Reddy Heater-30-55,000 BTU Variable
Problem for Reddy Heater-30-55,000 BTU Variable
165,000 forced air reddy heater
By speterson428 on Dec 03, 2008
Plug in, smokes, then kicks off. Will run if the top cover is off.
Solution #1
posted on Dec 03, 2008
Not Rated)
tbugger
Rank: Guru
Rating: 90%, 70 votes
It would help if I knew the model of heater because there are 2 different technologies that are used in Reddy Heaters. Having more information could affect my answer.
Generally, if a heater runs with the lid off but shuts down with the lid on, its a sign that either the air pump pressure is not to specs or the nozzle is restricted or worn out. Desa International, the manufacturer, recommends annual replacement of the nozzle, but this is arguable, depending on the age of the heater.
I am pasting a document that I've had around for awhile, that may help:
"A worn nozzle creates a spray pattern, where a good nozzle creates a fog. With a coarse spray pattern poor combustion results in an off color flame, . The photocell doesn’t like the color, sends a signal to the computer which shuts everything down. That’s the job of the electronics. On HSI heaters it is all about correct flame color , not just flame.
The part where you write "If I remove the cover again it runs fine" is a symptom of a bad, worn, or restricted nozzle. Remember- the ignitor only stays red for 5 seconds, then the flame keeps itself lit. The nozzle's pattern is a cone. Lift the lid & the pattern widens (aerodynamics) - replace the lid and the cone narrows & possibly distorts then the flame goes out.
This nozzle rule will only apply if everything is correct as far as fuel delivery applies. The pump pressure must be correct- not almost correct. Set the pressure with a low-pressure gauge that registers12-15 psi max. A gauge with a higher scale just will not read close enough to satisfy the system. If the pressure is not correct, the above rule will not apply. Instructions for setting the pressure can be viewed at http://reddyparts.com/pressure.htm.
In addition, a fan can cause the same problem if damaged or mis-matched to your specific model.
I must mention that any air leaks on the pressure side (or vacuum leaks on the fuel line, for that matter) between the pump and the nozzle will create a rich/lean mixture at the combustion chamber, creating an off-color flame."
Good luck, I hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Reddy Heater-30-55,000 BTU
Questions and Unsolved Problems for Reddy Heater-30-55,000 BTU
Do you recommend Reddy Heater-30-55,000 BTU Variable?
Answer
Answer
i need a wiring diagram for reddy heater model r55bt
Answer
I have a Reddy heater 3500 that was given to me. I have no idea as to the technical aspects of this... (More)
Answer
I have a reddy heater that the switch clicks but it won't ignite?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Reddy Heater-30-55,000 BTU...:
Top Heater Experts
Rank: Guru Guru
Solutions: 1212
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Heater Experts
Top Heater Repair
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
