Question about Samsung LN40A650A LCD TV
No color on new tv
Just got a new samsung lcd flat screen. have audio and video but it is all in black and white. figure it must not be set up properly but not sure what to do.
  • Anonymous Mar 12, 2014
    no color in my screen just blac and white
  • 4,889 Answers
Try adjusting the color through the main menu,picture. The color settings are usually set to a decent level. So check the input cables if they are all correctly plugged in. If it still doesn't resolve the issue make a dash for the store and ask for a replacement hope it doesn't get that far though..
Posted on Dec 03, 2008
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from
Samsung LCD Loud Noise and Green Vertical lines at Start up ... > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
White screen
"White screen" on Samsung LED TV - Forums - CNET > Forums > Samsung
CNETJun 11, 2015 - I guess I better send it to the repair shop and prepare myself for a long break ... Hello i have experienced the white screen tv as well, i got mine as part of a deal ... Samsung LCD Green Screen
Jun 11, 2015
Samsung DLP TV w/ White Dots on Screen
Jun 11, 2015
Samsung DLP white dots fix?
Apr 10, 2012
Samsung LCD TV now bright white screen
Aug 1, 2011
More results from
? 4:42
May 11, 2013 - Uploaded by Tampatec
EASY Common LCD REPAIR Blank WHITE DISTORTED VIDEO... LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test ...
Samsung TV "white screen" repair - YouTube
Dec 16, 2015 | Televison & Video
Screen is black, but still getting audio
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 21, 2014 | Samsung UN32F5500 32-Inch 1080p 60Hz Slim...
I have a Samsung LN46A650 LCD TV and recently I started getting a white line across the top of the screen. Sometimes the white line is thicker on the left side of the screen. Sometimes after the white...
Yes, it's the t-con board, a well know problem in this tv. Here it is
Sep 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
How can i play ps2 on lcd without having a black and white screen ? how can i connect the cables ?.....when i look at the back of my lcd i find three ports (red white yellow) when i use them the screen is...
1) The set of input (Yellow= Composite video, Red= Right channel audio, White= Left channel audio). This set of input is for composite video.
2) The set of input (Red= Red video signal, Green= Green video signal + sync, Blue= Blue signal, Red= Right channel audio, White = Left channel audio (the Red and White will be grouped close together). This set of input is used for Component video for HD signal.
You should try using composite video source (Yellow RCA jack) from DVD player and feed to the monitor and see if it works OK with all color showing that way we acn find out if it is the video source problem or the monitor video signal processing problem. Try the PS2 on the TV if it works OK also.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 20, 2011 | Samsung SyncMaster 940MG 19" LCD Monitor
Color image is coming out black and white
does it happen on the any input or just on tv setting?
if it's judt tv then sounds like the tuner, if it's on any input, then the video chip or a decoder on that board.
Apr 08, 2010 | Philips 26PFL5322 26 in. LCD TV/HD Combo
Black screen but still able to hear sound. Have tried turning off and leaving off for 24 hours and still no joy
This sounds like an LCD problem. My tv did something like this. Only my screen lit up and flashed random colors.I took it to a shop and was told the LCD was bad and throw it away.I kept the tv and just found a replacement LCD on EBAY for a grand total of $88.Now I can fix my tv for a fraction of an new one. The part number is LTM190M2-L31.I hope this helps.
Jan 14, 2010 | Samsung LN-T1953H 19 in. LCD HDTV
New Samsung 40" flat screen HDTV only plays in black and white
you need to check the cables.
component with RGB -- you need to connect exact match the color.
Feb 06, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
No color just black and white
Try setting brightness, tint, contrast and color intensity from the main setup menu.
If these have no effect, you have an internal failure beyond your reach.
Some sets have the inputs for external devices partly covered by a snap-off cover.
These are customarily in the back of the set; look for a piece of plastic that seems separated from the rest of the surrounding plastic.
This will normally have a crack at the bottom so the cables can exit with this cover on.
Our set has some inputs (more frequently used) on the side, others where described.
Jun 17, 2008 | Samsung LN-S4041D 40 in. LCD HDTV
DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
May 02, 2008 | Televison & Video
Samsung LN40A650A LCD TV Logo
108 people viewed this question
Jerry Greenberg
Jerry Greenberg
