Question about Metabo BSP15.6PLUS 15.6 Volt Cordless Drill / Screwdriver BSP15.6 Plus
When you push the trigger turning on the drill it pulsates.
There is no hammer head setting so it should not be doing this. The settings are just screw and drill.
Metabo 15.6 bst plus
Thank you
  • David Ford
    David Ford May 11, 2010
    Exactly what is it doing? The header is not that specific. Let me know and I will try and help
  • 3 Answers
The tool has an 'impuls' function that is very handy for starting bits into hard metal with out walking, or driving or removing screws with damaged heads. The pulse allows the drill bit to penetrate the metal and the screw driver bit to find its' best seat in the screw head.
There is a switch on the rear of the tool. Flip the switch one way to turn on the impuls feature, the other way to turn it off!
Posted on Jun 09, 2009
Drill not running at correct speed
Check for a speed lever on the case that changes the gear ratio from high to low speed There is a button in the front of the trigger and it limits the amount of pull you can give the trigger which controls the resistor setting in the trigger switch. Turning this will alter the speed when you pull the trigger
Nov 03, 2012 | Dewalt DW005K Rotary Hammer
Good battery but drill won't run
Push the battery in and out while pressing the trigger on the the drill to see if there is a loose connection here.
Check the terminals inside the drill and the battery terminals .These sometimes become tarnished and don't make contact. Clean with very fine sandpaper.
Jun 09, 2011 | Dewalt DC925KA Factory Reconditioned...
I bought a draper 500w hammer drill. instructions are not straight forward. I don't know how to get started with it. Do I have to plug it in first and how do I start drilling? C
Plug it in ... insert a drill ... tighten the chuck (the thing you put the drill into) ... pull the trigger ... drill the hole.
There should be a collar around the chuck that will select hammer or no hammer --- or there may be a pin to pull near the chuck. There may also ge a clutch on the collar. Play with it so to say, it will soon be self evident how it works.
The only time you will use the HAMMER setting is when you are drilling with a SPECIAL CARBIDE TIP drill into CONCRETE or other non wood - non metal - conctete or clay product (brick).
Jun 01, 2011 | Vacuums
The drill starts and stops while I hold the trigger. Like its just missing, then it wont run. How can I fix this?
I suggest that you check the brushes, and the armature. Worn out brushes sometimes cause that condition.
Also, try different trigger settings, to eliminate that as an issue.
May 01, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
When i drill with my 18volt cordless, and the bit catches it makes an awful grinding noise inside the drill, its not the adjustable clutch set low. its set on drill?
Your speed switch is between gears, pull the trigger lightly and slide the speed switch back and fourth until it is fully engaged. Also turn the clutch setting all the way down then all the way back to lock it is not uncommon for them to get dodgy.
Cheers,
Kevin
Mar 23, 2010 | Dewalt DC6PAKRA Heavy Duty Xrp 18volt...
Dewalt drill. I have a stuck chuck.
Hi there.
spray some oil into it and tap it lightly with a small hammer. Then hold the chuck and gently squeese the trigger in forward setting and backward setting. Do not use full force on backward setting.
This should do the trick.
Iceman.
Nov 10, 2009 | Dewalt Drills
Got a cordless18v dewalt drill that wont go onto its hammer setting
Try pressing the trigger at the same time as turning the selector collar. If you still can't get it to turn try using an air nozzle to really blow everything really clean.
Oct 14, 2009 | Dewalt Drills
Hammer drill quit
If it is an 1199, forget it. Replace the brushes and do NOT use for hammering. It is a design problem. My unit was repaired 4 times and hammered about 5 holes each time before same failure.
Jul 02, 2009 | Bosch 1617014127 Brush Set For 11224vsr
No power
Check the Cable between the plug and the switch for continuity using the ohmeter or continuity tester part of a cheap multimeter. Place one lead on each of the plug contacts in turn, and the other on the other end of that wire. If this is okay, check the switch for continuity by placing each lead of your tester on the in and out contacts and pressing the trigger. If still no joy, check the brushes. If still no joy, check the motor windings for continuity.
Jun 15, 2009 | Bosch HCBG500, 5 Pc Industrial Hammer...
Cannot engage hammer action
the problem is the metal part of the clutch that meets the pin from the transmission. remove the 4 screw from the clutch & check if the the inside of the clutch & the trans pin meets. all you can do is to push back the metal parts of the clutch setting.
Jun 07, 2008 | Dewalt 18 Volt Compact Drill Kit
Metabo BSP15.6PLUS 15.6 Volt Cordless Drill / Screwdriver BSP15.6 Plus Logo
196 people viewed this question
Top Metabo Drills Experts
Colin Stickland
Colin Stickland
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Metabo Drill Expert? Answer questions, earn points and help others
