Question about Euro-Pro Deluxe 7130 Mechanical Sewing Machine
Only sewing in reverse
All of a sudden about an inch from where i would be finished the seam the machine started to sew only in reverse without my touching the pedal.
If your reverse button has been stuck at all in the past then it may have just been sitting close to reverse for awhile and fell into that setting. Maybe your machine needs a good maintenance cleaning.
Posted on Feb 04, 2007
I am stitching a seam and when I finish it the thread is loose and it is like sewing a ruffle
increase the needle thread tension a bit
when approaching the end of a seam sew to the edge then engage reverse direction , sew back over the sewn bit for about 1/2" inch then forward sew again and cut the cotton when off the edge
Oct 23, 2016 | Sewing Machines
Tip
Sewing Tips for Beginners
1. Sewing Pins are essential
2. And how about a cute little Pin Cushion to hold those pins.
3. Before getting started it's best to Understand About Fabric Grain.
4. Knowing All About Sewing Machine Feet is essential.
5. Finish Seams without a Serger
6. Gather Fabric easily.
7. Serger owners can Gather Fabric on a Serger.
8. Making Bias Tape is sewing simple.
9. Attaching Bias Tape ~ even easier!
10. Once you've mastered Bias Tape, Making and Attaching Piping is the next step.
11. Shirring Fabric with Elastic Thread ~ tons of bang for your buck.
12. Attaching Buttons with a Sewing Machine
Best Sewing Machine Reviews 2018 The Ultimate Buyer Guide iSewing Machine
on Oct 13, 2017 | Brother Sewing Machines
Why is the fabric not feeding forward when stitching
on the front of the machine there is a lever/knob that sets the stitch size
if it is in the middle position ,the teeth will just go up and down and not back and forward
check that setting
it is used to seal of the threads when starting to sew and when finishing
start the sew for about 1/2" then reverse the feed then go forward again to complete the sewing
at the end of the sew do the same thing again before cutting the threads
this locks the threads as a knot so that the seam will not come undone
Sep 27, 2015 | Sewing Machines
Sewing backwards
sewing backwards is primarily to lock the threads at the start of a sewing process ans so stop unraveling of the stitch
it should be about 1/2 " long so you start sewing 1/2 inch , reverse back to start then reverse and sew on as normal
finish of the stitch should be the same before you raise the foot and snip the cottons
Aug 03, 2014 | Elna Sewing Machines
My Huskylock 936 won't sew. I was sewing yesterday, 4 thread overlock. I finished a seam, cut the thread, proceeded to sew another seam. I put my foot on the pedal..and nothing.If I turn the machi
Good evening madam
It sounds like there is something wrong with the electrical system in your sewing machine. You can check the power and connections.
good luck
Kolbrun
Feb 26, 2012 | Husqvarna Huskylock Computerized 936
While sewing and finishing seam I went in reverse to knot. While resuming to sew again the machine began making beeping sounds and wont move forward to sew.
Raise the needle, make sure no thread is caught ( try clearing out the bobbin area), then turn off the machine, re-thread the machine, then power the machine back on. That should take care of it. ;)
Jun 22, 2011 | Singer 7436 - INGENUITY
I have a brother VX-950 sewing machine I have a pretty good stitch on top and bottom, put it is still puckering. I tried the tension. What elese should I try?
New needle and make sure it is the right sized needle for the fabric that you are sewing. If silky satin then use a size 70 or even 60 needle sharp. If microfibre then there are Schmetz needles called microtec that are perfect for this.
Also try shortening the stitch length a little. You may still need to finesse the tension a bit. I think this is a front loading bobbin machine so you might try adjusting the tension on the bobbin holder a little bit. It is hard with these as there is no "0' marking to set it to, its just trial and testing.
Also, are you pinning across the seam line at about 3 inch intervals?
If there is still some puckering happening, then perhaps, stop at the end of the seam with the needle in the work, and ease the fabric along the stitching line a bit to smooth out the seam, then do the reversing stitches at the end to lock off the seam.
Also press, press, press each seam. Always press on top of the seam, turn it over and press the underside of the seam, then lie right side down on the ironing board and press the seam allowances open. This sets the stitches into the fabric and finishes off the seam appearance. I always sew with the ironing press on beside me.
You may still be unhappy with the seam result after doing all this - if you enjoy sewing then consider shopping for a higher quality machine - there is a difference in stitching quality between a $400 and $2,000 machine. You could always take a piece of your fabric to a sewing dealer near you and test sew on a European machine, you should see a difference in the stitching quality.
Apr 17, 2011 | Brother Sewing Machines
My consew 230 sewing machine is not holding the thred on the needle. every time i thred the needle and step on the paddle to sew, the needle comes back out unthred, please help.
before starting to sew
1.make sure the top thread & bobbin thread have a thread tail of 3 to 6 inches
2.make sure the thread tails are pulled behind the needle toward the back of the machine
then put the fabric under the presser foot to sew
when your finished with the seam, after the thread is cut from the fabric,, leave the thread tail the same as above before starting to sew again
Jan 22, 2011 | Consew Sewing Machines
How do you prevent pfaff sewing machines from eating up the fabric at the begin of every seam? do you have to start in an 1/8 inch each time you start a seam, or can you start a seam right at the edge of...
This happens with other brands as well.
Hold on to the threads behind the presser foot and hand walk the first two or three stitches.
Some like to use a leader/spider.
Fold a scrap and stitch to the edge and then **** with the fabric you want to sew.
Remove the leader and use over and over and soon the leader threads will resemble a "spider".
Mar 09, 2010 | PfaFF Sewing Machines
Euro-Pro Deluxe 7130 Mechanical Sewing Machine Logo
355 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
