Question about JVC GR-PD1 Mini DV Digital Camcorder
JVC Digital video camera GR-PD1
When I turn on the camera the colour is bright green and pink I plays old tapes ok
SOURCE: transfer movie from mini tape to computer - JVC GR-D770U
You need a DV Cable - Page 41 of your instruction booklet.
Posted on Jan 05, 2008
SOURCE: lost software for my old jvc video camera
JVC Software Site:
http://www.service.jvc.be/software.asp
JVC Operating System Compatibility and SW Downloads:
http://www.jvc-victor.co.jp/english/download/camcorder/about_winxp.html
JVC English Manual:
http://resources.jvc.com/Resources/00/00/98/LYT0421-001B.pdf
Hope this helps!
--grasshopper
Posted on Aug 24, 2008
SOURCE: jvc gr-d50aa driver
http://uk.jvc-service.net/public/download.cfm/prodsoft/Streaming_XP.zip?model=GR-D50&size=256396
USB driver
Posted on Nov 11, 2008
I have worked all day trying to figure this out and Finally found the correct link.
https://www.jvc.ca/en/consumer/service/s_downloads/default.asp
hope this will help others.
Nathan
Posted on Jan 10, 2009
  • 7 Answers
Product called EasyCap, for about 15 bucks, "can be found online" Has USB plug. Use your cable that has the 3.5 pin that goes out to rca cable, yellow, white and red. EasyCap has the RCA to USB then to computer. Use Windows Movie Maker, comes with XP & Vista, capture while playing from there. I just converted about 20 full tapes from one cannon mini 8 and 15 from a jvc dv onto a TB drive.
Posted on Jul 29, 2009
I have a JVC GR-D75OU video camera. When I turn
i have jvc movie camera when i turn it on it says protective cap is on how do i fix this
Nov 30, 2009 | JVC GRD775 / GR-D775US / GR-D775US MiniDV...
Transfer movie from mini tape to computer - JVC GR-D770U
install first the bundled software with your camera turned on and plugged in to your pc and then restart your pc if its necessary..
Dec 27, 2007 | JVC Cybercam GR-D200US Mini DV Digital...
Does this cam, play the mini dv tapes????
If you are referring to the JVC GR-DVL520, yes it does play Mini DV tapes, as well as records to them. It will not play Mini DV tapes that were recorded on an HDV camera. HDV is used by any Mini DV camera that records HD video.
Jun 24, 2009 | JVC Cybercam GR-DVL520 Mini DV Digital...
No sound when playing back video footage
If there is an external microphone jack on the camera, it would help if you tried recording with an external microphone. Also, the mini DV's will mute the sound if the tape guides are slightly out of adjustment. You can tell if they have moved by trying a known good sound tape in the machine. If that plays with no sound also, the tape guides have moved out of alignment.
Sep 16, 2008 | JVC GR-DX97 Mini DV Digital Camcorder
JVC Gr-DVL300 Won't playback
The heads are probably dirty. First you can try to let a tape run through from start to end and see if it cleans the head. then try running in reverse play scan. Next try a head cleaner tape if you have not yet. If these things do not get your picture back you should take it to a repair shop, I do not recomend taking camcorders apart for cleaning at home. Full size VCR's are ok to clean your self with instructions but not camcorders because they are vary easy to damage worse without experiance and proper tools.
Jul 09, 2008 | JVC GR-DVL300 Mini DV Digital Camcorder
Camera dead
there is a fuse blown it happens alot just make sure when you send it in that the shop is a certified jvc or a jvc only repair shop some places fix alot of different brands of cameras and sometimes you might not get it fixed right away because of the workload or not at all
Dec 29, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Jvc gr-dv500u
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 27, 2007 | JVC GR-D290 Mini DV Digital Camcorder
Black or blank screen
your older recordings will only play on a pal monitor / tv ; if the camera video is ok now ? your tape heads may be dirty , wearing out - or both ; try a cleaning tape first but - do not rewind cleaning cassettes , or the old grime will be put back on the cleaned heads and guides ;
Jul 23, 2007 | JVC GR-D73A Digital Camcorder (PAL System)
Struggling with jvc camcorder GR-DX67
replace the fpc wire which is coming from the lcd unit to main board assumbly
Jun 24, 2007 | JVC 580136 Camcorder
Open Questions:
JVC GR-PD1 Mini DV Digital Camcorder Logo
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
