Question about Toshiba P25-S676 Notebook
Display problem there was charging problem with my lap top i was busy doing work on it n the batt was getting low so i got angry n tried to open the lap top i opened 4 screws including the 2 inches but i was not able to open the lap top after 5mins i fixed the screws thinking to give it to some engineer to change the charging pin but as i started the lap top after fixing the screws back to there position there were straight lines on the screen n when i move the cursor on the lines there is yellow lines coming on tht lines i dint used and pressure or tried forcibly to open the screws it was all very smooth n it is a TOSHIBA SATELLITE P25-S676
  • 37 Answers
The best thing to do is to get the help of a qualified technician(better go to a toshiba service centre)
they will help you with this.
try removing the battery after turning off the computer and removing the power supply.reinsert the battery and turn on th notebook. it should work fine.
else contact the technician.
Posted on Dec 03, 2008
Metal detector 3110 ll stop detecting any small metals and is 15 days old, what can be the problem? Is like it lost 99% of the sensitivity in 2 weeks, with new Alkaline Batt,& I been very careful!
metal detectors are ******* batteries especially alkaline type so check the charge in the batteries with a voltmeter
if they are still at correct voltage , take it back for a warranty check or replacement
Aug 06, 2017 | Sport & Outdoor - Others
I have had my lap top in 3 different shops and been told all 3 times that the proublems I have are with my server!!!!!! I have used yahoo for many many years and NEVER HAD A PROUBLEM UNTIL I got this lap...
Thinks to try:
Try a different browser on your laptop.
Try your laptop in a different location(different high speed connection like coffee shop or libarary)
Try your accont on a different computer
Mar 01, 2011 | Computers & Internet
When I push the power button to power the lap top up the light display that says outlet power changes from green to amber and the laptop will not power up.
try removing the battery and just use plug power only if it boots normally then change the battery and the change the power supply unit as well I would just start with the power supply unit first then see if the battery charges up if not the battery is bad replace it. Now if the computer will not start with the battery removed then you have a power supply issue.
Change and replace it. Hope this helps. Also when computer lap top get hot they will shut down to protect the computer wait and let it cool down then try to restart your computer. If this does work and the lap top restarts normally get a fan cooler that is USB powered and the lap top sits on top of it. Also make sure the fan is running and is not stopped. Clean and dust it out once in awhile. I hope this assists you with your problem. John
Jan 22, 2011 | Toshiba Satellite Pro 6100 Notebook
Problem with Vista Business finding my HP all in one printer
your problem is that your missing drivers thats why its not seeing it. you can get the drivers from here if you donot have a disk with the needed drivers
Nov 11, 2009 | HP PSC 1210 All-In-One InkJet Printer
Blue screen with HP Logo is frozen on my lap top screen
try contrl alt del at same time hold for 5 sec if that does not work take batt out hope this helps
Oct 16, 2009 | HP Pavilion dv9000z Notebook
WORKING BUT WITH NO DISPLAY
It is very likely that the batteries need charging, tip, charge them in a separate charger, if the batts are low, the scanner asks for confirmation to charge them (it is not automatic) and with no display you won't see this message and will forever keep trying to charge them without confirming "yes" for the scanner to do it!!.
May 18, 2009 | Icom IC-R5 Handheld Scanner
How to reprogram a nokia 6680?
Dear customer,                  You can try *#7370# and *#7780# for resetting or formatting your mobile. Also the "Restore factory setting" will help too. Thank you.
May 02, 2009 | Nokia 6680 Handheld
Compaq presario c300 stuck in hibernation mode...won't recover or start up at all.
take out battery or unplug from wall open cpu or lap top and remove the inner memory batt. this will kill the last mode it remembers thats why its stuck. leave out for 2-4 hrs for best results. min 1hr and a half
Mar 14, 2009 | HP 435768-001 - Compaq Presario C300...
Toshiba P25-S676 Notebook Logo
187 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
