Question about Canon PIXMA MX310 All-In-One Printer
Ever time i fax show line busy ? - Canon PIXMA MX310 All-In-One Printer
    Problem Solver:
  • 9 Answers
It is because you have a dial up internet and when you use the internet it dials a number for you to get on untill you sign out or log out. Then you will be able to use your home phone or your fax.
Posted on Dec 03, 2008
3 Suggested Answers
  • 16 Answers
SOURCE: Kodak 5500 Fax won't connect
Most likely problem is your phone company is blocking it for some reason.
Posted on Apr 26, 2009
pineworks
  • 4041 Answers
SOURCE: shows busy but line is not busy
Hi
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
Click LINK= http://www.4all2sell.com/pdf/Brother-MFC-240C-Manual.pdf
You will need a adobe reader to see this file If you not got an PDF reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 03, 2010
Difficulty sending a fax
Hello. Please make sure your telephone line is plugged into the correct outlet.
Most fax machines typically allow you to plug the line (the cord that goes from the fax machine to the wall jack) and and a telephone (the telephone connects to the fax machine).
In order to fax correctly, you must plug the line into the jack with a block (looks like a 'T') marked on it. Do not plug the line into the jack marked with a phone hand set marked on it.
http://gdlp01.c-wss.com/gds/0900002546/PIXMA_MP780_750_Easy_Setup_Instructions_EN.pdf
This shoulds in detail how to connect the line properly. For this printer the line cord must be plugged into the jack labelled "L"
http://gdlp01.c-wss.com/gds/0900002542/PIXMA_MP750_780_Quick_Start_Guide_EN.pdf
This will show you how to actually send the fax. On your PDF View select page 42.
Feb 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
One line two Devices
WinFax will support two modems, but I believe only one ISDN device. So, you can't use both ISDN and analog fax modem at the same time.
Nov 24, 2008 | Symantec WinFax Pro 10.0 for PC
Phone line gets busy tone while recieving fax in DRPD mode
As I understand it, this is as it should be. You have two different numbers sharing the same physical line and only one can be active at any one time, so if you are using the phone and someone tries to fax, the fax line will be engaged and similarly, if you are sending a fax and someone tries to ring on your phone line, it will be engaged.
Nov 07, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Invalid number
Fax machines do not work well or at all on digital lines. They are designed for analog lines, like the standard phone company line. You may have to install a dedicated fax line from your tel. company.
Jun 11, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Incomplete info code 634 how to fix
That codes says:
"Redial count over with no response
or busy tone was not detected.
Note:
U.S.A. and Canadian models
will redial only once if a busy
tone is not detected."
The number you're dialing was first busy. When it went to redial, it detected no phone signal on the other end. If it happens to only 1 or 2 customers, then it's something to do with their lines and you can't fix that.
If it happens often, then get your phone lines checked out by your phone company, make sure your fax is not sharing the line with another other device and make sure it is not a digital line.
Other than that, you're looking at having to replace the main board in the fax. Which basically means it's time for a new fax machine.
Jan 02, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
We can't send or received faxes
Just a suggestion. This effect can happen if you have plugged the line cord into the tel jack instead of line jack.
Oct 30, 2007 | Brother IntelliFAX 2800 Laser Fax
Line 2 continually flashes on GE 29490GE2 Corded Phone
Does it flash when you try to fax? (Or) Does it flash and when you try to fax it shows busy? Your phone most likely has a line in use detection circuit so when a line is being used by another phone (or device) you will know to choose the other line. These detection circuits can sometimes be fooled, confused or even cause problems with other telepones.
Jul 06, 2007 | GE 29490GE2 Corded Phone
Fax line stays busy continously...
Still a problem? Can you be more specific?
Jan 29, 2007 | Canon FAXPHONE L80 Laser
Canon PIXMA MX310 All-In-One Printer Logo
47 people viewed this question
old marine
old marine
