Question about HP Pavilion xl756 (P1358A#888) PC Desktop
I started my HP computer today and it starting beeping, the tower and monitor have power to them, but the display isn't showing up on the monitor, it's just black
  • Anonymous Mar 29, 2014
    When I start my computer, the monitor shows the secuence R7000-B3 R5C on black image
  • 61 Answers
You need to open the tower and reset the memory sticks still if you get those beeps then try those memory stick one by one or swap the memory stick
Regards
Samson Ved
Posted on Dec 03, 2008
  • 37 Answers
Seems the problem is with your ram. reinsert it after cleaning its contact leads.it should work. if it doesn't, replace your ram with a new one.
the system beep indicates a trouble with any of the connected hardware. check all hardware by detaching and reconnecting them.
  • 519 Answers
Different types of beeps mean different things in any pc. The most common causes of these beeps is faulty RAM memory or a faulty display card. It could also be that they are not seated properly in their respective slots. Try removing the two items and re-inserting them firmly in their slots. If this does not solve the problem you can then try inserting them into another machine to determine if they have a problem.
Dell e178wfpc monitor shows power on light but no display.
You should check if the vga cable is tightly connected from monitor to cpu. If the cable is connected properly,then the problem must be with your monitor. Check with any other monitor. If you hear a beep beep sound, when you start the computer then your RAM has been damaged or not properly connected.
Apr 11, 2014 | Dell E178WFP Black 17 inch LCD Monitor
No Beep on start up, computer will not display anything either. Tried: Removing memory- when both memory sticks are out it does long continuous beeps. Put one or both back and power up there are no...
Well, if it was faulty it would detect it on POST (power-on self-test)
and beep. So, you could start by making sure that your display monitor is working ok by plugging another system or laptop into it, or plugging a known good monitor into your barebones system.
It's only a start, I know, but you have to know that the display works and not just assume it does.
Regards,
nicam49
Jun 02, 2012 | HP Computers & Internet
Hp pavilion a1220n comptur will not start unplugged unit and when i plugged to back in it would not start
Do you see anything on the monitor screen? Does the tower make any beeping noise or clicking noise, or does the fan tries to start up when you power the computer on? Are the cables connected properly?
If you see anything on the monitor screen, or if you hear a beeping sound, let us know so we can diagnose further.
Aug 07, 2011 | HP Pavilion a1220n (A1220NED904AA) PC...
Have lg monitor flatron e2260 . Have had for about 3 weeks. Starting today, the monitor goes black and states "d-sub power saving mode". The tower stays on. Thx
1. Check the connections and make sure they are still tight. If the monitor isn't getting data signal it can go into power saving mode. Since it was working I would check this first.
2. Look in control panel under POWER OPTIONS and make sure it's not set to turn off after so long.
3. Also check the settings for your screensaver under display settings. That too could put it into poewr saver mode.
It could be a setting on the monitor itself that somehow got changed. Check out the settings to see if anything has changed.
Apr 21, 2011 | LG Computers & Internet
My HP L2335 Monitor wont display anything. I can literally turn it on (the led power light comes on and it turns green if plugged in and I can tell the backlight is on), but nothing will display no...
why not try a dead display on 2 machines 2 PCs
using only 1 data cable at a time why try to confuse it????????
the OSD must work, or the display is bad or the power supply to it is dead.
easy as apple pie.
the monitor has a tiny computer inside it (micro)
on mine, the data lines dead shows NO SIGNAL in the screen
every time you I power up my monitor with data cables pulled off.
best is to read the book for your monitor, and run all the tests it
tells you there,
Mar 13, 2017 | HP L2335 23 inch Monitor
New hp computer not communicating with Insignia LCD TV monitor
before starting keep press f8. then choose safe mode then if you are in ur desktop try to ressetting your display 800x600 then finally done......
Feb 13, 2010 | Computers & Internet
Mx75 monitor turns off when I awaken my computer
right click on desktop select properties(screen saver ) select monitor button in that select turn monitor never.(configure carefully)
Nov 24, 2009 | HP Pavilion MX75 17" CRT Monitor
Computer tower started beeping
If you added more memory this may make your tower beep.
If so I WOULD REMOVE THE ADDED MEMORY AND THEN RESTART
Jan 12, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Monitor Acer Problem
I agree it isn?t the monitor but I would suspect the video card you are connecting it to or the PC itself. Generally if a monitor doesn?t detect a video signal it will go into hibernation mode, typically displaying a no signal warning and changing the LED color from green to amber. When you start the computer is anything displaying at all? Are you sure the PC is powering up and booting?
Jul 22, 2007 | Acer AL1916W 19" LCD Monitor
HP Pavilion xl756 (P1358A#888) PC Desktop Logo
152 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
