that again : )
Feb 08, 2008 | Ahead Software Nero Ultra Edition 6 for PC
Ahead Software Nero 6 Ultra Edition (2434nl20) for PC Logo
Top Ahead Software Computers & Internet Experts
celos
lemesee
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
