Question about Whirlpool Washing Machines
Washer won't go to next cycle after filling
I have had this set for only about 2 years. They are Whirlpool Gold, Ultimate Care II, Commercial Quality, Super Capacity, with AccuWash. Last week I went to do laundry as usual but noticed once the load was in and the tub filled with water, it didn't go to the next cycle. I thought it was weird at the time so I did everything the troubleshooting thing says ie... check the breaker, see if the load might be out of balance, plugged in and so on. All was normal. I pulled out a few things and rebalanced the remaining clothes and it started working. I know for sure I didn't over load it but whatever. Then yesterday doing the wash again and again the same drill but this time I can only have maybe a dozen items in the wash on Super Large load. This is rediculous!!! I don't know what is wrong with it and now wish I had my old Amana ones back! HELP!!!!
  • 1073 Answers
SOURCE: washing machine spins but doesnt drain water until I turn it back to spin only
timer contacts are burnt replace the timer
Posted on Jun 13, 2008
  • 3 Answers
SOURCE: water doesn't stop filling tub
water not stopping filling is the pressure switch its a long thin tube that goes from the bottom of drum to the front top about the thickness of a pencil this needs taking off clearing through and checking for pin holes then refitting this should solve water problem
Posted on Jun 19, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
Posted on Sep 11, 2008
blueextc3221
  • 15935 Answers
SOURCE: My washer fills the tub, but when it goes to next cycle just hums
Your motor has failed.
Remove it from the washer to have it repaired or replaced.
Thanks
:D
Posted on Jul 20, 2009
SOURCE: whirlpool ultimate care II top load skips agitation turns
I have the same problem, and i think it is a problem with the agitator i pulled mine off, (remove softener insert below that is a seal easily removed and then a 7/16'' bolt) seems a 'clutch' mechanism between base and upper agitators is shot.
Posted on Oct 16, 2009
On rinse cycle...cannot control water temperature...set it for warm but still feels cold to touch. wash cycle is ok. model is whirlpool gold ultimate care II..top loader.
Is the hot water turned on. Remove hose from washer and check screen in water inlet. If it is clear you may need a new water inlet valve.
Apr 01, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer fills but won t advance to the next setting for all cycle
Do you hear the ticking of the dial moving? if so it could be that the points aren't getting connection to cycle it threw the various cycles
Nov 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Filter? Is there a filter I should be cleaning out periodically?
There is no filter to clean in your machine.....any lint or other build up is designed to go out with the drain water...
Jul 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
252 people viewed this question
Dan Webster
Dan Webster
Sal De
