Question about Samsung CXJ1964 19 in. TV/VCR Combo
How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I have a Samsung TV/VCR 19in Combo I have lost the remote and wish to use a playstation with it. The TV has a scart port and an additional AV point. Yet with out the remote I can not use. Is there a combo of buttons I can press on the front panel to change to AV input? I have tried an universal remote, however it only works on the VCR setting and does not allow AV change.
  • 8 more comments
  • desidon Nov 11, 2007
    i lost the remote control.
    How to change channel?
    any combo buttons
    Thanks in advance
  • ccrthomps Nov 28, 2007
    Want to play game system, but the remote im using won't access the AV/Video 1(?). Is there a certain remote i need to use?
  • Jaidkat Jan 27, 2008
    Pongo83, I have several universal remotes... what brand/model was the code 037 meant for on your remote? Just wondering if I try the code for the same make/model on the universal remotes I have it might do the trick.
    Thanks.
  • Anonymous Feb 22, 2008
    cant use av con on tv have no remote
    yes
  • 2pink4u Mar 31, 2008
    I have the same problem, I have the samsung cxj1952 and I can't get the dvd player to work with the tv. I guess because I don't have the remote to switch the input.
  • stoner025 Nov 01, 2008
    i have this problem. i want to use my ps2 but i cant change the tv to video 1.
    help.
  • ricej Nov 20, 2008
    I have this same problem, is there any way that you can do it without buying another remote?
  • dragon_air20 Feb 28, 2009
    I want to play on my Xbox but i broke my remote and can change it to AV its set on TV all the time.. HELP please! >.<
  • Anonymous Mar 14, 2014
    Bought this combo set used with no manual or remote? Is there a fix for this or should I dump it?
    Can this be set up without a remote?
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.How can I turn to AV without a remote control (Sam - 98fe8a9.jpg
Posted on Jan 19, 2008
Trying to take tv off of av screen without the remote lost it
Turn off the device connected to the av output, then turn TV off and on again!
Aug 05, 2015 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Looking for code for my sylvania tv for my one for all access 4 u remote
Hello
Universal remote codes for Sylvania TV with One for all URC - 3300 remote control are:
0054, 0030, 0171
Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press DVD/VCR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once.After programming
a DVD Combo device, you will be able to control channel
selection, volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY
Repeat steps 1 through 5 for each device you want to control.
For future reference,write down each working device
code in the following boxes
OK.
Jul 13, 2011 | One For All URC-3300 Remote Control
Hi my samsung remote is damaged.I have a one for all tv universal remote & have lost the instuctions to program the remote to the tv. I need the instructions program my one for all tv remote to my...
Hello
These are the programming proceedings for a one for all universal remote control.
[1] Turn on a desired device (e.g.,VCR or
DVD player) and, if applicable, insert
before proceeding.Highlight or write down the
codes and device you wish to program before
starting step 2.
[2] On the remote control,press a device key
once (i.e., TV,PVR,DVD, CBL/SAT,AUD,or VCR).
NOTE: To program control of a cable box or
satellite receiver, press CBL/SAT once.
NOTE: To program control of a CD player or
audio receiver, press AUD once.
NOTE: To program control of a TV/VCR Combo,
press VCR once.After programming, you will be
able to control channel selection, volume, and
VCR functions.
NOTE: To program control of a TV/DVD Player
Combo, press DVD once.After programming,
[3] Press and hold SET until the LED (red light)
blinks twice, then release SET.
[4] Use the Manufacturer's Codes to locate the type of device and
brand name and then enter the first fourdigit
correctly, the LED will blink twice.
2 through 4 and enter the same code again.
[5] Aim the remote control at the device and
press POWER once.The device should turn
off. If it does not, repeat steps 2 through 5,
trying each code for your brand until you
key, press the (Play) key.
[6] Repeat steps 1 through 5 for each device you want to control.
OK.
Jul 03, 2011 | Televison & Video
I have samsung combo tv/vhs, lost my remote control, I have bought new one universal remote, nearly everything working except AV option,most important for me, TV modes number is TI-20P1, I need correct...
I have a samsung TI 20P1tv/video. I was told I would play dvd also but every time I load one it says 'bad disc' what does this mean as the discs I load work every time with other tv.s
Am I doing something wrong? I have not got a manual .
I would be grateful for any help
Juliet
Nov 13, 2010 | Samsung VR8559 VHS VCR
A/v channel
this have av channel and the av port is at the side front view of the television and can change it to av by using the remote control of the television.
Take care..
May 28, 2010 | Samsung CXJ1352 13 in. TV/VCR Combo
I lost my remote control for my tv/vhs panasonic omnivision
how do you access the menu without the remote panasonic omnivision tv vcr combo
Mar 31, 2009 | Panasonic PV-C2010 20 in. TV/VCR Combo
you might try going to channel 00
If you cannot just dial the number 00, go to channel 2 and then channel down.
Does not always work, but without the model number of the TV it is hard to advise further
Mar 12, 2009 | Televison & Video
Lost remote for akai tv/vcr/dvd set
I think you should look over the Internet to buy one from places like Ebay for your brand of TV.
Apr 07, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
RCA x-100 remote lost is this one all compatible?
PROGRAMMING DEVICE CONTROL
The One For All 3 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, and a Motorola
cable box.To control devices other than the default brands,perform the following
steps; otherwise skip this section:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if
2. On the remote control,press a device key once (i.e., DVD/VCR,
CBL/SAT,or TV).
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes (starting on page 18) to
5. Aim the remote control at the device and press POWER
you find one that works. If it still doesn’t work, try
NOTE: If the device does not have a POWER key, press PLAY.
6. Repeat steps 1 through 5 for each device you want to control.
Here is a link to your manual:
http://www.ofausa.com/remote_manual/CTGA...
Dec 04, 2007 | One For All URC-3021 Remote Control
WHITE-WESTINGHOUSE TV/VCR COMBO NEED CODE
The code for the TV is 0623 but to use the TV/VCR button to change mode from line to TV the code is one of the following 0179, 0451, 0463, 0624 or 0278. The 0623 only activates the menu but doesn´t let you change Air/Cable mode without first changing the Line/TV mode by pressing the TV/VCR or Line input button on your universalk remote with one of the other codes.
Oct 28, 2007 | Zenith ZN110 Remote Control
Samsung CXJ1964 19 in. TV/VCR Combo Logo
10,197 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
