Question about Motorola Mobility RAZR V3
How to charge my moto by connecting to laptop
I have a power cable to charge the moto. But, it's not getting charget from the laptop.
But, it's working fine for my colleague.
  • 492 Answers
Install Motorola phone tools. For the cpu on your computer to send power to the phone it must reconize it as a device that it is communicating with. www.motorola.com should be able to provide you information on phone tools.
Posted on Dec 03, 2008
Power wont stay on
Please elaborate on this issue. Under what circumstances does the power stay on? When the power cable is connected or when on battery? If it is powering off as soon as you remove the power cable, then the issue is your battery doesn't hold a charge. If the laptop dies with the battery and power cable connected then it might be getting just enough charge from the battery to power on for a moment and then it runs out of "juice" again. That is normally caused by a bad DC jack (The part in the laptop that the power cable plugs into). Test the end of the power cable with a multi-meter to make sure you are getting the correct voltage listed on the power brick (the box in the middle of the power cable). Let me know your results.
Matt
Mar 09, 2014 | HP Compaq Presario CQ70-120US Laptop
Moto roker e6 charging jumperdiagram
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 28, 2012 | Motorola Mobility MOTOROKR E6
Even if i connected the charger its not charging
First Option:
Second Option:
Jan 03, 2011 | Nokia 7610
I replaced the battery in my car and it still wont turn over. I tried giving it a jump it started and as soon as pulled the cables off it shut off and wont start again what could be the problem
you fitted a flat battery on your car,,,,,thats why it sarted with a jump battery fitted to it,,,,hook up the jump battery again ,,start the car and leave the jump battery hooked up,,,so the car can charge up both batterys,,,till yours has power in it,,,,better still hook up a car battery charget to your car and leavi it on charge for a fuw days,,,
Nov 28, 2010 | 2000 Mitsubishi Galant
Not charging
First Option:
Secend Option:
Aug 17, 2010 | Motorola Mobility MOTO U9 Pink Cellular...
Not charging
either have bad battery or the plug in connection is loose or bad.
Oct 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Moto q want trun on
Try taking the batteries out ( fully disconnecting them from the gold contact points) ... then put them back in with the charger already plugged in. It should go to that blue charge screen instead of turning on. LEAVE IT ON THAT CHARGING SCREEN for at least 5-10 mins. Now, Hold down power, screen goes black... then tap power about 2 seconds after screen goes out, and it should start up as normal. If taking the battery out has no effect, I would investigate whether that (the battery... being dead/unchargeable) is the problem. I'm hoping one of the two answers gets ya where you need to go.
OH AND YOU CANNOT USE USB CHARGER TO DO THIS. IT HAS TO HAVE DIRECT FROM-THE-SOCKET POWER TO CHARGE UP THAT FIRST BIT OF COMPLETELY TAPPED CHEMICAL (ELECTRICAL) REACTIONS.
Jul 31, 2008 | Motorola Mobility Moto Q
Battery will not charge
You can purchase a battery charget for your specific battery from wal-mart for about 49.00. If you charge you battery and it still does not work, and another battery of the same type doesnot work, then your problem might lie in the camera itself. unfortunately I am having problems getting mine to charge as well.
Dec 26, 2007 | JVC GR D370US camcorder Mini DV
Motorola Mobility RAZR V3 Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
