Question about Panasonic NV-HD680 VCR
Tape Ejects Immediately
As soon as I insert a tape, it starts checking its ID then ejects it immediately without playing (no matter what the tape). Any clues as to what I should check? There's nothing obviously broken or obstructing in the mechanism.
    Novelist:
    Champion:
  • 275 Answers
There are normally 2 causes. One is some obstruction in the tape path. Please open the cover of the VCR and shake and see for foriegn objects. Nothing??? Then there is one more possibility - Belts are loose.. Check the Tape Loading motor belt.Is it slack? This can happen over time.Change the belt.
Posted on Feb 07, 2007
When I put a tape in, it immediately ejects it.
Try to find out, where the tape drive stops and why. If there is debris in the recorder it could fake the tape is not going where the recorder expect it to go. There are lots of reasons why the recorder will spit out the cassette. In the first place it does so, to protect the tape for damage, because the sensors don't sense a normal flow of the tape.
Mar 04, 2015 | Emerson EWV603 VHS VCR
WHEN INSERT THE VHS TAPE TO VCR IT EJECTS BACK... WHAT MAY BE THE PROBLEM?
Hi, depending on the age, chances r that some components r worn out or the eye sensor needs cleaning or sdjusting.....
Jun 21, 2014 | Panasonic Televison & Video
Combi TV/VCR When video tape is inserted TV immediately goes onto "emergency mode" and won't play the tape. Sometimes ejects it str away. TV was 2nd hand so I don't have a manual for it.
The Video portion of the set requires a belt and possibly a drive pulley.
When the tape is inserted, the deck moves it forward then back and if it can't because it has lost its drive due to a belt broken stops dead. Hence "Emmegency mode".
Feb 28, 2011 | Televison & Video
Tape ejects when put it in. Will not play record rewind etc. It just immediately ejects.
Check the timing of the gears. they tend to slip.
Find the loading motor. It should look like a big battery with a worm gear on the side. manually turn the gear backwards and forwards a few times. Hope this gets you watching tapes! GOOD LUCK!
Jun 17, 2010 | Sony SLV-N500 VHS VCR
When I insert the tape it immediately ejects it. If it stays in and I set the timer, when the timer comes on it ejects. I can occasionly get a tape to stay in and record or play.
This could be a mode switch problem, sometimes you can get it to work by spraying the switch with Servisol Video 40. Sometimes it has to be replaced in which case you will need the service manual.
The Mode switch may look like these:
Apr 11, 2010 | RCA VR555 VCR
Inserted cassette doesn't play and immediately ejects
Could be a mode switch problem, you could try Servisol video 40 on the switch, or it might need replacement.
Mar 03, 2010 | Panasonic PV-V4022 VHS VCR
When I insert a VCR tape, it automatically and immediately ejects. HELP.. :-)
I rather suspect a mode switch problem. Sometimes you can clean them with Servisol Video 40, but it may have be replaced. Check also the carriage (the bit that lifts the tape) for damage.
Dec 21, 2009 | Orion VR213 VHS VCR
VCR continually tries to eject the tape after it is inserted
If you have cleaned the head with a good head cleaner and you are still having a problem...the belt is probably worn. A good head clean should fix the problem.
Mar 18, 2009 | Zenith VR4127 VCR
No remote for Goldstar 8mm VHS VCR recorder player
I have an extra remote to that unit if you would like to buy it. shesteasing@yahoo.com
Dec 06, 2008 | Goldstar GVR-DD1 VHS VCR
The tape ejects immediately after inserting tape
your m-chassis has a problem with it and when we get these we replace the chassis and adjust them you should send to canon for repair or a qualified tech. sorry
Dec 01, 2007 | Canon ES8200V Hi-8 Analog Camcorder
Panasonic NV-HD680 VCR Logo
1,114 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
