Question about Kyocera FS-1030D Laser Printer
I cannot take prinout from kyocera FS1030D from my laptop
Hello i am trying to connect my kyocera ECOSYS 1030D printer with my laptop having window XP please help
    Problem Solver:
  • 7 Answers
Make sure you have the correct driver for your laptop operating system and you have a usb2 cable
Posted on Dec 03, 2008
Just bought a Kyocera FS-1030D laser printer. what do i need to do or need to connect it to my laptop. have power cable but no disks
I looked up the specs this has a usb 2.0 interface so you need a usb printer cable. it has a parallel interface but this is an older technology and your computer most likely does not have a parallel port.
you need to download the driver see http://www.kyoceradocumentsolutions.eu/index/service/dlc.false.driver.FS1030D._.EN.html
windows os may have a driver already.
Jun 16, 2015 | Kyocera FS-1030D Laser Printer
Where can I find driver for KYOCERA FS1030D for MAC OS X LION ?
hi,
here;s the download center for kyocera you can download here the driver for your printer.just follow this link good luck!
Aug 11, 2011 | Kyocera FS-1030D Laser Printer
What location on the kyocera Ecosys FS-1030D is the correct place to insert the envelope.
Pull the multipurpose tray open in the front of the printer. There you will find adjustable side guides
Jul 19, 2011 | Kyocera FS 1030D LASER 22PPM A4 PAR,USB...
Dear sir / madam many times when i print, the printer give white paper and this error pcl xl error subsystem : kernel error illegal tag operator ox8 position 30374 what i must do thanks
try a different driver
pc5
pcl 6
and kyocera own kpdl or kx
or even a mini driver
here is the link http://www.kyocerasupport.co.uk/index/download_center.false.driver.FS1030D._.EN.html
if all fails u might need to upgrade firmware on the printer
Nov 20, 2010 | Kyocera FS-1030D Laser Printer
How do i print envelopes on a kyocera ecosys FS-1300d
Just a suggestion but in the application you are using, make sure the "Page Setup" is set to the envelope you need and the source for the envelope is correct.
Also, check the driver settings to make sure they match what the application needs.
Don
Nov 19, 2009 | Kyocera FS 1030D LASER 22PPM A4 PAR,USB...
Printer KYOCERA FS-1030D not geting connected to my local Netwok.
I cannot remember the name of the utility but I know on the new drivers for the newer machine it is built into it it discovers the machine baised on its mac address and you can change / set the ip from there.Try some of the utilities from the kyocera support sitehttp://www.kyocerasupport.co.uk/index/download_center.html
May 16, 2009 | Kyocera FS-1030DN Printers
Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Jan 14, 2009 | Kyocera FS-3900DN Laser Printer
Kyorcera FS1030D - error light sequence
Dave,
You need to empty the excess toner reservoir in the front of the process unit.
Front as in the other end to where you put in a new toner.
All you have to do is open the side panel and empty all the toner out.
That should fix your problem.
Sorry to give you all the instructions like this but people still open up the toner end and have a lot of fun putting it back together.
Enjoy
Dec 15, 2008 | Kyocera Mita FS-1030D Laser Printer
How to print configuration page for a Kyocera FS1030D
Try press and hold the green button for about 10 seconds. HOPEFULLY this will cause the printer to produce a configuration page with the details. Good luck!!
Sep 25, 2008 | Kyocera Mita FS-1030D Laser Printer
Kyorcera FS1030D - error light sequence what does it mean
If you mean that the sequence is: 2nd led and then 1st+2nd+3rd
the problem is in fuser unit. You have to call a technician to check the lamp, the thermistor and the thermostat inside the fuser unit
Mar 16, 2008 | Kyocera Mita FS-1030D Laser Printer
Kyocera FS-1030D Laser Printer Logo
327 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
