Question about Ricoh Aficio 2018D All-In-One Laser Printer
Copier restart issue
Hello...problem: an afico 1085 is restarting during copying. WHY? where is the problem! I have pluged it to another location but problem persist. please advise!
  • 162 Answers
If it observes spilled developer, it disassembles all the units of feeding of paper in the inferior zone of the develop unit and cleans them, the developer in the sensors can cause blockades in the power supply.
Can have some defective solder in the power supply.
Inspect the power supply board.
The switch of the frontal door also can produce problems the great replace to clean does not serve them.
Inspect cables and connectors in the fusor in those of the lamps.
Posted on Sep 10, 2009
  • 16 Answers
If the copier is shuting down and restarting while copying it sounds like it is over heating.you need to check that the fan at the fuser unit is working.check the rest of the fans aswell..lets know how you get on
Posted on Apr 30, 2009
False jam
Please try the below steps ..
  1. While the printer is ON, disconnect the power cord from the printer.
  2. Restart the PC
  3. Wait for 30 seconds.
  4. Plug in the power cord to the printer.
  5. Now try printing, it should work.
If issue still exists, uninstall the printer software, restart the PC and then re-install the printer software.
Aug 14, 2014 | HP Officejet 4620 e-All-in-One Printer,...
Alienware x51 random restarts [solved: Dell had the audacity to supply the need with an underpowered PSU for the GPU they offered]
Hello Wiryan =)
Sounds like either a power supply or graphics card issue to me. You could try downloading Almico's speedfan to check your temperatures just to be sure that they are fine.
You should contact Dell, they can probably troubleshoot the issue pretty fast/send a technician to you. The X51 randomly shutting down is a common issue if you check the forums over there. http://en.community.dell.com/owners-club/alienware/f/3746/t/19437557.aspx?PageIndex=1
I assume you have updated every driver to the latest?
Hope this helps! :)
Aug 07, 2013 | Dell Alienware X51 Desktop PC | Core i7 |...
Hp 2210xi printer will print from computer, but not print a copy placed on the glass. machine acts like it's printing, but page comes out blank and no error message.
Try restating your computer, uninstall the printer software, restart your computer, install printer software again, and restart computer again. (leave the printer off during this process unless told otherwise by the on-screen instructions).
If the above doesn't work, then it could be a hardware issue with the scanner. Try scanning a document to your computer and see if that works. If it doesn't, then your device probably needs a hardware repair...hopefully something is just loose in there.
Hope that helps!
Mar 28, 2011 | HP PSC 2210 All-In-One InkJet Printer
Drum is black afico 450
You need a new drum CLEANING BLADE
Sep 06, 2009 | Ricoh Aficio 450 Copier
I need driver for HP PSC 1300 series
Click on the below link and enter the product type and download the drivers which is compatible wiht your Operating system.
http://welcome.hp.com/country/us/en/support.html
Thank you.
Sep 12, 2008 | HP PSC 1350 All-In-One Thermal Printer
Hello MR dricha
If the developer has been changed.  You need to go into service mode to calibrate it before you print.  If you don't run the program and you make copies, copy quality will change and you may have to replace the developer again.
Once it is replaced go into service mode and issue the service code to calibrate the developer.
If you haven't replaced the developer yet, you should.
Sep 12, 2008 | Office Equipment & Supplies
Cannot access scan function
Hi , did you try a manual copy thru the printer operator panel to make sure that there are no issues with the hardware , if it is copying manually then its an issue with the software , you need to uninstall the printer drivers through the Printer Disk ****make sure to disconnect the printer cable from the computer before uninstalling the drivers **** once the printer drivers are uninstalled restart the computer and get into the Safemode (**keep tabbing F8 when the system restarts for safemode**) and delete the following Folder " SPOOL " it is located under C:\WINDOWS\system32. after deleting the Spool folder restart the computer and install a fresh copy of drivers it will resolve your issue.
Do let me know once you perfrom these steps.
All the Best.
Jul 10, 2008 | Dell 922 All-In-One InkJet Printer
Error messae appearin as soon as I turn it on
Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
If these steps did not resolve the issue, contact HP technical support for assistance
Nov 15, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Ricoh Aficio 2018D All-In-One Laser Printer Logo
90 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
