Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Get a Professional
Find a Solution
Most Common Problems for:
My reddy heater smokes and
speterson428 on Dec 03, 2008
My reddy heater smokes and then shuts right when you plug it in , If you take off the top cover it will work
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Dec 06, 2008
Not Rated)
mboyce4
Rank: Apprentice
Rating: 0%, 0 votes
Look at the fuel coming out at the spark pug, if its a spray and not a fog try replacing the nozzel, for the R 55 they are less than $20.00 from Reddy parts.com
Was this helpful?
Yes
No
Related Problems
I have a Reddy Heater 35,000 BTU kerosene heater. I used it...
I have a Propane Reddy Heater Model RLP50VA. When I start...
Heater will run as long as button is held in. This problem...
the nozzle is clear/new. I flushed and drained tank several...
Can you Help with these Heater problems?
shuts down when fan kicks on
Solve
my reddy heater 55 shuts off when the fan kicks on... why?
shuts down when fan turns on
Solve
i have a reddy heat 55 and when the fan turns on the heater shuts off... why?
heater turns on for a few seconds...
Solve
When I push the reset button the reddy heater 50,000 btu starts up runs for approx. 15 to 20... (More)
model r55a reddy heat kerosene,runs...
Solve
runs 1-2 minute then shuts off,restarts and does the same thing
it is a 35000 btu
Solve
it is a 35000 btu when it is running the flamme spits and sudduers. i ajust the two scews on the... (More)
Sponsored Links
Describe your Appliance problem:
Top Heater Experts
Rank: Guru Guru
Solutions: 702
Experience: Certified Master ASE Car and Truck Mechanic Certified AC mechanic Cert. AWS welder cert. Electrician
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
