Question about Coleman Powermate Premium Plus 6250W Portable Generator
ENGINE OVER SPEEDS WHILE RUNNING
COLEMAN POWERMATE 6560 ENG #1025195, S/N F05, WITH A SUBARU ENGINE...CRANK THE MOTOR AND IT GOES FULL SPEED RIGHT AWAY, JUST STARTED IT 2 DAYS.. HAD IT RUNNING, ALL OF SUDDEN, ENGINE WENT WIDE OPEN, LINKAGE NOT BROKEN & RETURN SPRINGS ARE IN GOOD CONDITION. HAD GENERATOR CHECKED & HE THOUGHT IT WAS IN THE GOVERNOR, MAYBE NOT LETTING THE WEIGHTS OPEN,, CAN NOT FIND A SERVICE CENTER IN THE AREA OF OF PORT ARTHUR, & BEAUMONT, TEXAS... THANKS
  • gjbtx28 Dec 03, 2008
    THANKS FOR THE QUICK RESPONSE,, WILL CHECK THIS OUT THIS AFTERNOON,,, GERALD
  • 169 Answers
This is almost surely a problem with the governor, check it like this.
Have someone with a finger on the kill switch.
Watch the governor arm while starting the engine, if it does not move almost immediately after starting the engine it is broken.
This is not a simple repair as it involves taking the crankcase apart, you'll have to contact robin/subaru to get a parts list in order to get the right governor spool and weights.
For an experienced technician this is about a 2 hour repair task.
Hope this helped,
Carl
Posted on Dec 03, 2008
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
My coleman powermate pro 6750 generator only puts out like half power, after 30 minutes it loads up and runs fine. what causes this?
It would be surprising to me if the engine was running at proper speed while it is not putting out full power. I am not familiar with your particular model so my answers are coming from knowledge of generators in general. If it is running at proper speed then it would have to be a regulator problem. This is assuming that it isn't trying to run in an overload condition and that you are letting it run a little before you put a load on it.
Dec 22, 2015 | Coleman Electrical Supplies
I have a coleman 5000 that won't hold voltage at 110 volts under load. It fluctuates up and down. The motor is running steady. What could be the cause of this?
govenor problem maybe does the engine sound slower when a load is on.
you will need something to read the power frequency
3000 rpm produces 50hz uk
3600 rpm produces 60hz
so if you have a meter to measure frequency you will also know what speed the engine is running at
Feb 27, 2010 | Coleman Powermate Powermate 5000W...
I have a Coleman Powermate 6250. Runs Great, No power to outlets!
Excite the genset.
with the gen engine running,
1) plug a 3/8 drill into an outlet,
(make sure the drill is set to the forward rotation)
2) hold the trigger in the run position
3) by hand, rotate the drill chuck with a quick flip of your wrist.
*** NOTE: BE PREPARED !!! this will excite the gen-set and the drill will start to run as normal.
Oct 07, 2009 | Coleman Powermate Premium Plus 6250W...
Does not generate electricity
check your fuses or circiut breakers...
Aug 06, 2009 | Coleman Powermate Powermate 5000W...
My Coleman Powermate 6250 generator has no power output. After the carburator was cleaned, I flashed it. A voltage meter shows there is power being generated, but none so to light a light bulb. What to do...
Take the cover off and flash the rotor again with a 12 volt battery. Positive lead goes to the top or right side brush. Negative to the other brush. Just touch it on, then remove it, and check for power at plugs.
If that doesn't do it, change the AVR (voltage regulator)
Aug 05, 2009 | Coleman Powermate Premium Plus 6250W...
I have a Coleman Powermate Pulse 1750 generator. The engine runs fine but lately I've noticed I'm only getting approx. 105 volts. Any suggestions.
Engine speed is low, does your meter read frequency? Set for 60 Hz @ speed. I doubt there is a voltage regulator adjustment. This may help
Jun 25, 2009 | Coleman Powermate Premium Plus 6250W...
What type of oil for a Coleman 5000 Generator?
You need a quart of regular old SAE 5W30 motor oil with detergent.
The engines on these generators are more or less the same as a lawn mower.
Don't forget to service/change the air cleaner when you change the oil, that should keep your generator producing full power.
Regards,
Carl
Dec 14, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman powermate 6560 generator won't stay running
coleman powermate 6560 that runs good but wont gennerate power, i tried to exite it by plugging a drill in & holding the trigger in & turnning it backwards but still no power any suggestions?
Aug 17, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
410 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
