Hanging while using internet
I am using windows service pack2 and 1 gb ram,INTEL D101 mother board,2.80ghz dual core processor.
my system is hanging while iam using internet ,i checked my ram by changing with other rams and also exchanged the new mother board in the shop and i checked the modem, i installed new windows and clened the hard disk every thing is fine but it was still hanging
can any one please tell me some solution
  • satya_ramu20 Dec 03, 2008
    then what can i do
    please tell me in detail
    Problem Solver:
  • 15 Answers
It is probably because your internet connection is slow or you lack bandwidth. You have a fast computer and if you've wiped the hard drive and reinstalled windows then its unlikely that it is a windows problem. Also if you're using a modem instead of a dedicated connection they do tend to be rather slow managing only up to 56k per second.
Posted on Dec 03, 2008
Which is the best graphic card for intel DG41RQ mother board
I have a motherboard intel dg41rq and intel core 2 duo E7200 and nvidia geforce 9500 GT and 4gb ram (DDR3).It will work with call of duty black ops 2 and FIFA 13.So your done.
Oct 02, 2012 | Intel DG41RQ Motherboard CPU Bundle - ...
I have a DG965RY mother board can i install a 1.6 daul core on that board and download windows7 and will it work
Yes, you can install a Pentium dual core processor on this mother board. Below is a complete list of the compatible processors for this motherboard:
http://www.cpu-upgrade.com/mb-Intel/DG965RY.html
Windows 7 will also work with this motherboard. Just make sure that you install a minimum of 2GB RAM for you to take full advantage of Windows 7's Aero feature.
Mar 23, 2011 | Intel DG965RY Motherboard
I can't install AUTOCAD 2009 in my windows XP computer.It asks to install direct 3D
Most probably your hardware ie graphic card do not support software requirements.
Autocad 2009 system requirements for Win XP.
32-bit AutoCAD 2009
Running under Windows XP:
•Microsoft Windows XP SP2 operating system
•Intel® Pentium® 4 processor or AMD Athlon®, 2.2 GHz or greater
or
Intel or AMD Dual Core processor, 1.6 GHz or greater
•1 GB RAM
•750 MB free hard disk space for installation
•1024x768 VGA with true color
•Microsoft Internet Explorer 6.0 (SP1 or higher)
If you are using AutoCAD for 3D modeling, you should bump up your system as follows:
•Intel Pentium 4 processor or AMD Athlon, 3.0 GHz or greater
or
Intel or AMD Dual Core processor, 2.0 GHz or greater
•2 GB RAM or greater
•2 GB of additional free hard disk space
•1,280 x 1,024 32-bit color video display adapter (true color) 128 MB or greater, OpenGL or Direct3D capable workstation class graphics card.
Hope it helps.
Mar 22, 2011 | Computers & Internet
I have intel dg41 rq mother board and i am facing a problem , when system heat too much it disconnected the network. when i restart or shut down the system it work properly but after some time internet...
Check the fans on the motherboard, are they all working?
Have you cleaned out the fans and heatsinks ?
Using compressed air, or even the blower end of a vacuum cleaner blow out the dust in the fans and the cooling fins of any large heat sinks, like the one over the processor.
It sounds like the machine is overheating, the dust is probably preventing air from circulating around the heat sink fins,
Nov 04, 2017 | Intel DG41RQ Motherboard & Core 2 Duo...
Pasos para instalacion de web camvx2000
Hola amigo primero que nada devemos saber que systema operativo usa tu computador Windows Xp Vista or Windows 7
Esta Web cam es configura automaticamente per piensa tambien en los requerimientos del su systema. aqui algunos tips.
Habla en espanol y solo pregunta ok
Techbelkin
System Requirements Operating System For Windows®-based PC
Requires a PC that meets the requirements for and has installed one of these operating systems
Processor Windows® 7
Mmimimum: Intel Pentium 4 (3 GhZ), 1 GB of RAM; recommended: Intel Pentium (Dual-Core 1.8 GHz), 2 GB of RAM, 1250 MB free Windows Vista®
Windows® XP with Service Pack 2 (SP2) or later
Other CD-ROM
USB 1.1 (2.0 recommended)
16-bit color depth or higher, 2 MB or higher video memory
Windows-compatible speakers or headphones Internet Broadband Internet access may be required for certain features. Local and/or long-distance telephone toll charges may apply.
Internet functions also require Internet Explorer® 6/7 for installation; 25 MB hard-drive space typically required.
Nov 03, 2010 | Microsoft LifeCam VX2000 Webcam
I want some information about Nvidia GeForce 9400 GT 1GB DDR 2
If you are using Dual Core the mother board you are using may have PCI Express Slot. So that you may install Graphics card. Only for particular lower end mother board doesn't have this feature. Any way tell me your motherboard make and model no. e.g., Intel DG31PR, 945GNT, DG41TY etc.,
Oct 04, 2009 | Computers & Internet
My system is hanged after few minutes
Well the issue could either be with the bas sectors on hard disk or faulty RAM or a burned capacitor on the motherboard.
The very first thing I would suggest you is to reinstall windows operating system.If the issue persists then run the system with another RAM and observe the performance.
if the issue persists then it could be with the motherboard or the power supply. Manually check the capacitors on the board for any leaking or faulty capcitors.
Let me know if you need any further assistance
Aug 08, 2009 | Intel Motherboard
Is it compatible a intel dual core processor to a
Hi..
If you want to upgrade you unit be sure that the motherboard socket are totally fix with the processor. The compatibility is important because if it is not compatible the motherboard can not support the processor,
Good luck !!!
Regards
PCmania
Jul 15, 2009 | ASUS P5PE-VM Motherboard
Intel Dual Core 2.0 GHz Sytem hangs after boot
During your boot screen press the F8 key to boot into safe mode. If that gets you to the desktop run virus/spyware scans. Reply with any results.
Jan 12, 2009 | Bravo Intel Dual Core E2180-2.0GHz 2GB RAM...
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
