Question about Car Audio & Video
Im tryin to wire a maxp124d subwoofer and want to do it correctly
  • stenco May 11, 2010
    are you starting from scratch? running wires new head unit?
    Problem Solver:
  • 6 Answers
What do you need to know that you dont already know
Posted on Dec 04, 2008
I need to wire 2 12" DVC Lanzar MAXP124D to an 8 ohm load. Had it wired at a 2 ohm setting and it would over heat my amp. So tried to wire it to 8 and it wouldn't work. Need help.Thanks.
Your 8ohm channel is fried why happened was you ran 2 12s in an 8ohm load and turned it down to 2ohms the speakers was pulling all the power and that made it over heat and when it over heated it fried you're amp. It ain't no good you can't fix that
May 11, 2015 | Lanzar Car Audio & Video
I need a wiring diagram for 2013 chevy silverado tryin to instal rca converter
You won't find that even at a repair shop
The Data bases won't likely have 2013
Try 2012 from Alldata,Mitchell or Identifix
Mar 04, 2013 | Cars & Trucks
My touch screen isnt working properly on my pioneer avh 57000
you by-passed with a toggle switch? correct? pioneer older units need to have a ground introduced each time power is supplied,,,on off on,use a two-way toggle switch
Jan 27, 2013 | Car Audio & Video
Wiring diagram avh-p6300bt
i have a pioneer AVH-P6300BT but im not sure if i have i connected correctly with my amp. my speakers just dont seem to be pushing the power i know they can. so for starters which wire is the remote wire? i have the RCA's connected to the one that is labeled"Subwoofer output" is this correct? The wiring diagram also talks about connecting to the violet and violet/black wires for the subwoofers whats this for?
Apr 30, 2012 | Pioneer Car Audio & Video
Im tryin to hookup aftermarket subs but the lineout converter isnt working, it sounds like alot of treble comin outt of the subwoofers. is there anyway to find a low frequency wire to tap into for the subs
instead of finding a low frequency line to attach to your LOC (line output convertor) use the built in crossover on yours subwoofer amp or an external crossover to limit the frequency range going to the subs
May 07, 2011 | Car Audio & Video
I have no idea what to do with my panzer maxp124d subwoofer. There's like 8 terminals on each sub and idk how to wire them
Here are the specs for your speaker.
  • Dual 4 Ohms Nom. Impedance
  • Fs: 40Hz, Qms:5.0, Qes: 0.90, Qts: 0.75, SPL: 84(dB), Vas: 5.204(Cuft)
  • That should help you design a good box.
  • The eight terminals are actually 4 with double slide ons for each. Each side has a + (positive)
    and a - (negative) with 2 connectors at each connection point.
    It is a dual voice coil thus 2 sets of inputs.
    If you have a 4 ohm amplifier then you are ready to go with a left to one side's terminal and a right amp output going to the other. If you have 2 speakers this can get wild because you can run them in parallel
    or series and reduce the impedance to 2 ohms if your amp is 2 ohm stable. If not-dont do it!
    You will burn the amp up. See #58 on the right sidebar of this site. It will teach you how to get the most
    from your setup. Bookmark the site. It has every kind of knowledge you need for audio or electricity.
    Look for the DVC (dual voice coil) info.
    "The image below shows the DVC speaker wired to both channels of a stereo amplifier. Each channel of the amplifier drives a 4 ohm load. " This looks like what you have to do.
    Mar 15, 2011 | Lanzar MAXP124D Car Speaker
    I have a 2002 olds alero and im tryin 2 hook my
    Ok to start you need to go to this website and you will have to get the factory adapter for your radio so it can be modified.
    . and also check this site this wiring diagram will help.
    Apr 16, 2010 | Car Audio & Video
    I am getting distortion at all levles of volume from 4 different lanzar maxp124d subwoofers. no matter how i wire them or what style box i've tried i get the same results.
    Its your amp. It may be pickin up noise from your car electrical system. Make sure your amp power wire doesn't run along side your RCAs back to the amp. Or you could be pickin up alternator wine, its a problem with the way your wires are run, unless your amp's just producing a bad signal, try turning your amp input gain a little lower, to muck juice into the amp can fuzzy up signals. If you can't find any thing wrong take your amp to an audio shop and they can test it to see if its distorting always, or just cuz of your wiring... Hop this helps you out.
    Sep 16, 2009 | Lanzar MAXP124D Car Speaker
    Car Audio & Video Logo
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
