Question about Blenders
I bought a 5speed blender your brand im so disappointed
The blade is not sharp at all it sucks bad. i couldnt take it back because i trow the box and recietp away
  • 3 Answers
Vitamix it has at least one year warranty up to seven years. Take it to Vitamix dealer, and it will exchange your blade free...
Posted on Dec 22, 2008
What should I do after buying an oster blender and blade doesn't turn?
Take it back now or you will have more future trouble. Sometimes we do get lemons. Good luck
May 02, 2014 | Oster Blenders
Leaking
Unfortunately Kitchenaid's design on those blenders is a one piece unit, over time the seals wear out and you have to replace the entire jar assembly, they usually run 40-50 dollars and can be found from several vendors.
Here is a link to the replacement jar on our site: KitchenAid Blade Jar Assembly W10555711
Nov 28, 2013 | KitchenAid KSB560MC 5Speed Blender
My blender is not chopping as well as it used to...sometimes not spinning at all.
The motor may becoming weak. You may not observe much difference between the two speeds
Nov 27, 2013 | Waring MBB518 2Speed Blender
Blade stuck in nutribullet
I took it apart by removing the rubber spindle and three small screws. Then soak it in vinegar and rinse to remove food gunk. Lastly, re-lube with cooking oil (I used olive oil) by pouring onto back shaft and spinning the blades to suck in the oil. Reassemble. I still have to replace mine as the spindle is loose due to the bearings being worn out but at least it is useable again until then.
Feb 21, 2013 | Magic Bullet Nutribullet Blender
My blendtec blender doesn't blend as well as it once did. The motor seems to be running fine, but I am not sure if the blades are spinning properly.
You have already found what is the problem the blades.
The blades after a lot of working hours with ice they have mainly three problems.
One the sharp adjes have created a lot of teeths and are not so sharp any more so the blending is not smooth anymore.
Second problem they have loose a title so they have move from corect place some milimeters and this change the wave motion and again the beleding is not so smooth as before.
Third the blades are secure on an axis which is located in two bearings which have een wearing out so the rotating motion of the blades again is not so smooth as before.
So if you are not able to fix the blades kit or to find someone in your area to do it profetionaly and cheap one good idea is to buy a new blades kid.
Good luck
Aug 17, 2010 | Blendtec ABC Work Top Blender
Blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 24, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
My Blender knives don't cut good anymore, what should i do?Can they be changed?or should I buy a new one?
Do you mean blender blades?
Either way, your blender blades/knives need to be sharpened.
This is the key to making your blender last a long time.
You may need to reach into the unit to sharpen them if the blade part doesn't twist off.
Good luck :)
Nov 11, 2008 | GSI Technologies 73365 Vortex Work Top...
Durabrand blender model number tsk-9368ap
You just bought a bad blender. Get a different model
Jul 10, 2008 | Blenders
Blenders Logo
52 people viewed this question
Top Blenders Experts
Mike Cairns
Mike Cairns
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
