Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Repost last comment on pt-47wx53g problem
Can you repost your last comment? I'm still trying to figure out how the fixya system works. I think you posted another comment after the one about the a-board check points, but I can't see it. Some other "solution" is the only thing I can see and I don't know how to make it go away because its completely useless. Thanks for your help so far!
  • 1 more comment
  • Steven Crawford
    Steven Crawford Dec 03, 2008
    Thanks I'll give it a go tonight and see if I make progress. Not sure how you get paid on this thing, but I'm quite sure I need to "accept" your solution to my original problem. Can't do that until you post something else to it. Thanks!
  • Steven Crawford
    I'll check the signal boards too, but switching inputs doesnt improve anything. Most don't even show the vertical bar. Maybe only 1 does that and I have no clue which one it is. I'll research that further also.
  • Steven Crawford
    Also Page 44 in the service manual has flowcharts for entering the service mode etc. How can I do that if I can't see what's displayed on the screen?
  • Panasonic Master
  • 19,396 Answers
Hi, I post here my last comment, follow the diagram at page 44, leave the checkup at page 16, for some of the test you need raster, and the TV is in protection mode now.
From protection mode follow troubleshooting diagrams, I think is page 44/45.
There are many faulty component that can give you blank screen with no raster, the strange things is that the TV stays on, has sound and is not on protect.
Test also the sygnal boards (the ones with the AV connectors) and see if it makes any difference switching the signal to a different input, this TV has several ICs that manage the video signal, testing blindly will give no help. Follow the diagrams on manual.
I think the following was my last comment:
You need to follow the troubleshooting charts at page 44 of user manual.
(download the service manual here)
Regarding the jungle chip, that is just a familiar name for the main computer CPU, service manuals rarely call it Jungle chip. Your jungle Chip is the main processor, IC4511, be careful handling the component arount the IC4511, some IC in there is sensible to static charges in your hands, better to keep fingers away.
In your case I would start testing following the diagram at page 44 of SM. I will also test the pico fuses at the base of convergence ICs, if the STKs had been replaced
That is what you do when the nature of the problem is not clear.
Since there is no protection mode on, the fault
can concern IC3001 and IC3002 that are vidio processors, and other parts involved.
If at any point you get the led on, and TV going in protect mode, with a flashing led, that is a step forward, means that the jungle IC (The IC4511) had detected the fault.
Start testing following the procedure at page 44, or same page on your version of service manual.
Posted on Dec 03, 2008
Pt-47wx53g tv won't click over n than the power button will blink 5 times
IC4511 has failed on the DG board replaing the DG board as a unit i the only way to fix the issue. The DG board isnt serviceable
Jun 01, 2012 | Panasonic PT-47WX53 47" Rear Projection...
Convergence problem on pt-47wx53g
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Your TV will commonly have one or more of the following symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio or Video
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 16, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt-47wx53g tv power light blinkcs 5 times and goes out.
Convergence problem...causing the TV to shut down. Goto www.TvRepairKits.com and get one of their fixes.
Jun 04, 2010 | Panasonic PT-47WX42 47" Rear Projection...
PT-47WX53G. TV got moved. Unable to move blue
The convergence ICs have failed which is very common when the set has been moved as a wek IC wont allow the color to be moved. You can get the PT52WX53G convergence repair kit from www.tvrepairworld.com which is the correct one for your model. The kit contains the parts and the CD with repair instructions.
Apr 10, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic CinemaVision PT-47WX53G : half the screen is distorted
did you try to try to adjust the vertical and the horizontal of your tv?
Oct 05, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Pt-47wx53g has red ghost. I tried adjusting convergence but some will not adjust
You have a problem with the convergence output IC's. They need to be replaced. This is a very common problem with all projection tv's as those IC's are high current components.
Jun 10, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Hi, We need solution for B-Ray connection to PT-47WX53G
We solved the problem with Sony experts from Vio. Thank you
Jan 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
PT-47WX53G green convergence and wave on bottom of screen
Had same problem with Red. Could not adjust. Funny broken lines. Found this link:
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Replaced the ICs. Was disappointed at first 'cause it was still all bowed out, but then realized that the Convergence 2 "target" can be changed with the number keys. Working thru 1-9 and going back to readjust as necessary adjusted each one into perfect alignment.
Problem solved. TV works great.
I should add that while I am reasonable technically adept, I am a software geek and never soldered before... hardest part was getting up the courage to dive in and do it myself. Glad I did.
Sep 24, 2008 | Panasonic PT-47WX53 47" Rear Projection...
How to reset defaults Panasonic HD PT-47WX53G TV/picture
First of all are you sure you were in the factory menu this step requires alot of known how!!!!!! By using your hand unit only customer controls can be reached unless you know factory menu setup. Which starts like this ,make sure antenna to cable then go to menu set sleep timer to 30 mins exit out now enter ch 124 then press v- down on tv you should now see on top CHK ,also these sets have double convergence patterens.if you were in factory set up for more information look in www.freelists.org techassist/09-2005 .let me know if you still need help.
Nov 14, 2007 | Panasonic PT-47WX53 47" Rear Projection...
You will have two of the STK392-110's in the set so a good idea to replace both. The reason is one of the IC's is dedicated to RED horizontal and vertical and then GREEN horizontal, the other is dedicated to the BLUE horizontal and vertical and then the GREEN vertical. These are the best place to start for ghosting in the colors.
Mar 12, 2007 | Sony KP-51WS500 51" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
168 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
