Question about Durabrand Portable DVD
Where can I buy a new connection cord.
I need to purchase a new connection cord that goes between the master unit and the slave monitor.
  • Kathy Shuller Apr 24, 2009
    why do you think this cord is the problem? How did you troubleshoot the system to this cord?
Try Radioshack. Ask for a 'B' tip adapter and an adaptaplug. You will need to purchase 4 'B' tips to go with the plug.
Posted on Dec 12, 2008
How to chek if it is master cylinder or slave cylinder problem?
check for brake fluid leak at the piston rod dust cover boots . on both cylinders ,the wet one will be the problem . the master cylinder can have a problem with out leaks, hold pressure on the pedal if it creeps down replace it. . may be it needs to be bled and oil top up.
Aug 02, 2014 | Vehicle Parts & Accessories
I have 94 Mazda mx-3 for the past month or so I've been having problems with my clutch and I notice a big wet stain on the floor mat and carpet I assume its the master cylinder or slave cylinder but I am...
It's leaking on the driver's side? That would be the master cylinder bolted onto the firewall. You will have to replace with a new or remanufactured clutch master cylinder. When the seals go out, the whole unit must be rebuilt. The store will give you a discount if you bring in your old one for exchange.
The clutch slave cylinder will be down on the transmission bell housing. Follow the small steel line from the master cylinder. It goes right to the slave cylinder.
Pretty easy to change out the master cylinder. Remove the steel line, unbolt unit from the firewall, then under the dash, there's a rod from the clutch pedal to the master cylinder. Just undo the retaining clip or pin holding the rod to the pedal. When the new unit is installed and filled with fluid, then you get to learn how to bleed the hydraulic clutch at the slave cylinder-the fun never stops.
Oct 31, 2013 | Cars & Trucks
Won;t start while clutch pressed but will push start
The clutch master cylinder must have gone out, the seals in it have failed. The clutch master cylinder (next to the brake master cylinder) gives you hydraulic pressure so the clutch pedal can operate the clutch.
You can buy a new clutch master, a rebuilt unit, or yours can be rebuilt with new seals. Save time and money and buy a rebuilt or remanufactured unit. Once installed, you bleed the system down at the clutch slave cylinder, mounted on the transaxle.
Jul 15, 2013 | 1989 Honda Prelude
How do you connect two hard drives to a computer?
1. For SATA, you just need a second SATA cable to plug it in and a power cable from the power supply.
2. For IDE, you will need a second IDE cable to plug the second hard drive, AND you will have to set both hard drives jumpers either to cable select or one Master and the other one Slave, based on which one you have the operating system.
Nov 12, 2010 | Maxtor Hard Drive
Replace clutch slave cylinder S10 89 2.5 standard
I would not replace clutch slave, take my advice and replace the master and slave unit. Though for the moment this is more expensive, unless you have a perfect master cylinder, the new slave cylinder will destroy it in a hurry. It is cheaper to buy them together rather than separate.
Sep 09, 2009 | 1988 Chevrolet S-10
Can't get my BL-PA300KTA to connect. I have plugged it in and pressed the Setup buttons (within 3 seconds Mater and Terminal). The PC, LAN, and Master lights are ligting up as they should (I believe), with...
I use these and the previous model without any issues.
1. They must be plugged into the wall socket. It's okay to use an extension cord between the adapter and the wall, but never a surge suppressor or UPS
2. The master need to be connected to you router
3. To test your connection do the following
-Plug the master into the wall at the router location
-Plug the slave into the outlet where the computer will be
-Press and hold the setup button on the slave unit only for 3-5 seconds
The leds on the slave will flash for a second or two and then turn solid.
The number of solid lights you see tell you what your connection speed will be 0-no connection, 1-<10MB , 2=-10-30MB, 3->30MB.
I always unplug the ethernet cables from the adapter when testing, but I don't know if that is necessary.
I have never gotten less then 2 leds in my house, but it's new.
Sep 01, 2009 | Panasonic Network Camera HD-PLC Bridge...
I need to purchase a new connector cord to connect my montior to my computer. My cat chewed my old cord and it's not working properly. Thank you.
The monitor uses a widely-available standard VGA cable with what are called D-sub connectors at both ends. You should be able to find one at a large office supply place like Office Depot or a retailer like Best Buy. (If you're outside of the US, you probably have similar stores in your area.) You can also purchase the cable online. Here is a suitable cable from, a company I buy from frequently. I've just used this as an example. There are many other sources.
May 03, 2009 | Computers & Internet
Hard Drive Installation
Hi emceedrive, I gather you are using ATA/PATA IDE hard disk drives? Each hard disk drive has a large white sticker on it. Listed there are pin settings to set the IDE to Master or slave & Master with a slave. (We want to leave you're drive with windows on it alone). Not changing its jumper or not adding a jumper for now. We are not hooking up you're second drive just yet either.
Oh, please you're not an idiot either.
Unplug the power cable from the PC & open you're case.
Please open you're ASUS P4P800 SE manual to section 2.2.3 Motherboard layout. We want to connect the data cable to SEC_IDE1 first because once PRI_IDE1 is connected you will not be able to connect SEC_IDE1's data cable up to the DVD drive bay.
So grab a data cable for you DVD drive. It may have three connectors on it. Plug the connector that is the furthest from the other 2 connectors on the cable into the motherboard slot named SEC_IDE2. The data cable only goes in one way. Run the remainder of the cable up to the DVD player but do not connect it to the player yet. It is ok to fold the data cable which will help in routing it upwards to the DVD bay. Than connect the data cable to you're primary master IDE drive. (The one with windows already installed on it). The data cable should look just like the DVD data cable. Again you want to connect the furthest connector on the data cable into the MB slot named PRI_IDE1.
For now it’s best not to install the drive into the drive bay. Stand it up next to your case or lay it down flat with a sheet of paper under it. Connect the power cable to the drive. Plug in the PC's power cord & power up the PC & start pressing the delete key every two seconds until the bios main menu loads. You should see the Primary Hard disk drive listed at the main menu. Now go to the title Boot in the bios. Open boot order. The boot order of the devices should be as follows.
Boot device 1. (Floppy Disk Drive)
Boot device 2. (DVD Disk Drive) [None shown it’s not connected to the system].
Boot device 3. (Model number of your Primary IDE Master HDD).
Once this is set, save the bios & exit. The system should auto restart & windows should load. Let windows finish loading. Than shut down windows normally.
Unplug the PC's power cord. Since you had to remove a DVD drive you'll need to set the remaining DVD player's jumper on the drive to a Master & connect the data cable & power cord to it. (You may have to remove the DVD to see where the Master pins are located. It will be marked on the DVD player near the pins).
Now take you're new drive, do not insert it into the drive bay. Look at you're Master drive's white label. Set the jumper on the master drive first. It should be set as a Master drive with a slave.
Connect a jumper for this.
Go to you're new drive. Again look at its white label. Set this drive's jumper as a Slave drive. The Master drive should be connected to the end of the data cable. The new slave drive should be connected to the next in line connector.
Once all data cables & power cables are connected plug in the PC's power cord & boot the system, again pressing the delete key every two seconds until the boot main menu loads. Now you should see the Primary IDE Master drive & you're new Primary IDE Slave drive listed. You should also see the DVD as the Secondary IDE Master. Go to the title "Boot" again. Set the boot order as mentioned above. Save & exit the bios. Windows should load as it did before. Once windows has finished loading open windows Explorer & see if you're new slave drive is listed.
Shut down the system & unplug the power cord. Unplug the slave drive & mount it into its drive bay. Take a black marker & mark the side of the drive as slave. Disconnect the Master drive & connect it into its drive bay. Reconnect the data cables & power cables. Check all connectors before closing the case up. Re-connect the PC's power cord & boot the system. Everything should be fine. If you have a problem getting the data cable connected to the slave drive because its closer to the DVD drive as opposed to the Primary IDE Master drive you can make the slave drive a Secondary IDE Master (Change its jumper setting according to the drive’s label for Master with a slave) & connect the DVD player as a Secondary IDE Slave. (Change its jumper to slave). Change the Primary IDE Master drive’s jumper as a Master with no slave, single drive. That all.
Good luck emceedrive!
Take your time. Any troubles please post here.
You should be fine though.
Aug 11, 2008 | ASUS P4P800 SE (890552603657) Motherboard
Lcd screen on slave unit not functioning
looks like Lenoxx, Alco, Funai possibly bought out durabrand but from what I hear durabrand is not a good brand people should by more expensive dvd players why by 40 doller dvd play that will brake down quick when you can by a bigger screen last longer better featured dvd player used ones are ok to
Apr 20, 2008 | Durabrand Portable DVD
Durabrand Portable DVD Logo
143 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
