Question about Teac AG-H550 Receiver
Connecting H550 Receiver to new HD Ready tv correctly
Can anyone advise what the correct way to set up the H550 with my newly acquired Sony KDL 32L4000 LCD for the various inputs, please?
Previously I had Virgin digibox connected by SCART to 3 a/v jacks, oldish Mitsubishi VCR (only has SCART output) by SCART to 6 a/v jacks, and TEAC DVD by optical feed. Old crt tv was connected by jack from TEAC 'monitor out' and everything worked fine.
New LCD tv has two HDMI ( no use as TEAC doesn't have this capability), two SCART inputs (AV1: stated as outputs available only for analogue tv, AV2 stated as outputs to the current screen - except PC, HDMI 1,2,Component 1080i) whatever that lot means!, Component In (Y/PbCb/PrCr) and AV3 (video, audio L, audio R phono jacks).
Is it possible to connect just the yellow video phono jack of a 3 jack/SCART cable to one of the tv's SCARTS, or will the AV3 video jack on the new tv be the only way to connect to the TEAC 'monitor out' jack?
Any helpful replies appreciated.
Thanks
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: I would like to run my TV sound out of my TEAC
Yes, and if you have a cable/sat/dvr box why don't you just run ITs best TV-related audio into the receiver without watering it down through your TV?
I'm not so sure that running the TV video through anything else serves any purpose. Once TV has it where else do you need it?
Posted on May 01, 2010
Testimonial: "Thanks for the tip. Works great."
dunnbiker
  • 8546 Answers
SOURCE: I have a teac crl600
It is an output. No digital inputs.
Posted on Aug 18, 2010
Connect tv audio input output receiver
Just make sure that you are using cables that are configured correctly physically and check to make sure that you are using the correct analog or digital signal necessary. Your audio settings need to be checked out and set accordingly. Check directions carefully.
Sep 03, 2017 | Sony DAV-DZ100 System
I have a Sony Bravia kdl-32s2020 LCD with MPEG-2 DBV-T. Are there any possibility to upgrade them to DVB-C MPEG-4. This model is also HD-ready. Haw can convert them to FULL-HD (changing SD receiver with...
This tv have the capabillity for the Full HD max resolution 1080i or 1080p.The problems u have is not the tv capabilities.The tv incomming broadcasting signals are vary like DTV,SD,480i,720i low end HD.Max HD resolutions are 1080p or 1080i.
Dec 01, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Connecting speakers.
The speakers cannot be connected directly to the audio outputs. These outputs are for use with an external amplifier. Connecting speakers directly to these audio outputs can cause damage to the set. Thanks
Oct 24, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
I have connected my Charter HDTV settop box to the strdh700 in the 'sat in' hdmi connection, then connected the 'out' hdmi to my sony bravia tv and the signal isn't getting there. any suggestions?
If you're not getting the audio signal, please select the Audio for HDMI to TV+AMP in Menu display. If you're not getting the videos, please check if the TV is HD ready and supports 1080p signals. Also check if the connections are firm and secure and you selected the correct input on both Receiver and TV. Please try connect the Settop box to different HDMI port of the receiver and try. You can also try connecting the Set top box to tv directly and check if its working. If its working fine directly with the TV, you may try to replace the cable and try else the receiver may require service
Sep 22, 2009 | Sony STR-DH700 A/V Receiver
No digital picture for Sony KDL-40v2500
These tv's receive digital on the atsc 8vsb. Do you know what there broadcasting in New Zealand ? It could be that a Sony tech there can fix your problem. The TV can be set-up for a different digital broadcast and Sony is all over the world even in New Zealand .
May 04, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Connecting sony bravia to direct tv
select the correct scart socket used go though the av channels until you find the correct input[scart]
Apr 30, 2009 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Can't play audio CDs without having the TV on
Your description is not entirely clear, so I have to guess a little here, but I think what is happening is as follows:
1) You are using your DVD player as the source for the CD.
2) Your DVD is connected directly to the TV and the TV then connected to your receiver.
If the above are correct, then the problem is that the TV only has what is called an ACTIVE passthru for Audio signals. This means that the signal is process by the TV and tehn sent to the audio output jacks. With the TV off, the buffer ICs are not functioning, thus no output. Some older sets have what is called PASSIVE passthru.
I don't know your specific DVD model specs, so check to see if you have 2 audio outputs from the DVD (many do) and connect the other audio out directly to the receiver. That will resolve your problem.
Dan
Mar 20, 2009 | Sony Bravia KDL-32V4000 32 in. LCD TV
Sony bravia kdl-46v2500
TRY A DVD PLAYER TO VERIFY IF IT COULD BE THE SAT.BOX OR MAYBE TV COLOR ADJUSTMENTS.JOE TV
Dec 30, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Teac AG-H550 Receiver Logo
88 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
