Question about Imperial IFS40 Deep Fryer
My customer purchased a used ifs-40. the wiring on the gas valve was dissconnected. i need a wiring diagram to hook it up properly. pat
  • 125 Answers
Hi there, here is the manufactures info: or when there use their 800 number to contact directly.
Hope that helps, and thank you.
Posted on Feb 21, 2009
  • 1,199 Answers
The manufactor will give you one free of charge if you viset web site
Posted on Dec 06, 2008
How can i tell if my gas valve is bad on my whirlpool oven
Hello. What problem are you having specifically to point you towards the gas valve? There is a service flash on the DSI ignition wire harness. The part number needed is W10701462. The symptom is the bake burner will spark but not ignite. A possible cause is the brown ignitor wire has gotten pinched between the side panel and back bulkhead causing intermittent ignition. The gas valve part number is 8054079 and is #15(bottom right) in the exploded diagram if needed. Check the tightness of all wiring connections, make sure the oven door is closing properly( if open, the bake ignition circuit will shut down after 60 seconds). Notice the pictures 3, 4, 5, and 6. They show other problems that can cause the no-ignition issue. Pic 4 gives the proper readings for a correctly functioning gas valve. You will need a voltage/ohm meter--BE CAUTIOUS--POWER WILL BE ON DURING TESTING OF THE VOLTAGE TO THE VALVE! TURN OFF THE POWER AND CAREFULLY REMOVE THE WIRES WHEN CHECKING THE COIL RESISTANCES. I hope I helped you!
Oct 03, 2015 | Whirlpool GS470LEM Gas Kitchen Range
How do I replace the thermostat on a Teledyne Laars EPC 250?
First, for your information, Jandy, is now the new owner of Teledyne Laars.
So, their parts will work, and are an exact fit for any Teledyne Laars product.
What did you have prior to the new thermostat control board, that you purchased? Was it just a mechanical thermostat?
I can try to assist you. But I would need more information, and more time to look at the wiring diagram.
please upload them here, and one of us here, would be glad to assist.
you can also email me at
p s m helps at g mail
good luck
Mar 23, 2015 | Teledyne Laars Pool & Spa
My car thinks it is being stolen 2008 Ford Fusion anti theft has disabled ignition. Tried disconnecting the battery; remote entry with ikt; using key to unlock; hit panic button and turned it off with...
Hi Eileen , How do you know your having a anti-theft system problem ? Any lights flashing when you try to crank the vehicle ? The engine does not crank over ? If it is a anti-theft system problem ,disconnecting the battery is not going to do anything except lose some learned setting's in some control modules . There are a few thing's you can check but if none of these are the problem your going to have to have it towed to the dealer ! It'll need to be checked for DTC'S - diagnostic trouble codes !
PATS disables the vehicle from starting if there is:
  • a damaged PATS key.
  • a non-programmed PATS key.
  • a non-PATS key (key has no electronics).
  • damaged wiring.
  • a damaged transceiver.
  • a damaged instrument cluster.
Inspection and Verification
  1. Verify the customer concern.
  1. Visually inspect the following for obvious signs of mechanical or electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Large metallic objects, a second passive anti-theft system (PATS) key on the same key ring as the PATS key, or electronic devices on the key ring that can be used to purchase gasoline or similar items
  • Ignition lock cylinder
  • PATS key
  • Use of a non-PATS key or incorrect PATS key
  • More than one PATS key on key ring
  • Remote start system installed
  • Smart junction box (SJB) fuse(s):
    • 13 (7.5A)
    • 23 (7.5A)
    • 26 (7.5A)
  • Circuitry
  • PATS transceiver
  • Ignition switch
  • Instrument cluster
You may not know where some of these things are located !
Mar 22, 2015 | 2008 Ford Fusion
Need a wire schematic for a deep fryer gas valve elite efs 40
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Jan 28, 2015 | Imperial EFS-40 - Gas Elite Deep Fryer -...
How to hook up a starter
battery and large wire eyelet w/fusible links on it, both go to large stud on solenoid. purple wire w/small eyelet goes on small stud, should have a S near proper small stud. do this with battery dissconnected
Dec 29, 2013 | 1990 Buick Century
Dayton Heater M/N 3E227E
Hard to believe they sell a retrofit kit for a Gas furnace to a Customer....This is ahrd to advise you on with out seeing the schematic and if it is indeed intended for that furnace....the Spark mounting location is CRITICAL for safety so make sure that is correct above all.....OK The wire coming off the transformer and tied to the red wire going to the heat excghanger would most likely be a High Limit switch...cuts the gas off if the blower doesnt work etc or you would have a this switch must be in series with the transformer to cut power when the switch opens....the wire MV/PV coming from the "Electronic control box" needs to go to the New Gas Valve you should have which will have a termional marked MV/PV (Main valve/Pilot/valve) as your old one was for a standing pilot application and when you have electronic ignition you req a Gas valve for Intermittent pilot should also have 2 more terminals on the valve MV and PV which will have seperate lines from the ignition control as well....basicvally there will be another wire coming from MV/PV going back to the transformer...make sure all wiring is correct and I would strongly advise you have a technician check your work before you attempt to use it....if wired incorrectly you could have a serious delayed ignition as its possible to power the main burner instead of the pilot if you wire it up wrong below is a typical spark wiring diagram....may not apply totally to your system but it will give you the general idea79f9627.gif
Oct 31, 2009 | Heating & Cooling
Whirlpool dryer newly hooked up and will not heat. Do they have a reset button. Tumbler moves. It is gas. electronic ignition?
Make sure that your gas valve is on, if there is no gas, it won't be able to ignite and therefore no heat. It is possible that the unit is defective as well. If you are sure that you have the gas line hooked up and the valve is on, also make sure you have the proper electrical connection. Most gas dryers are 120V and a standard receptacle is used. If all of that is correct, then I would suggest calling the tech support number in the information on the unit or call the retail establishment you purchased it at.
Oct 27, 2009 | Whirlpool Dryers
Need to see a diagram on wireing fore elect starter
what brand and model machine are we talking about also if you have any patent # you could enter that at google pat. search may have exploded view dia.
Jun 18, 2009 | Air Tools & Compressors
Imperial IFS40 Deep Fryer Logo
237 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
