I have a 2000 subura legacy/outback. When i put it in reverse it makes a loud clunk noise. Sometimes it does not make the noise initially, but as i am reversing it does it.
Another problem i am having is when i am at a light etc. the car will vibrate. It vibrates in drive, and park put when i put it in Neutral is goes away. As it is vibrating, if i turn the steering wheel some it stops and wants to lunge forward. Then it will start vibrating again.
Thanks in advance for any advice
Ali
Turn off engine . get the vehicle on level ground. try to move driveshaft back an forth or,by rocking in twist motion,,, try to hear a knock,,,this would indicate a worn universal joint.either front or back, if you are good enough to discern which one is making the klunk, change both to be on the safe side. think they may be about 20 dol apiece.
SOURCE: When i put it in reverse it makes a loud clunk
Hi Ali,
This sounds like one or more of your motor/powerplant mounts is broken. Here is an easy test:
Have someone sit in the driver's sear with engine running and trans. in Park.
You stand in front with the hood open. Have them shift from Park to Reverse, and then Drive and back to Reverse and Park, taking time to stay in each gear and give some throttle while holding the brake pedal tight. This will rock or move the engine a certain amount as they shift through the gears and apply power lightly. It will move alot more violently with broken mounts.
If you have a clunking noise on Reverse shifts, you should be able reproduce this with the hood up and pinpoint the noise and/or sight the faulty motor mount with a friend's help. Good luck, I hope this puts you on the right track to fixing this annoying noise.
Sincerely, Tater Todd
