Question about Zanussi ZX99 / 5 Bottom Freezer Refrigerator
Cleaning of Freezer cooling elements
I have a 4 year old Zanussi fridge freezer with the cooling elements underneath (& fan driven). I have to regularly clean these off as they get covered in dust & stuff. (If I don't, then the red warning lights are on & the over-temp bleeper sounds.) How can I clean off these elements ? Currently I can only clean off the first few "waves" & the rest are now becoming very blocked.
  • 237 Answers
They make a "coil brush" that works just for getting into those hard to reach places. There are also vac attachments that have long skinny brush attachments for doing coils also. Although messy and time consuming, pulling the fridge out and blowing it with an air compressor type air chuck using about 80lbs of air pressure works to dislodge the hard to get to stuff. On some models that are really stuck because of cooking grease in the air coating the coils, etc. I have had to pull the fridge outside and actually pressure wash the coils with detergent to get them clean of greasy build up that causes the dust to stick like concrete.
Posted on Feb 04, 2007
SOURCE:
Zanussi ZENB 2925 Fridge Freezer, 10 years old: Freezer working OK but fridge not working. Any Ideas.
look for ice build up behind freezer - defrost cycle transducer or defrost circuit
fan that blows cold air from freezer to fridge - see if it is working or jammed on something put into freezer .
Oct 02, 2018 | Zanussi Refrigerators
I have Zanussi Frost free fridge freezer 3 years old. Bottom of freezer compartment below shelf is filling up with ice. The freezer appears very cold. The fridge seems less cold.
There is a timer which defrosts fridge daily . Put on manual . replace switch . check door closing , defrost , check defrost element .
Apr 08, 2014 | Refrigerators
Fridge light on but fridge warm, freezer still working. zanussi built in fridge freezer 3 year old
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Refrigerators
Freezer works but frigde isn't working
once ice forms on the freezer coils there is no air flow. I had the same thing. I suspect your defrost cycle is compromised. Could be the bimetal switch, defrost timer or defrost heater element.
Nov 25, 2017 | Pds GE Profile Bottom-Freezer Drawer...
Fridge on Fridge freezer not working
Ok there is a drain pan under the evap. coil under the fan that may be clogged and full of ice there is a 3/4" hole the water drains out of that needs cleared if there is a puddle of ice over it , the ice will also effect the airflow traveling down the duct to the fresh food section of the unit.
If there is no ice puddle at the bottom of the refrigerator then make sure the unit is cooling well by making sure it has been running for 10 min. or so and checking the coil in the freezer , it should have a small layer of frost on it showing its getting cold the whole way through it. Let me know how this works.
Phil
Jan 02, 2009 | Zanussi ZI921 / 8FF Bottom Freezer...
Fridge doesn't work but freezer does
i have had the same problem, it was the fan which needed to be replaced.
Aug 30, 2008 | Zanussi ZEBF277W Bottom Freezer...
Fridge does not cool
lo1972
Sounds like ice built up on the evaporator coils inside the freezer. thus hindering air flow to the refridgerator section. Is there ice build up in the freezer? This is assuming the temperature control didn't get changed inadverttily.
Hope this helps
handiman518
Jan 16, 2008 | Zanussi ZEBF250W Bottom Freezer...
Fridge not cooling
Three most common problems are bad evaporator fan motor, defrost problem, or damper motor.
Sep 30, 2007 | Freezers
sounds like the freezer evaporator has iced /frosted up and you will not get cold airflow through it. try a 24 hour defrost to clear it. then check fridge cooling.
Jun 03, 2007 | Zanussi ZEBF250W Bottom Freezer...
Zanussi ZX99 / 5 Bottom Freezer Refrigerator Logo
226 people viewed this question
Top Zanussi Refrigerators Experts
Felizardo Erilla
Felizardo Erilla
Colin Stickland
Colin Stickland
Mark Bowens
Mark Bowens
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
