Question about Sansui VRDVD4005 DVD Player/VCR
Sansui VRDVD4005 My Sansui VRDVD4005, wont see or recognize the remote control. I have two of the same machines and two of the same remotes. So I know for sure the two remotes are sending a signal as they both work on the other machine. Any suggestions?? Thanks, Bob
  • Anonymous Dec 11, 2007
    I have Model Number VRDVD4005 need Manufactures code number to enable cable company to program remote control to operate Sansui Model.
    I have the Manual but it doesn't have the code. Would appreciate a reply. Thank you, Jim Sherry
  • lee111 Dec 17, 2007
    I have Sansui VRDVD4005, and just found out that the remote not communicate with the recorder. I also try with a new remote but still not communicate.
    Is there any solution? please help.
    Thanks
Unplug the system and plug it back in to re-set it
Posted on Sep 30, 2007
SOURCE:
Hi i have a sansui dvd recoder/vcr vrdvd4005 i need a remote do you know the model i need thank you?
Mine has no model number. But on the front down in the right hand corner is this number.......................076NOHQ010
Jan 30, 2011 | Sansui VRDVD4005 DVD Player/VCR
Where can I get a replacement remote for this dvd player/vcr combo
Remotes.com has a substitute remote that does the functions of the original here: http://www.remotes.com/store/sansui/vrdvd4005.html.
I hope this helps.
Jun 24, 2010 | Sansui VRDVD4005 DVD Player/VCR
How can I get a replacement remote control for a Sansui VRDVD4005?
you can contact SANSUI, but the easier way is to buy a generic one and program it, alot cheaper, and walmart has them
to make it easier also, but a USB programmable one that logitech has, this can control pretty much the whole house, but costs about $200.
Aug 21, 2009 | Sansui VRDVD4005 DVD Player/VCR
Vrdvd4005, remote quit, changed batteries,
I would almost stake my life that the inferred diode is the problem, this has happend to mine in the past I replaced the diode and it has worked for years now.
Jul 07, 2009 | Sansui LCDWDVD320 32 in. TV/DVD Combo
I have a 2003 Sansui VRDVD4005 recorder. It currently playsback on channel 4 on my TV and I need to reset it so it plays back on channel 3. Do you know how I can make the change? All suggestions on the...
Turn off the unit. press and hold the "3" button on the remote until you see "rf 3" in the display on the VRDVD4005. This will change the output channel to 3.
Feb 18, 2009 | Sansui VRDVD4005 DVD Player/VCR
Need a new remote control
Go to:
remotehound.com
or
sansui.newremotecontrol.com
Dec 31, 2008 | Sansui VRDVD4005 DVD Player/VCR
Setting the clock
Use an Aiwa Hifi Remote Control...Turn on the L300 (without any DVD on the player). Wait until in the TV appears "No Disc" Open the tray and put a DVD from other region (not zone 1), don't close the tray!!!. On the remote control of the Aiwa press the "Clock" button, in some remote control you must do a button combination like "Shift+9" (Is the combination to see the clock, do the combination fast), and in other model of Aiwa remote control doesn't appear the clock button, you must try with the "random" button. If you do it right, in the corner of TV where "No Disc" appears it will say "adjust complete".
Jun 15, 2008 | Sansui VRDVD4005 DVD Player/VCR
Lost remote
try 1-800-289-0980 or www.orionsalesinc.com
Dec 21, 2007 | Sansui VRDVD4005 DVD Player/VCR
Vcr to dvd recording
As i recall, +r's will only format in dvd vr, the unit does not like high speed recording disks. switch to dvd drive - insert blank disk - if no format screen - goto (on remote) setup - onscreen menu - system setup - disc setup - new disk format - hit center button in ring on remote to change to vr or move up to reformat as vr. once disk is formatted, use record speed button on remote to set record speed 1,2,4,6 hr then switch to tape deck with tape in and stopped at begining, on remote hit dubbing, it will ask you confirm dubbing vhs-dvd .... toggle over to yes & hit center button... away you should go... c245 is a copyguarded tape.
Oct 09, 2007 | Sansui VRDVD4005 DVD Player/VCR
Sansui VRDVD4005 DVD Player/VCR Logo
213 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
