Question about Kenwood KDC-516S CD Player
Lights up but will not play music
The RCA cabels going to my amp rubbed aginst the frame behine the head unit and crosed out. Now it will not play sound but will come and act like it is.
Check the RCA cables input,example your RCA input is AUX and the input selection in the control pannel must be selected AUX.
Posted on Mar 01, 2007
SOURCE:
I have a BA PV 800 sub that powers on but will not play. I have a static type of sound coming out of the unit that appears to be in line with the music playing. Any ideas on what might be going on?
Subwoofers are just mono amps. So if it not producing any sound then the most likely cause is the failure of the main amp that does all the work.
Mar 19, 2017 | The Audio Players & Recorders
Donladed music from computer but will not play on frame
I had the same problem. Certain digital frames will only play certain music files. The one I had would only play mpeg4 & avi files for music. If its not noted in the instructions, serach by the make & model of your digital frame.
Jul 29, 2014 | Photography
Hi, i am going to be opening a cafe soon and have purchased a secondhand yamaha rx-v1000rds amp. i need to connect my ipod to it so that i can play music from it.... what cabel do i need to do this? The...
First, no matter what, you need a manual and you need to READ IT.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-RX-V1000RDS-Receivers-manual/id/319bh926/t/2/
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
For convenience you could use the front panel VIDEO AUX connector if you want.
May 27, 2011 | Yamaha Audio Players & Recorders
Amp stopped playing riding down the road, power light turned off. came back on when i unplugged the rca's and cuts back off when i try to plug them back in.
Faulty RCA cables, Or worse possible solution is if your amp stopped playing when it was pumping at high volume, you may have blown the RCA connectors inside your head unit Or inside your amp. If possible try another known good working amp with the wires you already have, If same happens, try different RCA cables. If problem persists after trying these, Its your head unit RCA connecters or amp RCA connectors. To rule out your amp connectors, try your amp in a friends car if possible, to rule out your head unit, try another good known working amp in your car with the wiring you already have
Mar 03, 2011 | Kicker ZX300.1 Car Audio Amplifier
Got this amp from a friend and want to wire it up to my Sony head unit. The HU does have pre-out in RCA plugs. please help. I have tried it with: RED - stereo Amp Rem In YELLOW - 12V BLACK - -12V...
Senshin,
Red- 12 volts switched (ignition)
Yellow- 12 volts constant
Black- Ground
Blue/white stripe- remote amp turn on/ power antenna
If you have any orange wires there for the Illumination dimmer. (head unit dims when you turn the lights on). The white and gray are front speakers and purple and green are for the rear, solid being + and black striped being -. (gray and purple are right channels)Make sure that the RCA plugs go to the input side of the amp. I hope this helps, Ray
Oct 11, 2010 | Metra 705512 Ford Prm Snd Amp Plug Wiring...
I hooked up a 4 ch alpine amp MRP-F600. The back speakers play nice but the front speakers play very low. What could be the Problem?
1)When you connected the amp to the head unit, did you run two pairs of RCA cables for front and rear reference or did you only run one set of RCA cables from the rear out to the amp?  2)If that's not the case and you did ran two sets, on your amp, swop the rear and front RCA cables. If the rears go quiet and the fronts are loud you now know the issue is either in the cables or how the head unit is set up. If the fronts are still quiet, check your Amp's gain, frequency and filter setter settings (if available). If those settings don't change anything you may have a faulty amp. 3)Check speaker connections, seems trivial, but you never know.
Message me back if nothing works and/or you get stuck.
Ciza
Nov 04, 2008 | Alpine Car Audio & Video
My car amp works produces distorded noise . As I plug in the rca cables i noticed that if just the tip of the connector touches i get a good sound but if i insert the whole connector it becomes distorded...
You have a grounding issue.
The RCA inputs of the amp are many times NOT tied to chassis ( the chassis of the car ) ground.
Same goes for the RCA outputs of your head unit.
The speaker outputs of your amp SHOULD NOT EVER be tied to chassis ground.
  • make sure that no speaker wire from the amplifier is touching or attached to ground.
  • Make sure that your amplifier ground (GND )( of the 3 power inputs.....GND, +12V, Rem) is securely mounted to a bare metal spot on the frame. Best practice is to have the amp GND, and the head unit GND at the exact same physical point.
  • Make sure that your RCA cable shield ( not the center tip, but the part around it ) is not touching the chassis.
  • Make sure that you have not nicked the wire while installing it and are accidentally getting a connection to the frame of the car.
  • Make sure that the head unit is grounded properly.
  • IF for some reason you have an equalizer between the head unit and the amplifier, make sure it has its own switching power supply INSIDE the EQ.
Bad grounds are a pain to troubleshoot......best of luck....Rob
Mar 17, 2008 | Audio Players & Recorders
Alpine
If this occurs with the head unit plugged directly into the amp (no signal processors inline, you probably have open shields on the head unit.
To check the shield ground, disconnect all RCA cables from the head unit and measure the resistance between the RCA shield on the head unit and the case of the head unit. It should read ~0 ohms.
Dec 03, 2007 | Car Audio & Video
Head unit is on but no sound coming out
I Had That Happen To Me Its A Ground Problem. Check The Negtive Speaker Terminal And The Ground Wire Runing To The HeadUnit This Should Fix It.
Dec 17, 2006 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KDC-516S CD Player Logo
111 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
