Question about Brother HL 1440 Laser Printer
Stuck paper in printer
Paper went in lopsided--- can't remove it
    Novelist:
  • 148 Answers
The only solution for this is to dig it out
remove the paper feed cartridge, open the printer up and remove all corona wires, and anything that will slide out
look to see the feed rollers and try lifting on the rollers with your fingers to take any tension off of the top roller always try to remove the paper from the feed area slowly work the paper out if you still see small piece of paper try working them out with a stiff piece of index stock
avoid damaging the rubber rollers with a sharp object and by all means do not force the feed rollers they were designed to move in one direction..towards the copy area a pair of tweezers and hemostats work very well
the fact that the paper went in sideways lends me to believe you have a fed roller problem or an obstruction
once you clear the jam cean the feed rollers with soft cloth and alcohol
good luck
Posted on Dec 30, 2008
Document is printing lopsided on paper
Problem with paper pick up delay due to dusty disc encoder/sensor or pick up roller.. service needed,
Feb 01, 2012 | HP OfficeJet 7310 All-In-One InkJet...
My paper keep getting jam and will not go into print
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persists and you see no paper that is stuck in the printer it
May 14, 2011 | Office Equipment & Supplies
Paper jams
hi,
follow these steps:-
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting theprinter manufacturerfor additional assistance and/or repair.
Thanks!
Aug 04, 2009 | HP PSC 1350 All-In-One Thermal Printer
How to remove a paper jam from the vivera paper tray
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting the printer manufacturer for additional assistance and/or repair.
Jul 13, 2009 | HP Photosmart C7280 Laser Printer
Sharp al-1631 misfeed light will not go out
This usually happens when a sensor that detected a paper jam has not reset itself after removing the paper. Make sure that when the jam was removed - all the paper came out and there is/was not a small piece missing that could have been left behind in the copier and is hiding somewhere. If you are sure the paper has all been removed then what could have happened is when the jam was being removed it could have caught on one of the paper sensors. This could pull the little flag that activates the sensor out of place - giving a false paper jam message. there are only a handfull of sensors in the paper path. remove the paper tray and make sure there is no paper stuck behind the tray or in the cavity where the tray goes. look and follow very closely the path the paper takes - look for any sensors/flags the paper would avtivate and make sure the flag moves freely and is not lopsided.
Make sure you also try unplugging and replugging the copier from the wall.
Hope this helps
May 19, 2009 | Sharp AL 1631 Copier
Removed paper jam from 6450, but it still shows paper jam message went through the troublshooting steps, but ! is still blinking with paper jam message that says, "clear jam, press ok."
make sure you have all the paper out, sometimes there is a small piece that got stuck inside the printer. if you can not see it, you will probably have to take it to a service center. most likely its stuck where the sensor area is.
Apr 16, 2009 | OKI B4350 Laser Printer
Printer cartridge stalled
# Turn off the printer.
# Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
# Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
# Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
# Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue
Feb 06, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Paper jams sideways and gets munched up - will not print
Check the paper path way , and also leds that directing paper.
hope that help you
thanks
Hamedo
Oct 25, 2008 | Dell 922 All-In-One InkJet Printer
Brother HL 1440 Laser Printer Logo
126 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
