Question about GE (PSS26MSRSS) Side by Side Refrigerator
The drain panel is not opening
On the ge side by side fridge: i have melted the ice and cleaned the bottom out. i have noticed a panel which is held by a nut on the back wall inside the freezer: i think that is the drain pipe and i need to flush that: but how do i open it? tired all the tools from the tool box: but it is so small and there is no way to get to it!
    Scholar:
  • 82 Answers
Hello. This isn't making any sense. Usually the screw is a 1/4 socket. Most appliances use 1/4 inch and 5/16 inch sockets. Did you try these sizes? Maybe they decided to throw in a metric screw. This is rare though and usaully happens when another tech works on it looses your screw and puts in what ever is in his bag.
You are correct in guessing that the drain is behind this panel. It could be clogged or you may need a new defrost thermostat. When the defrost thermostat goes out it can cause the defrost cycle to terminate prematurely, thus allowing the moisture to freeze up before it has a chance to drain all of the way. Hopefully this will help.
Posted on Dec 03, 2008
  • 333 Answers
You might be able to **** the water out of the drain tube from the bottom of the tube. gain access by the drip pan at the bottom. t is easier to **** it out than to flush it as they tend to clog.
Where is the reset on my refidgerator wont get cold enough kid left it open
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
May 09, 2012 | Hotpoint-Ariston HSS25GFT Side by Side...
Ice buildup under bottom drawer in fridge, leads upward on left side to a vent...and the freezer also gets an ice build up coming from the icemaker. also icecream popsicles etc are not staying frozen. any...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 23, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator collecting water under veggie bins in my side-by-side GE fridge/freezer. This has been happening for months and I have to wipe up water everyday. Now my freezer and fridge are going up about...
Leo Ponder
imufo2
Aug 16, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have frost on the freezer side and both the freezer and fridge are not keeping the food / frozen items cold. The fridge seems to be running constantly
remove the rear panel in the freezer,and if evaporator coils a solid block of ice,take a hand held hair dryer and melt the ice,then remove the heater located under the coil and test it for continuity,if open replace it with g.e.# wr51x10055 heater element
Aug 07, 2011 | GE GSL25JFPBS Side by Side Refrigerator
I have a GE fridge model TFB26PPDABB that is leaking from the bottom left on the freezer side. The bottom of the freezer is a sheet of ice. Please help
you have a blocked drain,melt out ice with hair dryer,then go to the back wall.on the bottom you'll see a holeyou might have to take wall off,that's where the water drains when the machine defrosts,i use a steamer to clean out the drain,it's a shark super steamer costs around 40 bucks but you can use a long plastic wire tie or something to snake through the drain line,slime builds up in the drain or a piece of food or anything could be in there,when you think you melted and cleaned the drain pour hot water in drain,if it goes down your done
Nov 17, 2009 | GE Refrigerators
Water leaking out of the bottom of my ge refrigerator.is there a tray that I need to empty? cannot locate one.
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Sep 11, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE fridge GSH22KGMA not getting cold
you need to replace the gasket on the unit . its letting in too much moisture.. the drain line may also be clogged up and holding water in the drain pan. take a piece of wire and clear the drain then poutr hot water and baking soda down it witrh a turkey baster.
Apr 05, 2009 | Refrigerators
Ge profile water/ice fridge side under bottom drawer
take out the back panel in frzzer side use a steamer to clean out your drain hole
Mar 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
TOO MUCH ICE
just switch off and melt the ice away with a hairdryer.
drain is behind the back panel inside the freezer
Dec 02, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
