Question about Onkyo TX-SR605 Receiver
I'm not sure which model I have-
I bought it with a tv it was a sample and all it says on the
machine is : 7.1 95w/ch
analog to HDM1
Tag # 0242 347232 OB-A
M/M ONK TXSR674
serial 3660022029
I also need manuel, XM and FM ariels
  • 333 Answers
Click on this link if you cannot click on it then copy and past to your browser.then download the manual for your sr674 model. http://www.us.onkyo.com/searchResults.cfm?searchItem=TX-SR674 .
Posted on Dec 03, 2008
  • 6,487 Answers
IN order for us to provide you the manula we must atleast know the brnad or model of this device
    Sergeant:
  • 217 Answers
Please explain what problem the device is having or u just need the manual.
Cable box is plugged into denon's hdm1, but I can't get a picture. Hdm1 out monitor (arc) is plugged to TV hdm1 in (arc).
Power up all components. Select the HDMI 1 input on the Denon amp, and the HDMI 1 input on the TV. Additionally, run the old analog cables between the cable box and the TV. If no picture, select the input on the TV that is associated with the analog input from the cable box. You should have a picture at this point - but it will be a standard definition type. Check the settings on the cable box to change the output from "A / V" to Digital on the HDMI jack - if present. You may have better luck unplugging power / replugging in the cable box first - or calling the cable company if you can't find settings for this. Once you have the output of the cable box to HDMI, select HDMI on the TV. If you still don't have it working - try bypassing the Denon and go directly into the TV from the cable box. Try it with BOTH HDMI cables. Also - try different inputs and out puts (HDMI 2, HDMI 3, etc.). Discard any HDMI cable that fails to show video and play audio.
May 04, 2015 | Audio Players & Recorders
When I turn tv off at night it goes to tv. It will not stay on HDM1 even though I set it for HDM1
Main system control memory IC to this TV is fault. It should be replaced. It does not hold the LPM [Last Position Memory]. Contact any service technician.
Gopakumar Gopalan Google
Feb 24, 2015 | Proscan 32LA25Q 32 in. LCD TV
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Jan 16, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
We have a DVD components to our AVR-2307CI Denon receiver and then is outputted through the HDM1 1 out connection. The message 'not supported mode' comes up. Please help to tell me what I am doing wrong....
HDMI1 on the receiver is an input not an output. Make sure your TV connected to HDMI MONITOR OUT. On HDMI setup, check if analog to HDMI convert is ON, Color Space set to YCbCr. If you have more problem refer to page 54 of the owner's manual.
Nov 23, 2009 | Denon AVR588 Receiver
Do i need a converter to watch model kv-9pt40 tv
Can't find the specs but i presume it's an analog NTSC set. You will need a converter to convert the new off air ATSC digital format and if you're on cable, unless they are still converting to analog, you'll need a converter there too. Some cable systems (Comcast being one) will require their own cable box to index the digital channels and convert to analog ch 3 or 4 for your TV.
Nov 14, 2009 | Sony KV-9PT40 9 in. Television
No channels downloaded
The antenna must be hooked up to the converter box. The better the antenna, the better your reception will be.
Not everyone in the country will be in range of digital signals. Digital signals have a shorter range than analog signals do right now. It is possible (but unlikely) that you are not currently in range of any digital signals.
So make sure you are set up like this - Antenna--converter box--Television. Then scan for channels. You should still pick up any analog signals while the box is hooked up, you will just view them the same way you do now, by changing the TV station rather than the converter box station.
Dec 06, 2008 | Insignia Digital-to-Analog Converter for...
Sharp Aquos LC-52D64U LCD-52 wdscrn tht won't scan in digital...
Seeing that you have a superior brand and not getting channels is a bummer. It may have to do with the setting, make sure you're set to cable rather antenna and then do a rescan. Btw, often times channels from an over the antenna is much clearer than from cable because cable tv has to compress the signal. If you're high in the air like the top floor of a building a cheap $10 will pull in great free digital channels. It helps to experiment and read the troubleshooting guide in your manual.
Dec 03, 2008 | Sharp Aqous LC-26D5U Television
VCR Connection
If your vcr has an ant. in and out to tv coax type jacks the signal should pass through when the vcr is off or in tv mode. Make sure tv is on the output channel of the converter box(usually ch 3 or 4). If your vcr is different please give more info.
May 14, 2008 | Insignia Digital-to-Analog Converter for...
Onkyo TX-SR605 Receiver Logo
27 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
