Question about GE Spacemaker WSLP1100D Top Load Washer
Agitator I just had a Wslp1100 washing machine delivered. I know that the agitator does move and pause off and on while the machine is filling, but once it is filled and should start to wash, it keeps agitating and pausing, agitating and pausing, it never just washes like regular washing machines. Is this normal for this model?
  • hbhb Nov 20, 2007
    I have the same issue - I just got mine installed and it's doing the same thing! What was the resolultion??
  • Anonymous Mar 22, 2014
    What make agitated keep popping up
  • 5 Answers
Yes, it is normal. ;)
Posted on Jun 19, 2008
SOURCE:
My GE Spacemaker wslp1100 top loader is draining very slow causing error code dr. I took black drainage hose off and it seems to be clean. Filters are clean inside washer. I want to know if a coin could be...
You don't reveal full model number. It's not likely that a coin is blocking the water. The pump (part of the motor assembly) may be partially blocked inside or a garment (sock, u-shirt, etc.) may be blocking the water inlet to the pump. It's too early to remove the agitator.
Nov 22, 2013 | GE Spacemaker WSLP1100D Top Load Washer
Kenmore washing machine won't agitate?
You are referring to the "agitator dogs". Does the unit run during the wash cycle put the agitator does not move?
Nov 24, 2012 | Kenmore Washing Machines
Wahing machine will not wash
the entire agitator is not moving during the wash??? or just the top section that looks like a big plastic corkscrew???
or is the unit actually just filling with water, making the motor running noises and going thru the motions of running a cycle yet not actually moving anything within the unit, then draining out as normal??
if just the top section of the agitator is free spinning instead of ratcheting as normal you'll need to replace the agitator dogs if present.
if however the units just filling and draining of water with no inner movement then more likely the drive coupling is bad and needs replacement..
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Whirlpool Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
The agitator moves very slowly so clothes aren't washed
INSIDE THE AGITATOR IS A PLASTIC GEAR AND SOME DOG EARS WHICH GRAB THE AGITATOR,,,USUALLY ITS THAT,,CALL YOUR LOCAL APPLIANCE PARTS STORE,TELL THEM THE BRAND AND THEY WILL KNOW JUST WHAT YOUR TALKING ABOUT AND YOU NEED,,ITS A SIMPLE FIX,,NO NEED FOR TECHNICIAN,,
Sep 08, 2009 | Amana 3.2 cu. ft. Top-Load Washer
No agitate and no spin
ok,,you need agitator dogs ,,the top auger move booth direction,,worn agitator dogs,,,i need you to fill unit on smal use a poy or bucket i have to know if this washes,,,onthejob
Jan 16, 2009 | Whirlpool Washing Machines
Kemore 90 Serieswashing machine fills and spins but won't agitate
Remove the agitator and see if the agitator shaft moves during agitate. If it moves then the agitator spline is worn or the agitator dogs are worn and the top half of the agitator will not work. If no results then the gearcase would have to be replaced
Dec 30, 2008 | Kenmore 24032\24036 Top Load Washer
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Washing machine noise
check the dogs in the agitater
Mar 25, 2008 | Whirlpool GSC9455 Top Load Washer
Agitator always moving
The inner tub on some machines does rotate very slowly while filling to assist with the even distibution of the load. If the agitator is turning back & forth while in fill mode, you could have a timer or transmission problem. You need a tech.
Nov 04, 2007 | Kenmore 98702 Stacked Washer/Dryer
GE Spacemaker WSLP1100D Top Load Washer Logo
239 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
