I have a sky box remote control that the batteries went flat in. On replacing the batteries the remote no longer works for the tele. I believe that I need a code. Please help.
    Problem Solver:
  • 4 Answers
What is sky remote code for LG 42LB5500
It depends on the Rev. number of your remote. Older Sky remotes are programmes for different models compare to new ones.
A surerfire way to set this up is to use the Sky "Program my Remote" feature from the Sky box itself (it's in the Help menus), or direct from the Sky web page: http://sky.uebv.com/ Each way will ask you to chec k the revision (rev) number from the sticker inside the battery compartment.
Sky com Find your remote control code
Sep 07, 2014 | LG Televison & Video
How to pair sky controller
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 31, 2014 | Televison & Video
My sky remote control does not work with a secondhand skyplus box. what is wrong
see the diagram attached:
1) retight the spring contacts batteries with pliers for good contact
2) clean the contacts batteries with contact cleaner
3) resolder the wires contact batterires
4) open the r.control for clean the contacts for dirty, corrrosion, oxide, test with continuity, remember they send infrared signal to the microcontroller receiver.
5) if you can do it, go to the repair shop TV for fix it.
God bless you
Jul 16, 2012 | Televison & Video
We have loads of codes for sky remote control. Do you know which code will enable us to switch the tv off and do the sound control. At present we have to use two controls. TV remote to switch on and...
OK,
This really depends on which brand/model of TV you have and which Sky remote version. The code you need is specific to the brand/model of TV.
The Sky remote version is printed on a sticker inside the battery compartment. The older Sky remotes will have "RC1600/00" on the sticker. Newer versions will also have either "Rev 4", "Rev 6", or "Rev 8" on the sticker.
If you have a new TV and an older Sky remote (i.e. before Rev 8) your remote may not work with your TV and you will need to buy a new Sky remote if you want to operate TV and Sky box with one remote.
Please post back with your Sky remote version number and your TV brand and EXACT model number. I will then be able to provide codes for your remote and programming instructions.
Thanks.
Nov 03, 2010 | Televison & Video
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here: http://sky.uebv.com/
Sky guide to finding your remote code and programming remotes is here:
http://www.sky.com/helpcentre/tv/sky-remote-control/program-your-sky-remote-control-to-work-with-your-tv/
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Panasonic Viera TH-42PX80U Plasma TV
My sky remote has stopped working on my samsung tv
Easy peezy...just press TV on your sky remote,now hold select and the red button until it blinks twice,after it blinks twice enter this code ...1430....it sjould blink twice again,now press standby,it should turn your tv of,if it does press select to save these settings,it should now control your volume too,let me know if this helps
Feb 16, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Sky box wont work
try taking the plug out and waiting for 5 mins before plugging it in again.
Also are you pressing the button itself or just the remote control? The batteries in your remote might need replacing
Oct 27, 2008 | Audio Players & Recorders
Can't get sky remote control to work
i have a amstrad sky box the remote has the record button on it.
i did not change the batteries in it now it wont work the sky box at all.
HELP PLEASE....
Oct 08, 2008 | Televison & Video
Code for sky remote control
tech guy from ebuyer said no code available but sky remote will work ok but volume and tele on- off facilities will not so use remote which came with television to do this so says he.
Apr 17, 2008 | Hannspree (K206-10U1-005) Television
Rf2 outlet from sky hd box
on your sky remote
services
0 1 select
make sure the rf is set to on
Remember the channel rf number,
go to your television the link is to.
go to menu then setup and then manual tune
select the channel you want to view sky on. normally channel 6 on your analogue
then go to Channel type in whatever the rf setting was on your main sky box then press save.
that is your telly sorted out. if you have a magic eye connected at the link end you should see a red led light lit up.
if not remove the magic eye and connect it straight into the back of your sky box RF2
just to make sure that the eye is not at fault.
hope this helps
ill check in a day or two to see if you need more help.
Cheers
Little Dish Fitter
Nov 14, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
