Question about Harman Kardon AVR 500 Receiver
Harman Kardon AVR 500: randomly accelerates volume levels.
Sirs: Is the broke part #J32612050102? A digital volume control chip? A bad DTS? How much to fix? Can I fix myself; if so, where can I buy parts? Thanks. Chuck.
  • 1 more comment
  • saltonsea01 Mar 22, 2009
    Thanks meat_pop.: I ordered new volume encoder and soldered it in myself. Part was $6 plus ship. saltonsea01
  • ntsculpture
    ntsculpture Sep 08, 2012
    ver can I buy J32612050102 parts? Thanks
  • Anonymous Oct 21, 2015
    worked for my Yamaha RX-V692
The problem is with the actual eltromechanical element on the volume control, my avr 300 does this as well and I'll let you know the secret to avoiding it. There are small indents on the volume control as you turn it, if you leave it half way between indents, it will periodically start reading volume changes, if you're lucky it will go down, if you're unlucky by the time you've noticed it act up your speakers are blown. When you change the volume, make sure the control rests in an indent and the problem will never crop up again. A simple solution if you're the only one that uses the receiver.
Posted on Mar 21, 2009
You need to reset the microprocessor.
Push the main power button to "off" then push and hold down the dolby pro logic and am/fm button simultaneously while pushing the power button back "on" ...should solve the problem.
Keep in mind all settings will reset to factory settings- you will have to reset your delay and speaker surround levels-also your input selections.
Posted on Jul 10, 2009
  • Stuart Smith
    Stuart Smith Oct 21, 2015
    Awesome thanks reset worked for my Yamaha RX-V692
I have a Harman Kardon receiver Type AVR 500 RDS. Can I set it to 5ohz or 60 hz as I wish?
Should only set to frequency of your power supply otherwise may damage your receiver
Apr 29, 2011 | Harman Kardon AVR 500 Receiver
My volume goes up by itself on my AVR7300! What can I do to stop it?
i think in this model the main volume is moter controlled not endless digital step level volume,m it could be a problem with the motor control circitry, take it to repair guy along with the renote to isolate the problem
Mar 20, 2010 | Harman Kardon AVR 130 Receiver
Volume control
you will need to take it in for service your volume control is going out eventually if it does you will not be able to turn the sound down at all or even adjust it
Nov 02, 2009 | Harman Kardon AVR 525 Receiver
Harman Kardon AVR 230 Receiver Volume
You are overdriving the amp, they were never meant to be played at that volume despite the fact they will go to that level. Your only hope is to buy more efficient speakers or a stronger amp.
Apr 04, 2009 | Harman Kardon AVR 230 Receiver
How to play dts/dolby digital on HK AVR5
I believe he avr-5 has 6 channel inputs, what you will need is a dolby digital 5.1 and DTS outboard surround sound processor, say an item as the Technics SH-AC500 decoder, a Harman Kardon Signature 2.1 DTS version outboard processor/preamp, and many others on the market by different manufactors, Run the discrete audio outputs from the Processor into the AVR 5`s 6 channel inputs, select 6 channel input or DVD inputs on the receivers selector and your good to go. Be sure you are playing Dolby Digital 5.1 or DTS encoded material.
Feb 08, 2009 | Harman Kardon AVR 100
Cannot get dts from my Harmon Kardon AVR 300 via my Blue Ray
I'm not sure if this solution is still necessary however:
I own a H/K AVR300 and have a PS3 hooked up via HDMI to the TV and Optical TOSLink to the receiver. I have no troubles selecting between DD 5.1 and DTS 5.1. I can even select trueHD whatever format but I can't detect an audible difference, I think that mode might be downgraded back to regular DD5.1...
Hope this helps...
Mar 23, 2008 | Harman Kardon AVR 300 Receiver
Avr 35 volume control
Are you using the two small silver touch + and - controls that are set close to the bottom of one sound stick? They are very discrete and easily missed. (I did at first.)
Nov 29, 2007 | Harman Kardon Harmon Kardon SoundStick II...
Harman kardon avr-147
Hi Javis. This is perfectly normal ! This mode change is done because the receiver auto detects the digital audio signal and sets the receiver's DSP to decode the signal correctly. You can go into the OSD menu to bypass the auto detection of it, but it's not recommended at all ! You're getting the best audio quality by doing so. Thanks ! cheebster.
May 07, 2007 | Harman Kardon AVR 240 Receiver
Harman Kardon AVR 500 Receiver Logo
2,597 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
