Question about Vivitar 283 Flash
Charging problems The flash gave no signs of operation. After disassembling, I tried to troubleshoot the DC-DC converter and the charging circuits. I was able to get it charging somewhat - when powered on, the flash gave a whine that rose in pitch, but more slowly than I expected. The capacitor only charges to about 100v. When I disconnected the cap, the charging circuit reaches 400v, and the voltage rises much more quickly. How do I test the capacitor to verify if it's bad?
    Champion:
    Scholar:
  • 216 Answers
Try to check that capacitor by parallel it with a good capacitor.
Any uf capacitor that is close will do. Just make sure you have a 300v or more cap.
atdlee@netzero.com
Posted on Feb 26, 2008
Rv 12v system stopped working, doesnt work from battery nor shore power
check dis connect if ok see if converter is charging batteries and operating 12 volt appliances check fuses in fuse box for converter or in converter itself
Aug 25, 2018 | RVs
My toyota voxy 2002 model was put on diagnostic machine and gave us fault code p1215 what do i check
- Faulty EDU - EDU harness is open or shorted - EDU circuit poor electrical connection - Faulty Spill control valve What does this mean? Possible symptoms - Engine Light ON (or Service Engine Soon Warning Light) P1215 Description The EDU drives the spill control valve at high speeds. The EDUs high speed driving under high fuel pressure conditions is achieved through the use of a DC/DC converter that provides a high voltage, quick charging system. The engine ECU constantly monitors the EDU and stops the engine in case an abnormal condition is detected. The battery voltage is increased by the DC/DC converter. A voltage of approximately 50 V is applied to the spill control valve in accordance with the IJ+ signal received from the engine ECU. At this time, the injection verification signal (IJF) is sent to the
Read more: http://www.autocodes.com/p1215.html
Nov 05, 2016 | Toyota Cars & Trucks
Dc lo keeps blinking on the fridge and lights go low in rv, power converter middle light is blinking green
The battery is not being charged OR is no longer accepting a charge.
The inverter does not charge the battery. An inverter consists of components that first convert the battery's low (12) volt "direct current" (DC) power used to power automotive devices to a higher (120) volt "alternating current" (AC) power that is required by nearly all household appliances to operate properly.
The charging of the battery occurs when either the RV's engine is running and spins the alternator, etc. OR when connected to another charging device - whether it is permanent or portable.
With the RV engine running, there should be about 13.5 - 15 volts, DC on the battery posts or terminals. This voltage is coming fromt he RV alternator and since it is greater than the 12 volt battery, "charges" the battery. If you use a portable charger - that is part of a generator, or plugs into a power port at a camp site, etc. this will charge the battery.
When none of these things is happening, the battery voltage will slowly drop. Once it is at ~10 volts, it is "dead" and will need to be recharged.
The battery will no longer accept a charge if a "cell" inside it has "opened" or "shorted", or if the battery is at the end of its useful life. The battery state can be checked quickly by any mechanic.
I hope this helps & good luck!
Nov 19, 2013 | Electrical Supplies
Laptop will not charge battery. Issue with internal power converter, etc.
The motherboard has charging circuits built in to regulate the charge to the main battery, in rare causes it fails leaving a choice to attempt a repair or replace the motherboard. I suspect this is what has happened to your system.
Apr 05, 2012 | Lenovo IdeaPad U550 (374955U) PC Notebook
UPS battery is over heating while plug in, and this is the regular problem in the UPS battery
The battery in UPS supplies a dc vcoltage to an converter which in turn converts the dc into acceptable ac voltage. When a load is connected to output terminals of UPS, a certain amount of current is drawn which in turn to be supplied by battery to the converter circuit. When the current flows through the battery, due to its own internal resistance heat is generated in battery that causes heating up of battery. When there is no load to ups, but charging of battery is on, the charging current passing througfh the internal resistance of battery heats it up. so either charging or discharging time the battery gets heated up. Ripple is sometime expressed as millivolts to per output volts. insuch cases the ripple has to be multiplied by output voltasge to get the correct value. Ripple content can be measured using fast responding sensors connected to the system or oscilloscopes.
Oct 31, 2011 | APC Smart-UPS SC 1500VA UPS System
Won't charge, purchased new battery and new AC adapter, still does not charge. AC charges other Dell I have so must be in charging circuit or connector. How do I disassembly computer to voltage getting to...
You are right, most of the situations like this end up that the charging connector fixed / soldered to the motherboard get damaged because of shaking the connector when ever we connect and disconnect it .
Mar 06, 2011 | Dell Inspiron 2600 Notebook
Sony ericcson k800i, new battery and charger but wont charge up. any thoughts?
If it was not charging before and you replaced the battery and charger, then the charging circuit has most likely failed possibly a DC/DC converter. Probably terminal I'm afraid
Nov 10, 2009 | Sony Ericsson K800i Cellular Phone
Changed motherboard, needs battery to power up, but when battery goes dead no power. does this laptop need battery to power up?
no, means your charging circuit / charge controller is not working. Double check that the board (also known as DC converter or DC Controller) is seated firmly, all connectors are in place, etc. You may also check the power supply as well, or try substituting another supply for a short time.
Nov 06, 2009 | Toshiba Satellite L45-S7409 Notebook PC
DC-DC converter problem
You need to get the converter changed. But before you change, try a different power source
Sep 09, 2008 | Gateway MT3705 Notebook
My Compac Armada M700 does not power up.
Had the same problem with My Compaq M700 No Boot Or Post. Battery Light Flashes 8 Times, Have to Wait 24 to 48 hrs sometimes longer to get Laptop to Start. Tryed the DC Converter Board Change No Difference same Problem. Noticed When Laptop Did Start Clock Time Was always a Little Off 2-4 Hours sometimes more. So Figure CMOS Problem With Time Issues. Read About Battery Memory Transitor Voltage spike Detection Issues Corrected With Newer Bios Flash at HP Supports. So I Flashed Bios With Latest 686h. During the First Boot After Reflash Battery LED Did flash No Start, After pushing the power button again it Started. And has Every since.So Far Laptop Now Boots Everytime and CMOS Checksum Seems To Keep Time Correct In Windows. The Bios Flash Corrects a Voltage Spike Detecting Transistor In The Charging Circuit. During First Start after flash Bios will run system test on the charging system and Correct CMOS. Worked for Me Hope this Helps a Few.
Oct 30, 2006 | Compaq Armada M700 Notebook
Vivitar 283 Flash Logo
216 people viewed this question
Top Vivitar Cameras Experts
Damen Wong
Damen Wong
DMS-UK
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
