Question about HP PSC 2410 All-In-One InkJet Printer
Fax does not respond to programming
Fax picks up on the third ring, regardless of what its programmed to do. already tried reset, it didnt work.
    Sergeant:
  • 390 Answers
You need to uninstall it and reinstall it. It sounds like it is ignoring pc communication so errors are present. If no good, email me at amethystgerry@bluemaxx.com.au
Posted on Aug 16, 2007
My Lexmark Interpret S405 fax?copy machine picks up incoming call from cell phone as fax. it goes onto fax automatically after 2 rings..
It seems that you're sharing your home phone line with your Lexmark fax machine. You can adjust the "pick-up" ring from the printer operator panel by pressing the Setup button > Fax Setup > Ringing and Answering > Pick Up On > select your preferred number of rings before the fax answers.
Please note:
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Nov 08, 2011 | Lexmark Interpret S405 Wireless All-in-One...
How to get my s405 to receive a fax
You might want to check the User's Guide for your printer. To access it, on your computer, click on Start > All Programs > Lexmark > Pro200 Series > User's Guide. Go to page 62 to know how to setup your printer to fax.
If your fax is already setup - meaning you're already able to send faxes but not able to receive. Make sure that the Auto Answer is on. To check that, on the control panel of your printer, press on Setup > Fax Setup > Auto Answer.
If you have an answering machine, make sure that your fax will pick up 3 rings higher that your answering machine. If you answering machine picks up on the 5th ring, set your fax to pick up on the 8th ring. You can change that under fax setup.
If you have a voice mail service enabled in your phone, you'll need a distinctive ring feature for your fax to work if it's being shared on the same line.
May 23, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Phone is plugged in to a fax machine and the phone rings too many times before answering machine picks up so the fax machine takes over. How can I reduce the number of rings so that the answering machine...
Change the answer machine rings to answer number to less than the fax number of rings to answer or increase the number of rings to answer on the fax machine. Would need exact model number of phone system to give more detail on programming steps. Info should be in manuals of phone system and fax machine.
Dec 07, 2010 | AT&T DECT 6.0 Cordless Phone System with...
Cannot send faxes on my all in one hp office jet 5610
If the recipient side is ringing, then the problem is on their end. It sounds like the receiving fax is not set for auto-answering a fax call. A receiving fax machine should pick up and start to attempt the reception even if the fax number is dialed from a normal voice-only telephone; the receiving machine has no idea if the caller is a fax or a regular phone. It should pick up regardless and start to negiotiate the fax (that's the high-pitched whistling sound at the beginning of the call).
May 15, 2009 | HP Officejet 5610 All-In-One InkJet...
How do you program the machine to recognize the incoming fax ring tone
if it is a sharp fax machine it has a reception button which you could change the status of unit from telephone to fax or answering machine. usually the indicator of these button is located on the rightmost portion of the lcd screen. once you press the reception button while the unit is on standby, the indicator will point on which of the three settings will you want to activate.
May 12, 2009 | Office Equipment & Supplies
I can send fax but cannot recieve one it just rings
My Mode was wrong. I switched it to telephone and fax (instead of manual). Then i set the ring to pick up on the third ring. now i dont have to be here to press start everytime a fax comes. I found all the information by searching for the manual on line it is under "Basic fax settings"
Mar 19, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
FAX JX500
Mary:
Given that the last question I responded to for you related to a Fax JX200 - and this to a JX500 - I am not certain which model you are actually asking about. The information that follows relates to the JX500. Further, if you need information in this regard on the prior post in order to feel that the previous response was a FixYa level response, please let me know. I responded based on the information you provided...
Based on the fact that you are getting a constant 5-ring situation, it appears that the machine is in TAM (tel-ans mach) mode. The purpose of 5 falls into remote recovery of messages - toll saver results in the phone answering after 2 rings if there are messages to retrieve, and 5 if there are not. This is done to prevent long-distance charges if there are no messages.
Two ways to accomplish an 8-9 ring objective. (1) Place the machine in manual mode, which means answering every call and sending faxes to the machine. Additionally, a "fail-safe" on this mode is that it will switch to TAM/automatically answer (if there is a recorded greeting message) after 15 rings - below. (2) The incoming ring - ring count - can be set (under Fax/Tel Auto) to ring 10 to 60 seconds before the fax picks up. (3) Alternatively, the Incoming Ring ring count can be set to have the fax ring 2 to 30 times, depending on the country specific parameters.
Re TAM: When the fax is set to <MANUAL MODE> and <MAN/AUTO SWITCH> has been set to <OFF>, TAM MODE will be activated if the fax rings 15 times and the call is not answered (only when an outgoing message has been recorded). When the call is disconnected, the fax returns to <MANUAL MODE>.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding your specific needs, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Aug 04, 2008 | Canon FAX-JX200
Winfax Pick-up
Try looking at best buy for a fax switching device it can tell the difference between data and voice. I don't know how well they work but i have not used that particular program. I did find this though on another site http://www.windowsitlibrary.com/Content/238/15/1.html
You can have Microsoft Fax automatically answer every incoming call to your modem or, instead, you can manually choose which calls to answer. The quickest way to change this setting is to right-click on the fax icon on the Windows taskbar then choose Modem Properties to display the Fax Modem Properties dialog box . Another way to get to these properties is from within Exchange; choose Tools, Microsoft Fax Tools, Options, then switch to the Modem tab, select the modem, and click the Properties button.
So you have to change the settings in Exchange I assume
Jul 08, 2008 | Symantec WinFax Pro 10.0 for PC
Sharp UXB700 Fax
Below is for when you are using machine in fax mode, is that how you use it or are you also using the answering machine function? ie TAD mode
If desired, you can change the number of rings on which the fax machine
answers incoming calls in FAX mode. Any number from 2 to 5 can be
selected.
1 Press FUNCTION once and 3 times.
Display:
OPTION SETTING
To select FAX mode, press
(with no document
in the feeder) until the arrow in
the display points to FAX.
RESOLUTION/
RECEPTION MODE
RESOLUTION/
RECEPTION MODE
FAX
A.M.
TEL
Using TEL Mode
58
2 Press once and once.
3 Press once.
4 Enter the desired number of rings (any
number from 2 to 5).
Example: 3 rings
5 Press to return to the date and time display.
Note: If you are using Distinctive Ring, the fax machine will answer calls after
two rings regardless of the above setting.
Oct 16, 2007 | Office Equipment & Supplies
HP PSC 2410 All-In-One InkJet Printer Logo
Clive
Clive
