Question about Garmin StreetPilot C330 GPS Receiver
PC can't communicate with GPS unit for initial map load
Repeated tries to load maps on new unit get problem message re communicating with PC (Compaq Presario). Garmin help desk sent email telling me to be sure I'm plugged into a USB on rear of PC (I am), then sent email telling me to check my chip set. When I look at USB controllers in device manager it just lists "standard enhanced PCI to USB host contoller" and "standard open HCD USB host controller", no brand name of chip set. Garmin's email said I may need to buy a new chip set (I don't even know what that is), e.g. Syba NEC & install in my PC. Any suggestions will be appreciated. Thank you!
    Problem Solver:
  • 4 Answers
It will NOT show up under USB controllers. It should appear as "GARMIN Devices" in your device manager. Mine is right under Floppy disk drives. Do other USB devices 'bong' up when connected and 'bong' down when taken off? Of course you have to have your audio on for that. The GPS should 'sound' just like any other USB device when attached or taken off. I find that GARMIN help is of no use. Forums like this have helped me far more.
Posted on Mar 03, 2007
SOURCE:
How do I program my garmin
Your Garmin should have maps factory installed that load when you turn it on. If you want to update the maps you can 1) take the unit to a Garmin dealer to get updated maps or 2) Connect your unit to PC or laptop with internet through a usb cable and go online to Garmin.com. You must install a small program in the computer- Garmin Communicator - so your unit can communicate with the website. Go to Map Updates and download the update into your gps. You can update one time each year. Hope this helps.
Oct 17, 2014 | Garmin nuvi 52LM Essential Series 5" GPS...
Garmin nuvi 1450 problems
You need to download a Garmin tool called "Garmin Express" to load the map software off the Garmin site.
May 19, 2017 | GPS
When you turn the unit on a message comes onto the screen that says. UNIT CURRENTLY CONTAINS NO MAP! INITIATING MAP UPLOAD. you cant do anything with the unit message stays on the screen.
when you turn the unit on a message comes onto the screen that says:
May 01, 2011 | Magellan eXplorist 400 GPS Receiver
I purchased the new maps for my Garmin Nuvi 660. Before trying to install the disk, I first tried to update my firmware. After opening the download, the install program could not find my unit. The same...
Most likely the firmware is corrupted and not allowing your unit to get to the communication routines that allow it to talk to your PC.
Please see this link: Your map & firmware issue can be resolved there.
http://www.sharc.net/gps_repair.htm
- Jim
Nov 30, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin 405 - cant unlock maps
Step 1: Get "garmin_keygen_v1.5.exe" 2008 by JetMouse
Step 2: Follow the bottom instructions...
11) Go to "Utilities-Get Unit ID" and Find Device with your GPS plugged in USB. Write down Unit ID.
12) Run Garmin Unlock Utility, Enter that Unit ID at the top.
13) Select under "Select Map Product"
14) Enter the type of map you're using or if you have the Map ID enter in a custom map, use the Generate button to get 25char code.
15) In MapSource go to "Utilities-Manage Map Products"
16) Go to "Unlock Regions" Tab, and hit "Add...", enter 25char code, comment optional
17) Now on the main MapSource screen, type 'm' to enable map tool.
18) You should see a large white rectangle, with rectangle outlines (these represent NA maps)
19) Click and drag to select them all, you can click "Map Set Name" if wanted.
20) Click the "Send to Device" button. Wait an hour. Enjoy.
Mar 09, 2009 | Garmin StreetPilot C330 GPS Receiver
2009 map update not loading
Fixed. Called Garmin. It seems that version 4.90 FW on the Nuvi 350 (which came shipped on my 350) has a bug where it cannot communicate with the Garmin software either to update maps or update FW. Tech from Garmin e-mailed me a patch that I copied into the Garmin folder on the Nuvi itself, via USB and Windows Explorer. I then rebooted it; the patch installed itself which then allowed the unit to communicate with the map upgrade software and all is well. 2009 map update is now installed and the Nuvi is working fine again. Haven't tried upgrading to newer FW yet; will probably leave well enough alone.
Jul 01, 2008 | Garmin Nuvi 660 GPS Receiver
Does it recognise the Nuvi? Are you connecting it through a usb Hub. Are the drivers for the nuvi installed properly? Usually there is a folder named USB, thats where the correct drivers reside, and that's where you tell the computer to look when it asks for the drivers.
May 18, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Streetpilot i3 GPS cannot load map to memory card
A way around this is to insert the SD Card into the computer (SD Card reader), point the directory to the card and install the maps like that. I had to do that the first time I bought my unit because I couldn't figure it out and got frustrated. So I thought of this easy work-around.
Dec 22, 2007 | Garmin iQue 3600 GPS Receiver
Map update gone bad
Connect it to a PC and delete the map(s) using windows explorer.
Oct 20, 2007 | Garmin StreetPilot 2620 GPS Receiver
Cannot load map in my Garmin Streetpilot i3 GPS
i dont think you can upload maps to an i3, it can only load pre-loaded maps on micro-sd cards.
Sep 22, 2007 | Garmin StreetPilot i3 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
123 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
