Question about Xerox Phaser 8500/DN Printer
Display Screen not available
The display screen is not available for us to get to the diagnostics menu. Does anyone know how to get the screen back??
  • amandaconnel Dec 11, 2008
    We ended up calling Xerox and they are sending a new display screen. Hopefully that will work!
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
The control panel has gone bad and must be replaced (part# 848K06552). This is a pretty easy fix. Here is a video that shows you how to replace this part. Iteminc.com has these in stock and ships same day
Posted on Jun 21, 2011
I have the same problem.
I don't know why
Xerox gave me a new display on the warranty.
(even if the guarantee had been exhausted)
They said it was a fairly common problem
Posted on Dec 11, 2008
Why is my laptop screen black during startup?
I recommend you to connect an external monitor and check if there is display on it. Press 'Windows' + 'P' on the key board to get display on the external monitor.
I also suggest you to run diagnostics on display. To test the display shut the system down, next press and hold the letter 'D' on the keyboard and press the power button. This will initiate diagnostics on the display. Please check if the colors are displayed across the screen without a problem.
You may also try this step that is shut the system down, remove the battery and disconnect the ac adapter, press and hold the power button for 20 to 30 seconds. Now connect only the ac adapter and wait for 30 seconds , press and hold the Fn key on the keyboard and power on the system. This will run diagnostics on the hardware components and also the display.
check also:
Please let me know if there is any light on the keys shows below:
5557.led-status.png-
if any of these are flashing in a sequence
please reply back with results
Jun 08, 2014 | Dell Latitude E5500 Laptop
Dell latitude E/6400 blank screen worked yesterday
run the dell diagnostic by turning the laptop on and tapping F12 key when you see the Dell logo
keep pressing F12 to enter the Boot Menu
* When the boot device list appears, highlight Diagnostics and press Enter
* The computer begins to run the Pre-boot System Assessment, a series of embedded diagnostics that perform initial testing on your system board, keyboard, hard drive, and display
* If the Pre-boot System Assessment completes successfully, you receive the message Booting Dell Diagnostic Utility Partition
* Press any key to continue
* Press any key to start the Dell Diagnostics from the Diagnostics utility partition on your hard drive
* After the Dell Diagnostics loads and the Main Menu screen appears, click the button for the option you want to run -
Express Test = Performs a quick test of devices. The test typically takes 10 to 20 minutes and requires no interaction on your part
Extended Test = Performs a thorough check of devices. The test typically takes 1 hour or more and requires you to answer questions periodically
Custom Test = Tests a specific device. You can customize the tests to be run
Symptom Tree = Allows you to select tests based on a symptom of the problem you are experiencing
* When you have finished running a test, close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and reboot the computer, close the Main Menu screen
during the test it will beep and display colored bars then ask your if the colored bars were displayed. to press Y for yes and N for no
this test the graphics/video chip on the computer to see if the hardware is working.
You can also connect it to an external monitor like a monitor that comes with a pc.Then press and hold the "FN" key and press the F8 (CRT/LCD) key to toggle the external monitor. if the image is displayed in the monitor then it can be a lcd screen or lcd inverter in laptop.
hope that helps
Feb 27, 2014 | Dell Latitude D630 Intel Core 2 Duo T7250...
My TV lost its wide Screen display two days ago. It Screen Menu is not available (only for VGA, whatever that means). How do I restore wide screen display?
VGA is an interface used between a computer and monitor. You need to go through your main menu and look for 'Input' and change it back to whatever input you normally use, such as 'Cable' or 'Antenna.' Depending on how your remote is designed, you may have a button marked 'Display' which gives you access to input selection.Right now, your set is looking for input from a computer and is expecting to see signal from a 15-position connector which you probably have never used.
Nov 30, 2011 | Grundig GU19WDVDPCX 19 in. LCD TV
I have an HP DV9000 laptop and did a presentation yesterday. When I arrived at the site I had to attach the display to an LCD projector. I connected the project via a porft connector, I believe that...
I think it's probably FN+F8 that may do this on the HP laptops. The key should have a little icon on it in the same color as the function key (typically blue) that will toggle the screen from the laptop screen to the external. There are usually 3 modes to this toggle
1. Laptop screen only
2. External screen only
3. Mirrored on laptop screen and external screen
So try toggling with the FN+F8 key combination.
Also you can probably start up in safe mode to disable the external VGA toggle.
When you see the HP Splash screen, start tapping the F8 Key to bring up the boot menu. From there choose safe mode and see if you get the video back in safe mode....After that reboot and see if it will bring up the video in normal viewing mode.
Good Luck
Mar 23, 2011 | HP Pavilion dv9005us Notebook
I don't know how to change my screen saver
  • Click the Start menu button. Next, click on Settings and then on Control Panel.
  • 2
    Double-click on the Display icon (or on the word Display). This opens a window called Display Properties.
  • 3
    Click on Screen Saver. You will see a window with choices related to your screen saver.
  • 4
    Click on the Screen Saver list box to view the screen savers that are currently installed on your computer . Select the one you want by clicking on it.
  • 5
    Click Settings to adjust factors such as the speed, size and color of the screen saver that you want to use.
  • 6
    Click the Preview button to view your new screen saver. If you are not satisfied, go back and change the settings or select a new screen saver from the list of those available.
  • 7
    Decide if you want to password-protect the screen saver or to set the amount of time that will elapse before the screen saver comes on, and enter those changes.
  • 8
    When you are satisfied, click O
  • Oct 16, 2010 | Computers & Internet
    Magnavox 32'' LCD, Menu being displayed on the screen all the tim
    Magnavox = Philips,for some sets there are software update's available.U can update te TV via USB.
    Dec 08, 2009 | Televison & Video
    Canon Powershot SD1000: LCD screen display
    Hopefully you resolved this already. If not, push the "DISP." button left of the MENU button. Pushing it gives you three options: black (for discreet shooting so your LCD doesn't give garner dirty looks from fellow concert goers), liveview, and liveview with info overlayed (shooting mode, ISO, etc.). Good luck!
    May 05, 2009 | Canon PowerShot SD1000 Digital Camera
    The language on my printer screen appears to be Chinese. It used to be English, but my grandson pushed buttons and I don't know how to get English back. Help-- it is a Lexmark X3470.
    How to Change the Display Language on a Lexmark X3450/X3470/X3480
    1. Turn off the power by pressing the Power button once.
    2. Then press and hold both the Start button and the Power button.
    3. Once the screen displays Mfg Menu enabled, release both buttons and wait until the display shows Copies:1.
    4. Press the Mode button three times. All the indicator lights will go out and the screen will display LCD button test.
    5. Press the up arrow (pattlnk_692006_1047-up%20arrow.gif ) once. The screen will display Clean NVRAM.
    6. Press the Start button once. The printer will be reset. Afer a few seconds, the message Language: English will appear on the display.
    7. Press the up arrow (pattlnk_692006_1047-up%20arrow.gif ) until you reach your preferred language. Press the Start button once, then the Menu (pattlnk_762006_1319-menue.jpg ) button.
    8. Turn the printer off and then back on to disable the manufacturer menu (Mfg Menu). NOTE: After clearing the NVRAM, you will need to print an alignment page. The printer LCD will display this while the alignment is being performed.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Mar 08, 2009 | Lexmark X3470 All-In-One InkJet Printer
    I ccannot find a screen display menue. I have seen it before. My screen needs to be changed
    Tom Tom can do lots to things but they are not all shown on the Main Menu Screen initially. This is done to save space on the screen. If you are able to get to the Main Menu, Tap the change preferences Icon. You should then see an option called "show all menu items" On this menu, you should find all the options available including one called "Turn Off Map Display" Tap this choice....You should then be able to select what you want your map display to do. Thanks for using Fixya.com!
    Jan 27, 2009 | Tomtom ONE GPS Receiver
    Display goes haywire...
    The easiest solution is remove the hinge cover and check if the LCD cable got cut.
    http://tinyurl.com/oyrzt
    follow the following instructions to replace display assembly
    http://tinyurl.com/hbk5x
    You can also run diagnostics.. power on and press F12 on dell logo slowly 5 times
    Select diagnostics and follow on screen instructions.If the LCD fails its time to replace the same.
    Apr 06, 2008 | Dell Inspiron B130 Notebook
    Xerox Phaser  8500/DN Printer Logo
    101 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
